Question about SI-TEX Boating
Si-Tex HH-150 Where can I purchase a batterie pack for this Radio, it works very while plug in but the batteries do not respond any more
SOURCE: supersonic SC-299TDVD
Battery back needs to be connected to the DVD player when charging. connect the batter pack to player. Run the DC/out from the battery pack to the DC/in in the player. plug the charger into the wall.
if that does not work, you have a bad battery
Posted on Jan 20, 2008
SOURCE: SI-TEX MAX 10 NT
Do you still have this unit around? Can I have it?
Posted on Sep 08, 2008
Editor925
  • 285 Answers
SOURCE: Lowrance LMS522c transducer
Probably not. Usually the transducer is made specifically for the head unit it is designed for. More often than not, transducers are not interchangeable, particularly across brands. Also, for best results, you really want to install the transducer that came with your new lowrance. That will give you the best results and sonar clarity.
Hope that helps!
Please rate my solution on FixYa!
Posted on Mar 29, 2009
eradiostore
  • 1654 Answers
SOURCE: How to charge battery in Motorola Talkabout Distance DPS
You can obtain a wall adapter style charger for your radio at your local Motorola dealer, or online at http://www.eradiostore.com/cart/index.php?target=products&mode=search&subcats=Y&type=extended&avail=Y&pshort=Y&pfull=Y&pname=Y&epcode=Y&q=htn8232
Sidenote: The rechargeable battery is good for about 2 to 3 years. You can tell the age of your battery by looking at the date code on the back of the battery above the stop sign. The first number is the year, the next two numbers are the week of the year. 915 would be 2009 the 15th week. (Or if very old it could be 1999 the 15th week.) A good battery, when charged will go an 8-10 hour day.
Keep both of your charge trays, replacements for these are no longer available.
Posted on Apr 12, 2009
SOURCE: Yaesu VX-3R ham radio will not turn ON!!!!
Even though this is several months old, I thought I would post this reply. I had the same problem when I ran the battery completly down. The charge light didn't come on and the unit would not turn on with the power or battery. Sent the unit back to Yaesu for warranty work and they replaced the switch board. Unfortunately after I got it back and ran the battery down again..... Well, it's back at Yaesu AGAIN! Looks to me like there could be a problem with the power circuit being overloaded when it tries to charge the flat battery!!
Nice little rig, but it may be for sale once I get it back!!
Posted on Nov 20, 2009
I need new batteries
There are a lot of battery specialty stores on the web. Search battery's and you'll find them. You will need to know the type of battery you need. Go to a website and enter the battery type. Shop a few stores at least as the prices will vary quite a bit. Heres a couple for you. BATTERYMART.COM, BATTERIESANDBUTTER.COM, UPSTART BATTERY and BATTERIES AMERICA for hard to find radio batteries.
Sep 04, 2014 | Radio Communications
Have pair of FRS14ND radios, with charger. One battery pack has quit, so other must be about to. Tried switching remaining pack between radios & both work, so it's not radio. Can't get AAA alkaline...
Similar problem, solved when dirty contacts were cleaned, look for some corrosion on either the battery pack or in the radio battery holder. Use very fine grit sand paper.
also check to see if a tab on the battery holder contact is bent inward (radio dropped perhaps)
Jan 08, 2011 | Columbia Telecommunications Group...
Uniden BC70XLT - Steady tone on power on
must be dead i have one works fine with wall pack
Jun 29, 2009 | Radio Communications
Apr 12, 2009 | Motorola Talkabout Distance DPS (10...
Freeplay S360 Need Replacement Battery Pack
I will give my info here and say that I -was- able to replace the battery in my Freeplay S360. I purchased two of the 2/3 AA rechargable NiCD batteries and soldered them together. Then I rewired it into the radio and voila! It works! Total cost: about US $4 Total time: about 20 minutes Now all I need to do is remember to use the thing every month or so, just to keep the battery in good condition.
Jan 05, 2009 | Freeplay Energy S360 AM/FM/SW/DAB Radio
Battery pack
According to Venturers website, they do not offer battery packs or anything like that.
Also i don't think there are compatible third party battery packs available...
Mar 29, 2008 | Venturer PVS62911 Car Video Player
Receing and transmiting
Hello TSAworker,
I would definitely recommend against leaving the radio turned on while it is sitting in the charger. This can damage the radio and it can also contribute to decreasing the lifetime of the battery pack as well.
Whether or not the problems you are experiencing are related to leaving the radio turned on while it is charging is hard to say. I would recommend that you start by swapping the battery from the working radio into the non working one. If the problem is the battery, this should allow you to determine that and you can just simply get a replacement battery pack.
If the battery isn't the problem then the radio probably has a hardware problem that would require service. Given how affordable these kinds of two-way radios are, you are probably going to be better off just purchasing a replacement at that point.
Best Regards
Ken
Go Ahead. Use Us.
Mar 03, 2008 | Motorola Talkabout SX700 2-Way Radio
Will not work on battery
UNPLUG THE RADIO !!!!!!!!!
Try removing the battery cover and remove and disconnect the battery.
Reconnect the battery and replace the battery cover.
Now, plug the radio into the wall electrical outlet and wait, the blue light on the radio top should start flash and will flash for about 10 minutes and then stop flashing.
Leave the radio plugged in for about 16 to 24 hours to completely charge the battery. For the first three or four times, completely drain the battery and completely recharge for 16 to 24 hours, this will condition the battery .... mine works like a dream. GR
Feb 16, 2008 | Teac R1 FM/AM Radio
FRS-14ND 2 way radio
Hello you can recharge the batteries only if the bateries you are using are rechargables, this could be Bat recharg. 2AA or 3AA or a pack.
Oct 01, 2007 | Columbia Telecommunications Group...
Boating Logo
179 people viewed this question
Top SI-TEX Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a SI-TEX Boating Expert? Answer questions, earn points and help others
