Question about Kodak Brownie 8 Movie Projector Model 10
Frozen control switch brownie 8 movie projector
Projector not used for many years. control know is frozen. will wD-40 help? will it damage? any suggestions?
Kodak m67 8mm movie projector struck in rev lever can be move to forward but miss run backwards
it is hard to explain but there is a metal pin on one of the mechanisms it can become bent out of place. you need to remove it and heat it up and put back straight. dont try to bend it straight as it will snap or the pin will come out of the metal part.
Oct 13, 2013 | Kodak 1950s/60s Brownie 500 8mm Movie...
Projector keeps switching itself OFF
The projector is probably overheating you need to check fans and lamp inside
May 28, 2008 | Audio Players & Recorders
Control knob on kodak brownie 8 will not turn
Hi Don,
I have the same problem with my dad's Brownie 8 Model A15 projector...however, the knob will turn to "Rewind", but not to "Project". Did you ever get yours to work? Thanks! Jon
Sep 02, 2013 | Kodak Cameras
? Is the sprocket wheel in the middle of the projector supposed to move? The film seems to be locked up in there, and only the few inches of film in the gentle curve above the lens seems to feed thro
I know this post is old but I found a solution. The axle going to the sprocket is locked up with something sticky. You have take out the two screws holding the white plastic piece around the sprocket. Then loosen the small bolt on the big wheel on the other side. Remove the big wheel. Try to push the axle through to the other side. If it doesn't budge easily, hammer it out. That's what I had to do. Then clean it up real good with solvent, like alcohol. Lube it with grease and put it all back together. Worked for me.
Jul 19, 2012 | Kodak Antique Brownie 300 Movie Projector
Need relacement buld for Brownie Movie Projector Model 1, bulb 300-watt, 120-volt,T81/2. S.C. bayonet base, C-13D projection lamp
Hello
You haven't specified anything about your projector or other detalis about it. jsut get into this link, and see whether the lamp you want is available there or not. You have to search with its number. It will have a model number on it. OK
http://www.visualapex.com/accessories/lamp-projection-tv.asp?MFR=DNGO
Dec 13, 2011 | Office Equipment & Supplies
Makita 12Volt cordless drill driver - chuck is frozen
Ok glad I have helped and that WD-40 has solved the sticking chuck...
Please rate this solution on FixYa!
Mar 24, 2009 | Makita 3/8" Dr. 14.4V Cordless Drill Kit
Unable to switch off projector with remote (Infocus SP4805)
A bit unusual for the projector to stop responding to the remote. Usually it follows when someone has opened the projector, they forgot to reconnect the controls from the case top which also includes the IR receiver. If it isn't that, it could be a broken IR pc board or bad connection. I've seen that.
The worst case is that the IR controller on the main board has failed and if that's the case, you'll have to live with it as the cost of a new board is very high.
Mar 13, 2008 | InFocus ScreenPlay 4805 Multimedia...
Kodak Brownie Super 8 Projector
in slide projector smooth movement of mechanism is rule number 1 .1-spray contact lubricant cleaner on forward and backward switches and press them many times.-open it and clean it with air blower and clean piece of clothes.apply good type of light grease in levers-cams gears-confirm all mechanical parts is in good condtion.change any broken part from nearest store.
best regards
Feb 20, 2008 | Office Equipment & Supplies
Kodak Brownie 8 Movie Projector Model 10 Logo
73 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
