Question about Measuring Tools & Sensors
Hilti pd30 display screen is locked - Measuring Tools & Sensors
2 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: hi i have a hilti PD30
OK if the model number is PD30 go to Hilti.com and type in your model and it will direct you downloads on the right hand side of page go there and under user/owners manual you can download a copy or read it online for this tool. If you need any further help let me know. Also if you are located in the US you can call their toll free number and get tech at 1-800-879-8000. I deal with them all the time and they are extremely helpful.
Posted on Jan 13, 2009
Hilti Pd 38 starts with an E 189
us.hilti.com/HiltiTools
Jun 11, 2014 | Hilti Pd32
I have a te 500 it not knocking at full strength
A Broken front ring which blocks the lock bolt ?
Is there enough lubrication flow if something is broken inside replace ALLWAYS a complete servicekit , because its , beware of the Turmopol oil is expensive. there are equivalent oils if you asked special for it also by Hilti to buy.
Hilti and Duss are not the 2 cheapest brands of powertools.
Special Tolerance-free bearings are used it is all super calculated on a number of operating hours and about if something is defective, a complete overhaul is necessary.
These hammers may leak no trace of oil in the front until 2006 HILTI has in my Country support , but after this date
exclusively support to the end-users and support closed for brokering.
Feb 15, 2014 | Hilti 120-Volt SDS Max Demolition Hammer...
Hilti pd 30/hilti pd 40
If anyone know I need one too for my pd 32
Jul 02, 2013 | Hilti Drills
How to Replace Hilti TE22 chuck
You put the two flat sides on the end of the cap nut and lock them in a vice. You then put a wrench on the back side of the chuck which also has two flat sides. with the cap nut locked in a vise take the wrench and turn the retaining sleeve which has the two flat sides counterclockwise to break the cap nut loose. When it turns freely take the chuck out of the vise and turn the cap nut off. You then push the ribbed locking sleeve down to access an o-ring. You pull that off and it releases the locking sleeve and two roller bearings. You then pull off the retaining slv with the two flat sides and release the other two roller bearings. the chuck will then just pull off the shaft
Hope this helps
Sep 30, 2012 | Hilti TE 7-C 120V Rotary Hammer Drill
GUIDE D UTULUSATION PD30
Tiens, mais c'est en englais
ou bien ici pour la version francisee
Aug 09, 2012 | Hilti 202415 PD 4 Laser Range Meter
Hilti chuck won't turn
inside the chuck you will see a screw, remove the screw and chuck . A small punch with minimum forced with a small hammer to move the chuck dogs toward the end on the chuck . The chuck was opened to far and is a mechanical bind ..
Jun 30, 2012 | Hilti SFH 18A CPC Hammer DrillDriver
How do i remove the chuck on a hilti dd100 core drill i was told you just knock out the pin but it dosnt seem to budge and its starting to get butchered
go to Hilti.com and type in your model number for an owners manual on this tool. It looks like it has a locking mechanism that you just need to pull back. Let me know if you can't find it and I will get more specific info, or you can call them at 1-800-879-8000 and speak with tech services for this
Oct 01, 2009 | Hilti Drills
Hi i have a hilti PD30
Jan 06, 2009 | Hilti 377374 PML32 Line Laser
Hilti PD30 Laser distance meter
shut the unit off by using the power button then turn it back on holding down the power button unitl the menu is displayed allowing you to turn the beep on/off with the + key and change the units with the - key
Oct 14, 2007 | Optics
Measuring Tools & Sensors Logo
81 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
