Diplomat apm 8552 washing machine manual
My grandparents recently moved into a house where it as an integrated diplomat apm 8552 washing machine however there is no manual. Does anybody have one please?
4 Suggested Answers
  • 1462 Answers
SOURCE: Diplomat washer drier
all you have to do is:
select half load
set drier timer to required time. set main timer to dry program
i suspect you are not pressing half load button - this is essential
Posted on Jul 20, 2008
blueextc3221
  • 15935 Answers
SOURCE: user manual for diplomat washing machine
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
  • 6277 Answers
SOURCE: Looking for an instruction manual for a HJA8513
Sorry but FixYa cannot do that direct- members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Aug 18, 2011
Diplomat washing machine
Try Sliding the Soap Dispenser Drawer Lock to the RIGHT and then pull straight back... It is located under the handle
Mar 03, 2014 | Washing Machines
I have moved into a property that has a diplomat cooker. I am looking for instruction booklet for it can you help
Diplomat are no longer trading. These appliances where fitted with MFI kitchens who have also gone
Oct 19, 2009 | Ovens
Diplomat dishwasher bleeping showing FA
We have just experienced an FA audible error on our Diplomat ADP 8332 dishwasher...after pulling the dishwasher out and removing the low front panel we found the drip tray full of water. We tipped the dishwasher onto it's front and removed the drip tray and found a float pressure switch...it appears that once the drip tray is full the float switch activates and causes the FA fault (prevents the dishwasher from continuing) drain off your drip tray replace all covers and you should be good to go!!
Sep 16, 2009 | Dishwashers
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
Faulty Diplomat Dishwasher - tripping mains fuse
My dishwasher a diplomat 12 program (hja8640) was doing exactly the same where every now and again when turned on at the plug it would trip. After engineers coming out several times and failing to fix it, they condemed it. New one was supplied, however did exactly the same thing. The electrician came back, checked the RCD power breaker and this was fine. It was then discovered that some dishwashers and washing machines send out a lot of earth leakage, combine this with other appliances on in the house can be enough to trip.
Soloution. The electrician removed the kitchen circut from the RCD breaker and intalled another breaker RCD just for the kitcehn loop, this therefore means that the kitchen has a seperate trip from the rest of the house, and touch wood, has solved the problem. This mind you has taken about three months to work out so i hope it saves you some time.
Always use a fully qualified electrician though.
Thanks.
Oct 21, 2008 | Dishwashers
select half load
Jul 20, 2008 | Washing Machines
I have a Diplomat APM 8702 integrated washer / dryer, it has decided to stop working! its been great but does get used alot, the electrics come on, ive checked all the connections inside the machine made...
I have one of these machines. I don't know whether this will be of any help but I had issues of the machine not activating a final spin and the clothes being left sodden once the cycle had finished. The engineer replaced the PCB module at the rear of the unit which fixed the problem. If your APM 8702 is not even starting I'd guess its a motor problem and time for an expensive repair or new washing machine.
Apr 26, 2008 | Washing Machines
Washing Machines Logo
161 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
