Question about Freezers
How do i add freon to my avanti chest freezer model cf97
2 Suggested Answers
  • 4 Answers
SOURCE: Avanti chest freezer cf199 will not freeze. A
Sounds like your freezer has lost its charge of refrigerant. That motor sound is the compressor. And the internal thermal overload is tripping it out every minute because refrigerant also cools the compressor motor. Have a licensed repairman find the leak, seal it,and recharge it with R134a refrigerant.
Posted on Jan 07, 2010
My Avanti CF142 chest freezer won't work on normal setting. It will work on Quick freeze so I know the compressor is good. Any ideas why it won't work on normal setting. The green light won&
Sounds like your control switch is going bad. Good thing you have the quick freeze button. You may want to go ahead and replace it. The whole thing will go out soon. This is something you can replace yourself.
Jan 27, 2013 | Avanti 5.3 cu. ft. / 150 liter Chest...
Magic Chief Freezer MCCF7W power light is flickering, but no problems with temperature
Most likely loose connections at the light. Try removing and checking. Usually can pry loose with a flatblade screwdriver.
Oct 15, 2011 | Avanti 5.3 cu. ft. / 150 liter Chest...
Why dose the freeze only freeze around the top and not the bottom
Hi, Please check your fan for malfunction. Set the thermostat a little bit colder and observe your freezer.
Nov 05, 2010 | Avanti 3.4 cu. ft. / 96 liter Chest...
How do i add freon to system
Get a saddle valve like THIS ONE. Sand down the suction line or compressor ear and attach the valve. Connect hoses to the valve and add some freon. The low side pressure should be around
5 PSI.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 30, 2010 | Magic Chef Chest Freezer MCCF5WBX
Nov 19, 2009 | Avanti 7.1 cu. ft. / 201 liter Chest...
Stop no work
If your freezer is not running at all you will need to change the temp control.If it is running and no freezing then you may have a seal system leak.
May 19, 2009 | Avanti 2.2 cu. ft. / 62 liter Chest...
Frigidaire Chest Freezer Model LffC1466DW4. Inside coils are frozen and copper pipes underneath are frozen. I have let set unplugged for 2 days and tried again. Ice forms within a few hours. How do you...
you dont want to add any more freon to it to start with
it either has to much in it or the thermostat is not turning it off and making it run to long, you need to see what temperature you are getting in the freezer and what suction pressure the unit is running on to determine if it is over charged
Apr 29, 2009 | Frigidaire Freezers
UNIT NOT COOLING(IS RUNNING WHEN PLUGGED)
only reason refrigerent may be needed is that there is a leak so adding more will achieve nothing. unlikely to be needed. i assume compressor is running. probable causes of no cooling are compressor fault or a blockage in the pipe sysyem. not diy
Jun 30, 2007 | Avanti 1.4 cu. ft. Chest Freezer...
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
