All lights flash after starting programme and dryer stops. Turn off and leave and fault returns after 2-3 mins of running.
SOURCE: Kenmore Oasis Dryer Model 7704 F 2 Error
after haveing read through some blogs here, the F02 code is either a short in the interface board or the ribbon is loose. I'm having a similiar problem, mine started beeping all by itself, when it was not even turned on, am presently running a load through and is doing fine so far, also, I had unplugged the dryer last night, not sure if that helped but so far is working properly, other advise I read was to make sure the ribbon was seated properly, next step for me will be to do that then order the part (?), sorry I can't be more helpful
SOURCE: Hoover washer Time 1600 H160E UK stops mid cycle with flashing lights
REPLACE TIMER OR POWER CONTROL BOARD
SOURCE: Indesit WIDL 102
almost certainly a new module and eprom. these modules have given a lot of problems.
not really worth doing
SOURCE: Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
SOURCE: Zanussi zdc46130w Fault.
I think you should read the instruction manual . 3 beeps means some information to begin a solutin.
