Question about Connex 3300 240-Channels Base CB Radio
My galaxy twin turbine dx93t started just floating on freq. counter on all bands no trans no rec
2 Suggested Answers
  • 67 Answers
SOURCE: connex 3300 hp
U mean on sideband? Frequency counter only useful on other than sideband operation. This does not mean the carrier insertion osc. is on frequency. If it needs adjustment, your voice will sound high/ low on transmit. Incoming signals will sound right after adjusting the osc.
Posted on May 25, 2008
Can't get freq numbers and channel numbers to match on dx66v
so,what numbers does it show? If you are at 27.187 or 27.183 it should be no problem that little amount of frequency differance won't make any differance. Now if you were at 27.180 or 190 then you would be going into another band width.
Apr 01, 2014 | Galaxy Radios DX-66V Base CB Radio
Broken the jaw of radio galaxy 2547 dx
If you open it to much you will be going into another band but 5 k isn't to much. you may want to have someone do it for you because you will need some equipment to do it correct. A scope,freq. counter a power meter a multimeter and a function generator. It can be done by eye and listening but it is always better using technology.
May 25, 2012 | Galaxy Radios DX2547 40 Channel Base...
Galaxcy DX 66v freq counter and radio slide up and down 3-5 clicks. Not all the time. Nothing I do seems to help
set your mode for AM with frequency counter reading 26.965 mhz on band E. ( channel 1 ) Now you have to adjust VR 1 for 26.965 mhz if its not reading it already . Now set the counter and the radio to 27.405 mhz ( channel 40 ) check for 27.405 mhz . If its off by .003 to .005 thats really nothing but if its off by .3 to .5 thats when it really off frequency .
Apr 20, 2012 | Galaxy Radios DX-66V Base CB Radio
Dx-959 freq counter an channel selector don"t
Hello, please tell me what you were doing before and at the time of change. Were the digit lights recently switched? Please give me a little more information so I can be more specific in my answer. Thank you.
Mar 01, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
I need a instuction manual and freq. cheat sheet for my galaxy dx88hl.thanks Rod
To use this radio on the CB band, you set the 10 Khz switch to OFF, and then turn the band switch to A/E.
Here is a Frequency Chart.
Here is the manual.
When the 10 Khz switch is on OFF, the band switch is E,F,G,H. When the 10 Khz switch is in the ON position, then the band switch is A,B,C,D.
So when you are on band E, which is when the 10 Khz is OFF, and the band switch is in the first position, it is on the E band.
I would get your self a Frequency counter. It makes using a radio like that much easier.
Hope this helps!
Oct 11, 2010 | Galaxy Radios DX- 88HL Base CB Radio
Band selection an freq. doesnt align galaxy 33hml
sounds to me someone was tampering with it ,your best bet is to get a frequency counter and realine the radio .start from 27.185 centre band you can do this by tuning the ossolator be very careful not to damage this should realine the radio for you goodluck
Oct 16, 2009 | Galaxy Radios DX-33HML 40-Channels Base CB...
My freq counter didnt work on my galaxy dx 959 when i took it out of the box and hooked it up.. what do i do about this and is this common thanks drew
check patch lead with multimeter both centers and outers should read but inner and outer togther should not. try a power meter to make sure you are tx ing at least 1/4 of a watt. try freq counter on another rig. all rigs will run on a counter.
Apr 04, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Rolling Frequency Counter
I'm giving this info from the Master Edition of C.B. Tune-up manual Volume 1 year -1995. The original price of this info was $39.95 But I have had people help me with radio info. so here it is---- on page 60 it says [ Model ] : Galaxy Saturn ( and export models using the same Freq. counter module ) The most common problem with the { Galaxy Saturn } is after it has been on for awhile the read-out becomes unstable. And sometimes it will quit all together. This problem has been traced to a Zener Diode inside the freq, counter module. The square silver box located right behind the speaker. The Zener Diode inside marked D-603. This is a 2.4 volt , 1/4 watt diode next to IC-609 the ( LM-7808 ) regulator. REMEDY: change D-603 to a ( 2.4 volt , 1/2 watt diode) This should restore normal operation. {{{{ 357 - MAVERICK }}}
Mar 13, 2009 | Galaxy Radios DX-2517 CB Radio
Sideband freq
That is wrong , I used to have a freq. counter that only read when you applied RF to it on my old Tempo rig and I ran lower 37 and upper 35 so I would key the radio on am and tune the vfo to that frequency and would be on frequency with everone else,I remember hearing that once long ago but it's not true.
Feb 21, 2009 | Galaxy Radios DX-2547 40-Channels Base CB...
Not a Galaxy DX-2517
its a mexican kraco clone,lol
Aug 09, 2008 | Galaxy Radios DX-2517 CB Radio
Connex 3300 240-Channels Base CB Radio Logo
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Mitch Davis
Mitch Davis
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
