SOURCE: craftsman 15.5hp 42'' changed hydrostatic fluid
Purge the transaxle by pulling the freewheel lever at the back of the transaxle.With the lever in the freewheel position run the engine full speed with clutch out,work the forward/reverse control back and forth 10 times and then try it.Also make sure that if you had the wheels of that you didn't lose a wheel key.
Testimonial: "Tried what you said now at least the wheels do turn a little. Gonna let it sit and see if i can purge it some more."
SOURCE: How do you replace drive belt on a hydrostatic
Its not a hard job just push in clutch and lock it, remove mower belt then replace drive belt and then put mower belt back on and release clutch.
