Question about Hotpoint Aquarius WMA42 Front Load Washer
Where's the filter?
I have the WMA33 Aquarius and was wondering if the models are the same in design, and if the filter would be in the same position?
  • Tony9r Aug 31, 2007
    Many thank's for your reply & help!
  • Jagilkat Dec 16, 2007
    Is there a filter that needs cleaning on the hotpoint aquarius? Mine isnt spinning too well and now there is water on the floor i think from the right as you are looking at it (hard to tell)
    I have taken the bottom cover off but cant see anything easily removable and no key came with the machine.
    Thank you
    Novelist:
    Champion:
  • 244 Answers
All hotpoints are the same only filter that they have is uneath in the pipe that comes out from the middle of the outer drum undo clip having a tub to catch any water that comes out tip the pipe up and pull clear plastic filter out the only one that there is m8
Posted on Aug 29, 2007
I have a tumble dryer Condensed Hotpoint Aquarius tcm570. The empty water indicator is on. I have cleared the,filters and no water was in tank. I have noticed it is taking longer to try clothes and the...
Dryer need to be clean out .
all area of lint screen down to were are comes out or fan may be blowing stripped blade on motor.
Need whole model # of dryer to quote you parts cost
Mar 01, 2015 | Hotpoint Dryers
Where is filter on my hotpoint aquarius wmf540 washing machine, im getting white fluff over all my clothes everytime i put a wash on, im guessing the filter needs cleaning and just wondered where it is
http://laundry.manualsonline.com/manuals/mfg/hotpoint/wma58_wma56_wma54_wma52_wma50_wmm59_wmm53.html?idRes=599752
see last page.
also, you should try run a cycle without any clothes (add a bit of bleach) in it in cold water for once to rinse out the dirt.
Oct 02, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Where do I find the filter on my Hotpoint Aquarius WM22? Or does it not have one?
Both the Hotpoint WD63 (wash dryer) and the Hotpoint WM22 (washing machine) have a drain filter in the sump hose at the bottom of the tank.
This filter is a last line protection for the pump and is not designed to be cleaned on regular intervals by the user.
Jan 31, 2011 | Hotpoint Aquarius WD63 Front Load...
My machine won't spin. The belt is OK. Any ideas? Brushes possibly? Thanks, Ian
Could be brushes, only way to be certain is to remove motor and check them for wear.
Replace if less than 4 or 5mm long.
Could also be blocked pump filter.
To check , remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Dec 23, 2010 | Hotpoint WMA33 Front Load Washer
Washing machine wont spin
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our sitehttp://www.apart4u.co.uk
This first video shows you how to diagnose the problem
utube.png You-Tube video "kG5HWQ0x2s0" placeholder (do not delete) utube.png
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Apr 28, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Variable temp control how does it work
It allows you to select any wash you like, and set the temperature as you require it, thus giving you much more flexibility over the programmes.
Do not use it at 95 for all your washing, as it will cause problems with clothes shrinkind, and colours running.
Check the washcare labels on clothing before selecting the correct temperature, you can always go lower than the recommended temperature, but do not set it higher than it is supposed to be.
Mar 30, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WMA33 washer - door won't open
Problem seems to have corrected itself! I tried another slow spin cycle, waited a reasonable interval for the Door Locked light to go off, then when it didn't I switched the power to the machine off. I tried squeezing the door catch a few times and pressing the door downwards, then left it. Some time later when I went into the kitchen the door was open. I washed a small load this morning and the machine worked normally. Fingers crossed, it's ok now.
Oct 07, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Invalid friend needs User Manual for his Hotpoint 1300 Aquarius Extra WMA33. Can you please help>
Hello.I can help with your request.
In the browser bar type in-
hotpoint user manuals
In the drop down list on the left click on
manuals-user guides-handbooks-hotpoint service
In the search box, enter the model number of washer, and down load the instructions.
Please leave a fixya rating for my solution .
Thankyou.
Jan 30, 2009 | Washing Machines
Wma42
This usually indicates that the sensor which determines that the door is shut properly could be faulty.
My WMA33 does this occasionally. I manually push the door in and up slightly with my knee - and then start the wash cycle. This seems to work every time.
Failing that you will need to replace the door sensor. A call to hotpoint may help.
Jul 04, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
363 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
