Samsung swa-6000 I tried everything the 0135 code and I'd set pressed for 5 seconds nothing the blue led light keeps blinking just bought it new need help
5 Suggested Answers
SOURCE: Samsung SWA-4000 Wireless connection problem - Not connecting with main unit
I have had the same problem with the wireless unit and thought the same, it didn't work. The way to fix this is simple. You need to do the 0, 1, 3, 5 on the remote and turn on the home theatre system on the main switch on the front panel (as I was doing this on the remote, and it was failing). The blue light should then stay illuminated. If not just switch the main on/off button again, and it shoud work.
Posted on Nov 09, 2008
  • 4234 Answers
SOURCE: Onkyo TX-SR575 I
The unit is in protect mode. The outputs are fried in all likelyhood. This can be repaired. Figure on $5-$15 for parts plus the local labor rate for the total repair cost.
Dan
Posted on May 21, 2008
SOURCE: problem with wireless conection between Samsung SWA-4000 and Samsung home theatre.
turn the main dvd player off, and press 0,1,3,5 on your remote, then turn on the player and the rear wireless receiver at as close to the same time as you can. should then light up the blue "link" light permanently.
Posted on Nov 22, 2008
SOURCE: goes to standby with fast blinking red light after 5 seconds
From my experience you need to replace the Hi power module
Posted on Sep 26, 2009
Cannot program new garage code
You are missing a step. It sounds like you have a genie intellicode black wireless keyless entry unit. The final step is to program to the opener. When you open halfway and press the prog and 8 keys, youve unlearned the unit from the opener. Lets start over. Complete the previous steps and then finally, press the code or learn button on the opener. There is a red LED light next to it which will flash after pressing it. Within 30 seconds, type your new code and press the up/down or enter button on the keypad. Then press the up/down or enter button a second time. Programming is complete!
Apr 22, 2014 | Building Materials
Need code for my oneforall URC-7140 for my Echostar HDS-600RS
If none of these work 0853 0396 0713 1323 1409 1413 try this,
The Search Method allows you to find the code for your device by scanning through all the
codes contained in the memory of the ONE FOR ALL. The Search Method may also work if
your brand is not listed at all.
Example: To search for your TV code: Switch on television (not on standby) and aim
your ONE FOR ALL at your TV.
1. Press and hold MAGIC for 3 seconds until the blue LED (any LED) stays on.
2. Select the corresponding device e.g. TV
3. Press 9 9 1. The blue LED will blink twice (showed by going out twice).
4. Next, press POWER.
5. Press CH+ (over and over) again until your device switches OFF.
6. As soon as your television turns off, press the magic key to store the code.
Congratulations! You should now be able to switch your device back ON and
control your device successfully.
In this example we will set Volume Control (VOL+, VOL- and Mute) to "TV
volume":
2. Press 9 9 3. The blue LED will blink twice.
3. Select the corresponding device e.g. TV.
4. Press and hold the magic key for 3 sec. The blue LED will blink twice and then
Switch off.
Now you have set the Volume Control to "TV volume". The VOL+, VOL- and
Mute keys will always control "TV volume" independent which device mode
key (TV, SAT, DVD or AMP) is selected.
WWW.ONEFORALL.COM 9
OFF
SSAAT/CBL T/CBL
This feature gives you the possibility to
set the Volume (VOL+, VOL- and Mute)
to always control a certain device (e.g.
TV) independent of which device mode
e.g.: Control your TV Volume in SAT
mode.
How to deactivate Volume Control
1) Press and hold MAGIC for 3 seconds until the blue LED stays on.
2) Press 9 9 3.
3) Press Vol +. The blue LED will blink 4 times.
All devices will send out their own VOL+, VOL- and MUTE.
How to remove a device from Volume Control
2) Press 9 9 3.
3) Select the device mode you wish to deactivate from Volume Control.
4) Press Vol -. The blue LED will blink 4 times.
The removed device will send out its own VOL+, VOL- and MUTE.
Search Method
Volume Control
You may have to press
these keys many times
(up to 150 times) so
please be patient.
Jan 13, 2013 | Televison & Video
All I get is a blue welcome screen on my Mitsu WD-65C9 DLP TV. After several seconds of blue screen, it always just shuts down. I downloaded the Mitsubishi software upgrade, but it did NOT solve...
Hi Mike,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Kind Regards,
Mjsazon
Nov 25, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
Hi, i have recently borrowed a magnavox tv from my uncle. he lost the remote and the one for all remote i have is apparently old. the # is URC 3220. I was wondering if you could help me with receiving the...
There are 5 different codes for Magnavox.
0054, 0706, 0030, 1454, 1254.
If you need instructions, here they are. Press and releaseTV. Press and hold SET until the LED blinks twice. (the first blink doesn't count. wait a few seconds) Release the SET button, and enter one of the 4 digit code. The LED should blink twice again. Aim the remote at your TV and press POWER. Keep trying until you find the right code.
Aug 16, 2011 | Philips Magnavox Learning Universal Remote
I NEED T.V CODES FOR A ADMIRAL T.V AND NEED STEPS ON HOW TO SET UP CODE FOR A INNOVAGE REMOTE
Hello
Code for Admiral TV with Innovage remote control are:
001,173
CODE INPUT SETTING:
You will need the list of codes to manually select and input the correct codes to your
specific device.
1. Turn on the device that you want to set.
2. Look for the brand name under the specific device listing provided.
3. Aim the remote control at the device and press down and hold CODE SEARCH button for
at least 3 seconds until the red LED lights up solid red.
4. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
LED light will blink once and then remain solid red.
5. Using the number keys, enter the 1 st set of 3-digit codes from the list. You will notice
that each number that you press, the LED will blink once. After you have entered the
3rd digit, the red LED will turn off indicating that the code was recognized for the device.
(NOTE: If the code entered was not compatible, the red LED will flash several times.
You will then need to repeat Step 3. You have 30 seconds to enter a code.)
6. After the red LED light has turned off. Press the ON/OFF key. If the device you are trying
to program powers off, then you have found the correct code. If the device does not
power off, then you will need to repeat the process again from Step 3, using another
3-digit code.
7. Make a note of the 3-digit code for future use.
CODE SEARCH SETTING:
This is an alternative method to programming your device without using the code list. The
remote control will scroll through the list of codes to identify the correct code for your
device.
2. Aim the remote control at the device and press and hold down the CODE SEARCH button
for at least 3 seconds until the red LED lights up solid red.
3. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
4. Press ON/OFF button on remote slowly and repeatedly until the device you are trying to
program shuts off. (Note LED will blink once each time you press ON/OFF button)
5. Once this occurs, press ENTER button to store the code and the LED light will turn off
Mar 27, 2011 | Innovage Jumbo Remote Control
Hi need code for ancient centrex tv for universal remote help aaaaaaaaaah
Hello
Centrex is not listed with URC04110 universal remote coldes. But you can search and find the code for your device with this remote control. I'm not sure will it work with your old Centrex TV. Anyway try. Wish you the best.
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all
codes listed for your brand, or if your brand is not listed at all, try
searching for your code. For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED blinks twice, then release
SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns
off.
NOTE: In the search mode, the remote control will send IR codes
from its library to the selected device, starting with the most popular
code first.
5. To lock in the code, press and hold SET until the LED blinks
twice, then release SET.
6. To search for the codes of your other devices, repeat steps 1 through
5, but substitute the appropriate device key for the device you are
searching for.
CHECKING THE CODES
If you have set up the remote control using the Searching For Your Code
procedure, youmay need to find out which four-digit code is operating
your equipment:
For example, to find out which code is operating your TV:
SET.
3. Enter 9 - 9 - 0.The LED will blink twice.
4. To view the code for the first digit, press 1 once.Wait 3 seconds,
count the LED blinks (e.g., 3 blinks = 3) and write down the number.
NOTE: If a code digit is "0", the LED will not blink.
5. Repeat step 4 threemore times for remaining digits.Use 2 for the
second digit, 3 for the third digit, and 4 for the fourth digit.
6. To check for codes of other devices, repeat steps 1 through 5, but
substitute the appropriate device key for each device you are checking.
OK.
Mar 08, 2011 | One For All URC4110 Remote Control
I had a problem getting the code,to work with tvsignature2000,can you e-mail me the code for this,
Actually there is no code specified in URC-3021 manual to work with Signature.
But still we can try
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH up, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
1 through 5, but substitute the appropriate device key for
the device you are searching for.
If you have set up the remote control using the Searching For Your Code procedure
as above, you may need to find out which four-digit code is operating
your equipment. For example, to find out which code is operating your
TV:
then release SET.
seconds, count the LED blinks (e.g., three blinks = 3) and
write down the number in the leftmost box in the TV
code boxes on page 8.
5. Repeat step 4 (on the previous page) three more times for
remaining digits.Use 2 for the second digit, 3 for the third
digit, and 4 for the fourth digit.Write down the code digits
in the remaining TV code boxes on page 8.
through 5
Feb 17, 2011 | One For All URC-3021 Remote Control
I need codes
Codes for direct TV are 200,201,202,203,204,205,206,207,208,209,210,211,212,213,214,215,216,217, CODE INPUT SETTING:
specific device.
(Note: You will notice that some brands will have more than one 3-digit code. During the
code input process, you may have to try more than one 3-digit code that will match your
device brand and model.)
3-digit code.
device.
5. Once this occurs, press ENTER button to store the code and the LED light will turn off I hope this information helps you with you remote controls problem. Thank you for using FixYa and have a nice day!
May 31, 2009 | RCA DIRECTV Satellite Remote Control
I NEED THE CODE FOR ALBA TV MODEL NO. ALCD15TV8M
There are two code types for sky remotes, Brand Codes & Direct Codes.
The codes for Alba are:
Brand - 0043
Direct - 037, 065, 246, 399, 263, 064, 446
There is a small difference in the way they are set.
To program using the 3 digit code - Direct Code
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Enter the 3 digit code
5) Press the select button to store
Press TV and any number to test, If this does not operate the TV set try below.
To program using the 4 digit code - Brand Code
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Feb 18, 2008 | Televison & Video
Bad picture color. red LED blinks 5 times. Replace picture tube?
Definitely bad picture tube==not worth fixing......T.
Oct 11, 2007 | Sony KV-36FS16 36" TV
2,672 people viewed this question
 Grubhead
Grubhead
