Question about Home Security
Tru bolt home safe tb138B
I need to change the password
What is the best way to keep important documents and cash home safe from burglars?
Burglar's can be one of the most unwanted situation that take everything they find easily. And the first thing they wanted to grab is home safes without even knowing what is inside that. And having the safe bolted down will almost make the odds 100% in your favor of the thief leaving it behind. So, having a home safe that can provide you with the safety from such burglar's is one of the best thing to make yourself out of such situations. There is an website that provides there valuable customers with such home safes that are burglar resistance that you can buy after getting it compared with other safes and choose the best with almost every options available to them from TossTheKey
Jan 04, 2017 | Home Security
What is the best lock system for home safes?
There are three kinds of locking mechanisms used for home safes,
1. Lock and key system
2. Pass code system
3. Fingerprint system
The safes with above mechanism and also fireproof is an added advantage. You may check online for price comparison also.
Visit Fire Cabinets Direct to find the best safes for your home.
Sep 15, 2016 | Home Security
Tru bolt electric lock quit working with codes
Replace the batteries. May need to reprogram the code.
Aug 17, 2016 | Home Security
Can not sign in
you need to restart your computer in safe mode to delete your password and then login to create a new password contact me and i'll walk you tru it step by step hardworkingdad1914@gmail.com
Jan 17, 2014 | Computers & Internet
Lost my password
you need to restart computer in safe mode to delete your password and then log in to make a new password contact me at hardworkingdad1914@gmail.com and i'll walk you tru it step by step
Need to recover password or reset, cannot get into computer
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed http://wiki.ljackson.us/Control_Userpasswords2 if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. http://download.cnet.com/lazesoft-recover-my-password/3000-18501_4-10973339.html Lazesoft Recover My Password Home Edition is a very easy to use Windows password recovery freeware
http://download.cnet.com/password-cracker/3000-2092_4-10226556.html password cracker free
Feb 18, 2013 | Acer eMachines Black EL1850G-42w Desktop...
Reset password on emachine 355
If you have forgotten your password if you have another user account with administrative privileges you can log into that account and change your original user accounts password from the User Accounts applet in Control Panel.
If you dont have another account like this set up or dont have the password to it you will need to log into the built-in Administrator account.
In XP Home boot the computer into Safe Mode.
Do this by repeatedly tapping the F8 key as the computer is starting up.
This will get you to the right menu
Navigate using your Up arrow key the mouse will not work here
Once in Safe Mode you will see the normally hidden Administrator account
The default password is a blank
In XP Pro you do not need to go into Safe Mode
At the Welcome Screen do Ctrl-Alt-Del twice to get the classic Windows logon box.
Type in "Administrator" and whatever password you assigned when you set up Windows.
If you reset the built-in Administrator accounts password in Home or have Pro and dont remember the password there are ways to change the password for that account to a blank
hope this helps
Jun 25, 2012 | eMachines T3508 PC Desktop
Forgot password, window xp home edition, how to by pass
Here is a little trick to use that may or may not work:
Start the computer in safe mode and log on as administrator. It's surprising how many people set up their XP computers and password protect their profile, but forget to password protect the administrator account. Once in, you can change your password in your own account.
Feb 01, 2010 | Microsoft Windows XP Home Edition
I need to bypass the login password. I was given a computer and the previous owner forgot his password.
try starting in the safe mode...press f3 maybe f8 follow the screen to see what it says to boot in the safe mode.... once the you may be able to change the password.. you may have re install
Dec 12, 2009 | Microsoft Windows XP Home Edition
Home Security Logo
517 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
