Question about Dryers
Cissel dryer f55 - Dryers
Have a cissell 170lb dryer it will ignite than flame will go out
Most likely problem with ignitor. You can try cleaning the ignitor. One reason I can think of is that the feedback from the ignitor circuit is not working. What usually happen is that when the flame have started. The ignitor will generate a small current to tell the ignitor control board that there is a presence of flame. If the small current feedback is not detected. the system will automatically shut off the gas for safety reason. You probably tried stopping and restarting and the same condition will occur.
Jan 28, 2013 | Cissell Parts Cissell H87533014 Dryer...
I need a service manual for a Cissell Comercial Dryer model HD50G1
hi .my hd50g1 wont light up . we had a problem with the motor and had that rewound, now it wont ignite....it starts spinning and everything except no gas flow or ignition.
Oct 21, 2010 | Dryers
Where can i download for free a Nikon F55 user manual
You can find the manual for the Nikon N55 at http://www.butkus.org/chinon/nikon.htm
The N55 and the F55 are the same camera; the N55 name was used in North America and the F55 name in the rest of the world.
Jan 24, 2010 | Nikon Cameras
Cissell Dryer Model HD30ST gives an error code P-F. I would like to know what this means.
I had the same problem with our Cissell L125URDG with the error code P-F. Found out it means Plug #4 on our wiring shematic. On this plug there are several sensors connected to this plug: highlimit switch, air switch, thermistor, door switch, and a bonnet thermostat. So, it is probably one these switches that is given this error code P-F.
Aug 30, 2008 | Dryers
ACDSEE with F55 ??
Unfortunately you can't use ACDSee to access your images on the F55. Not unless Sony comes up with a twain driver which seems unlikely. I have to use Picture gear to access the images and transfer them to my PC which I then use ACDSee to view. I also got a floppy adapter.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Batteries for Sony DSC-F55 or DSC-F505?
No, those are 'M' series batterys and the F55 and F505 take 'S' series batterys.
Sep 08, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Sep 08, 2005 | Sony Cyber-Shot DSC-F505 Digital Camera
Adding zoom lens to F55?
Zoom can be added to the F55 by instead purchasing the F505..
Dryers Logo
53 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
