Question about Brother MFC 210C All-In-One InkJet Printer
MFC-210C Can this equipment be used as a regular PC printer, I can't find any connector to plug in a data cable other than the regular j11 phone jacks .
  • Dannyg821 Aug 28, 2007
    I know what a USB port looks like but I can't find it. Is it on inside of a compartment??
    Sergeant:
  • 279 Answers
Yes, this is a USB printer. The connection will be very small, either a slot, or a square hole with two corners cut off. The cable will connect to a USB port on your computer (the aforementioned slot).
Posted on Aug 28, 2007
You have to open the printer up to see the USB port . That is open the lid to expose the ink cartridges and you will see the port to plug your USB cable.
Posted on Sep 07, 2007
Need to install Brother MFC 210C Fax/Phone/Printer on my computer with Windows 7 Need the driver program
Unfortunatly the full driver and software have not been created for Windows 7 for this particular Machine( mfc-210c)
You can install as printer and basic scanner by simply plugging in the USB cable, windows 7 will install the drivers automatically.
Apr 09, 2010 | Brother Office Equipment & Supplies
Can the Brother MFC-210C read a Turbo SDHC Card ?
No, SDHC cards are not backwards compatible with SD formated devices. You will have to get an ungraded SDHC reader or SDHC device you can plug into your PC to read it that way.
Dec 28, 2009 | Brother MFC 210C All-In-One InkJet Printer
Fax, phone line cable should be plug in "LINE"port or "EXT."
The "LINE" port plugs into the wall socket.
The "EXT" port can have an analogue handset plugged into it.
Nov 17, 2009 | Brother MFC 210C All-In-One InkJet Printer
Already purged mfc-210c but the same error
não entendo ingles não poderia mada mensagem em portugues
Jan 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C All-In-One SAYS I HAVE A JOB TO FINISH BUT I HAVE NONE AND I CAN'T DO ANYTHING ALSO
--Print data remains in the MFC’s
memory.
-Re-start printing from your computer.
memory. The USB cable was
unplugged while the computer
was sending the data to the MFC.
-Press Stop/Exit. The MFC will cancel the job
and eject the page that is being printed.
Oct 22, 2008 | Computers & Internet
Brother MFC-210C INSTALLATION
Try plugging into a different USB port on your computer.
Jul 18, 2008 | Brother MFC 210C All-In-One InkJet Printer
MFC 210C "unable to print"
i had the same problem i simply pressed the menu/set button then mono start then up button (serch/speed dial) 4 times, then 01 wait till it makes a beeeeeep sound then unplug it (none you will loose all setting and data on the printer
May 06, 2008 | Brother MFC 210C All-In-One InkJet Printer
Faxing
The phone wire from your wall jack gets connected to the jack marked "line" on your printer. If you are also are connecting a separate phone to the printer connect a phone wire from the jack marked "ext" to your phone. Just in case you need a manual here is where you can download one. Please rate if this helped. Thanks. Have a nice day. http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Mar 21, 2008 | Brother MFC 210C All-In-One InkJet Printer
PC won't detect MFC-210C Printer
TRY THIS, remove or uninstall the printer from your computer and turn it off.
Now, before you switch back ON the computer, remove the USB connection of your printer.
When the computer is done loading. Install the Printer using the CD that comes with the printer.
When the installer ask you to insert the USB connection of the printer,
that's the only time you should insert it to the USB port... switch ON the printer... Installation should proceed smoothly until completed.
That should solve your problem
Jan 21, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
85 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
