Question about Radio Communications
Ilive bluetooth receiver/adapter Power button does not respond. Green light on all the time and blue pairing light won't come on...any solution please!
    New Friend:
I had the same problem and I contacted iLives support team and it worked!
This was their response.
"Thank you for writing to us.
I'm sorry to learn that the unit is not powering off. I apologize for the inconvenience this might have caused to you.
Please try these steps given below to resolve your issue :
1. Drain the complete battery from the unit.
2. Once the battery is completely drained on the unit, press and hold the power button on the unit for 30 sec.
3. After 30sec connect the unit to a charger and charge the unit completely and have a check.
Hopefully this works for you. Let me know if you need further assistance.
Thank You,
Have a nice day.
Regards,
Roger Paul"
Posted on Oct 05, 2013
  • Mandy Johnston
    Mandy Johnston Nov 29, 2014
    i tried that and they still do not work. please help :-(
I have a pair of Auvio colored Bluetooth headphones and i am unable to use them via bluetooth and reseting doesn't work and i cant find the headphones on bluetooth.
The poorly written manual says to hold the Play/Power button for five seconds at which time you will get the blue light, Then hold the Play button again for three seconds to enter the bluetooth pairing mode at which time you will see the alternating red & blue flashing light. Ignore all of that and just hold the Play/Power button for however long it takes to start the red and blue flashing sequence. That means the headset has entered the bluetooth pairing mode. Then make sure whatever device you are trying to pair has its bluetooth pairing mode activated and you will eventually see Auvio BTCHP on your device's pairing window. Select it and you should then be paired.
Apr 29, 2017 | The Audio Players & Recorders
How to pair my ilive blue tooth wireless head phones with a proscan tablet
Open the blue tooth menu on your tablet (usually -> Settings -> Bluetooth)
Turn on your head set. Usually there is a pairing button option, on your set, you need to turn the headset off, then turn it back on but hold the power button for 8 seconds until they will flash red/blue.
You should be able to find your headset then on your device.
How to pair bluetooth headphones to your phone
Nov 08, 2015 | Proscan 10.1-Inch Internet Tablet,...
Ilive bluetooth receiver/adapter won't turn on
Its a simple push button device , and if its not turning on . The product has stopped working and you can only return it back to the store or buy a new one...
Dec 26, 2013 | DPI iLive Bluetooth Receiver/Adapter
Manual for ilive bluetooth receiver and adapter lAB13
Have you actually checked the charger is actually working with power coming out of plug that plugs into device.. THe actual charger unit may not be connecting properly into wall socket...
Dec 09, 2013 | GPS
How do I acitivate it
Charge your headset
Charge the headset's battery fully before using the headset for the first time.
1 Put the headset in the supplied charging case and close the cover.
2 Plug the travel adapter into the case's charging socket.
Put your headset in pairing mode
1 Ensure that the headset is off (see Turn headset on/off below).
2 Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
Turn on Bluetooth on your phone and pair with headset
1 Set your Bluetooth phone to discover the headset by following your phone's guide.
Typically, the steps involve going to the Settings, Connection, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices. Your phone will find the Samsung WEP200
headset.
2 Select Samsung WEP200.
3 When the phone asks if you want to pair with it, confirm by selecting Yes or OK.
4 Enter the headset passkey or PIN, 0000.
Your phone and headset are now paired and ready to make and receive calls.
1 Place the headset over your ear.
2 On your phone, make a call to the number you want.
3 If your phone and headset are successfully paired, you will hear ringing on the headset
After you have successfully paired your phone and headset, you do not need to repeat these initial setup steps each time you use the headset.
To turn the headset on
Press and hold the Multi-Function button for4 seconds until you see 4 blue flashes on the indicator light, then release.You will hear a tone and see the indicator light flashes while the power is on.
To turn the headset off
Press and hold the Multi-Function button for 4 seconds until you see 2 blue flashes on the
indicator light, then release.You will hear series of 2 tones and see the indicator light stops flashing.
http://ars.samsung.com/customer/DownloadAnsTempl?AT_ID=70171&SEQ_NO=2
Jun 07, 2011 | Samsung Bluetooth?® WEP200 Headset...
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
How do I pair my s9 bluetooth headset with my
do you have the adapter that makes your ipod nano have bluetooth?
im guessing you do so
turn on the bluetooth adapter on the ipod
mod the power button on the motorolla s9 untill blue light is constantly on
from the ipod select the bluethooth options and select the headset
use the password 0000
Apr 29, 2010 | Motorola Mobility MOTOROKR S9 + Bluetooth...
I have a cark-11 bluetooth adaptor for my car.
  1. Press and hold the "Answer/redial" (green) button and the "Volume down" button together until you hear a tone and the blue LED begins to flash.
  2. Be sure Bluetooth is enabled on your phone. Follow the documentation provided with your phone to search for new devices.
  3. Select CARK 11 from the list of Bluetooth devices on your phone.
  4. Enter the passcode: 1234.
  5. The LED stops flashing when the phone is paired.
Note: You may follow the above steps to pair up to four phones. Pairing a fifth phone causes the first paired phone to be deleted.
Apr 06, 2010 | Cell Phones
Radio Communications Logo
2,616 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
