S3ba 030k what type of gas is used by the Frigidare S3BA030K
2 Suggested Answers
SOURCE: We have a Frigidare S3BA-036KA
I Had a similar problem with my Air Conditioning unit, the repair man said without the information their was nothing he could do, but that he would go look for it.
This is what i was able to find, This litterally all just took place within the past hour so i don't know if its workable information, but here is my two and a half cents.
http://www.transtaracsupply.com/pdf/s3ba.pdf
Posted on Aug 17, 2009
A intertherm t3qc-030k air conditioner is how many tons?
If T3QC-030K is the model number it is 2 1/2 tons.
12,000 btu = 1 ton 030 means 30,000btu
Jun 04, 2014 | Intertherm P3RA-036K Air Conditioner
I hav a miller p3rd-030k when i turn the thermostat on fan comes on but not the compressor
Could be the compressor leads burned off the terminals at the compressor, or contactor switch is bad, or capacitor is bad, or compressor locked up.If you can use a multimeter you can find the problem. If not call a service man.
Jun 04, 2014 | Intertherm P3RA-030K Air Conditioner
My frigidare gas oven wont turn on...
try changing the igniter it may have burned out or is weak
Aug 26, 2012 | Frigidare FGB24S5DC Gas Single Oven
Where do I recharge the P3RA 030K
Take the panel off where the copper lines go in. Down towards the bottom ,the copper will tie into valves. There should be caps approx. 1/2" at bottom,these are your charging ports!
Jul 20, 2011 | Intertherm P3RA-030K Air Conditioner
LOOKING FOR YEAR OF MANUFACTURE FOR MILLER MODEL P3RA-030K SERIAL P3D030400057
Your unit is April 2003. So it is 8 years old. P3D is model ref 0304 is year/month of manufactor. You also have a 2.5 ton system. Hop this helps. Info verified through local Intertherm distributor.
May 16, 2011 | Intertherm P3RA-030K Air Conditioner
Need Capacitor Size
try calling technical support of the company
Jun 04, 2009 | Intertherm P3RA-030K Air Conditioner
Changing Air Filter
In general terms an electric unit uses a 20 x 20 x 1 filter and a gas system uses a 20 x 25 x 1 filter. If the return filter is somewhere other than at the unit, it will very greatly in size. Its the descretion of the installer as to what size filter they choose to install.
Apr 07, 2009 | Intertherm P3RA-030K Air Conditioner
We have a Frigidare S3BA-036KA split condenser with a badly rusted Compressor run capacitor. What is the correct capacitor for this unit?
Aug 08, 2008 | Frigidaire Heating & Cooling
Intertherm outside unit - s3ba-036k - does not run
Measure the voltage across the line. The outside unit normally runs on 220 Volts. Measuring each side of the line to ground will give 110 Volts. If your outside disconnect is of a fused type one fuse could be blown. If a fuse is blown on one side of the line you will read zero volts differential across the line.
Check the type of fuse used in the disconnect. Make sure the proper size time delay fuse is installed on both sides of the line at the disconnect.
May 17, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
