Question about Canon SELPHY ES2 Printer
Canon selphy es2 printing a horizontal line through my picture
jackboy
  • 2985 Answers
SOURCE: Cannot print from my PC
totally unload the driver and software. Then go to printer/faxes - install new printer and when the new hardware prompt comes up - ignore the CD prompt and select from list instead. select Canon select Model- then try come back with the result.
Posted on Sep 18, 2007
SOURCE: CANON SELPHY DS810 PRINTER PROBLEM
i am having problems changing catridge,help
Posted on May 04, 2009
Devsta
  • 68 Answers
SOURCE: Canon Pixma MP130 printing lines through pictures etc
I'd say it's probably the printer driver. Uninstal and reinstal it or update it. Printer drivers are a comon cause of printing faults.
Posted on Aug 16, 2009
  • 62 Answers
SOURCE: Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Posted on Feb 13, 2010
Douw
  • 91 Answers
SOURCE: canon Pixma IP4200 started printing regular
Hello first of all are you technical
I have taken the printer head out
boil some water and pour in a cup
take off the 2 screws at the bottom
gentley open the head from the casing**** note if you not gentley it wil brake and U can through the hole head away
then let the white block lie in in the water until the water is cold the trough that out and repeat this step.Boil water again....Wait for 4 to 5 minutes to pass..... then use high copressed air and blow from the underneth so that the presure will force the **** out on the white block side also force some hot water from the litle sifes at the top down and make sure that holes are open
replace the ruber perfectley and the head pease an make sure every thing is propeley dry.Replase the scews .and put it back in the printer.Remember it is also a very filthey and inkey job.Good luck
Posted on Feb 15, 2010
Only half of the picture prints on my selphy cp 730 canon printer
Nov 01, 2014 | Canon SELPHY CP730 Thermal Photo Printer
Cp810 problem white line pictures
I am having the same issue with my cp910 and i believe it is caused by dust inside that for whatever reason is not coming out when running multiple prints to try and clear it. I have looked up a couple of videos to help me take apart mine but the cp910 seams to have a security screw in one of the corners but i think you'll find that yours does not and you should be able to take it apart fairly easily to give it a clean and that should hopefully sort your problem :)
Jan 09, 2014 | Canon SELPHY Office Equipment & Supplies
Cartridge error message
Please tell about your Cartridge Message.
Or Other Wise Contact Canon Email to Your Problem.
They solve your problem.
May 13, 2013 | Canon SELPHY ES2 Printer
Iv changed my ink cartridge and now it wont print it keeps saying ink cartridge has been changed
I just got mine working again. Solution: You have to disassemble your Printer. Take a close look at the small round motor inside. Their is a small toothed wheel attached to the shaft of the motor - mine was already lying inside the printer. This wheel hast to be replaced by a tighter fitting one or the original one has to be fixed to the shaft - I used glue, as i had no new wheel.
May 10, 2012 | Canon SELPHY ES2 Printer
Cannon selphy es2 - how do i remove old cartridge?
you can remove the old ink cartridge from the Canon selphy es2 by simply lifting the small green lever on the ink cartridge carrier. Take note of how the cartridge was situated in the carrier, then gently take the old cartridge out of the printer.
Jan 18, 2010 | Canon Office Equipment & Supplies
Es2 won't print. printer display reads; "cartridge has been changed" its a new cartridge
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Dec 16, 2009 | Canon SELPHY ES2 Printer
How do I print borderless pictures on my Selphy DS810?
You print borderless by choosing that option in the print software, after choosing print, you go into printing preferences and choose borderless..
Aug 20, 2009 | Canon SELPHY DS810 InkJet Photo Printer
User manual required
Hi there here is the link just click it or copy and paste it to your browser http://www.generalmanual.com/Printers/Canon-SELPHY-ES2-Compact-Photo-Printer.htm
please rate me thanks have a nice day
Jan 03, 2009 | Canon SELPHY ES2 Printer
Canon SELPHY ES2 Printer Logo
26 people viewed this question
old marine
old marine
