Dell v520 keeps saying I have a communication problem. How do I fix. Also is this an air printer
5 Suggested Answers
map9966
  • 2351 Answers
SOURCE: computer will not communicate with printer
Ckeck in control panel & se if the driver software installed. It should be listed in Add/remove programs. If it is, power up the piinter & load windows Vista update service. See if Vista has any patches for you're printer. If no, goto Lexmark & go to the driver section for you're P4350 printer software for Vista. While in Vista update, install any updates listed.
Click on the link provided.
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:479:0:0&searchLang=en&os_group=Windows%20Vista&target=
Creat a folder on you're desktop & down load the latest driver software in-to the folder you created. Uninstall any Lexmark software that might have been in add/remove programs. Install the driver software you downloaded. If all this still fails, call Lexmark since this is a new printer. The number should be in you're manul. Or you can go here for free support.
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_652569481_0_en,00.html
Luck!
Mike
Posted on May 29, 2008
sys_admin
  • 829 Answers
SOURCE: computer not communicating with my printer Dell A920
Check for the cables if found defective replace and try.
Posted on Apr 02, 2009
  • 523 Answers
SOURCE: printer 924 dell cant communicate with computer
cannot comunicate means you have to reinstall the driver again, could be corrupted after the virus, also communication problem could be from the cable you use, check both.
Posted on Apr 17, 2009
MUKHTAR
  • 2017 Answers
SOURCE: My Dell 926 All-In-One Printer will not print from my dell comput
kindly change the usb port put the cable in other usb port.
Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online. Also I suggest you to change the usb port and the cable also still if you facing the problem follow these steps, right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Mar 19, 2010
It says no communication to the computer but it says ready to print? how do i fix this?
shut down pc and printer and restart
(also mercury is retrograde)
best regards
Ck
Aug 18, 2011 | Dell 926 All-In-One InkJet Printer
Computer says there is no communication with the printer
Couple of things to consider and try,,,have you tried another USB device in the computer, like a flash drive? If it can read the flash drive ok then the problem is not the USB port. Try using a different USB cable for the printer. Make sure your computer is up to date with the most current drivers. To me it sounds like a bad printer cable. Another thing to try is having the printer attached and when the error message comes up try wiggling the cable to see if communication is restored. If so then chances are that the printer cable is bad. Hope this helps.
Jul 22, 2010 | Dell Photo 964 All-In-One InkJet Printer
My printer keeps saying there is a paper jam, but there is no paper in it. How can i fix it?
Look for loose scraps of paper in the feed path. Blow it out with compressed air or a vacuum cleaner setup to blow.
Aug 01, 2009 | Dell 926 All-In-One InkJet Printer
Cannot print from laptop with Dell 3300...says Communication not Available
I have seen that in most of the cases (with lexmark and dell printers)it is fixed by reinstalling the printer software. Be sure that youcompletely remove the older drivers using the cd or using add/removeprograms.
There is a good article on dell website to fix this problem by different methods. Here is the link
Jul 29, 2009 | Dell W3221 Projector Lamp for 3300M
An error code 1706 keeps coming up. It says "no valid source could be found for product Dell Connections (Support Software). "The Windows Installer cannot continue. I'm not trying to install anything and...
Microsoft says that Error 1706 is a Microsoft Office Error code which
indicates that required files can not be found by Setup. Since you
are trying to install new programs I feel that this is probably the
correct interpretation of your error code.
Microsoft's Knowledge Base Article 297834,
http://support.microsoft.com/default.aspx?scid=kb;EN-US;297834
Jun 26, 2009 | Dell Computers & Internet
Printer 924 dell cant communicate with computer
Apr 17, 2009 | Office Equipment & Supplies
Computer isn't communicating with my printer
The problem could be because of ONE out of FIVE problems listed below. Try the steps recommended and it should fix the problem.
Thanks,
Abhishek
Apr 08, 2009 | Dell 962 Photo All-In-One InkJet Printer
Computer not communicating with my printer Dell A920
Apr 02, 2009 | Dell A920 InkJet Printer
Computer will not communicate with printer
Go out to Lexmark web site and look for a vista update in their software download section. So this should solve your problem.Most of the cds which come with equipment do not contain vista software and drivers.
Aug 06, 2008 | Dell 962 Photo All-In-One InkJet Printer
When trying to print it says "Communication Not Available"
Reinstall the printer driver.
Get the latest driver from Dell.com Drivers and download.
Jul 08, 2008 | Dell A940 All-In-One InkJet Printer
32 people viewed this question
k24674
