Question about Whynter Heating & Cooling
Repair bottom arc - 14s
Water leaks through crack in bottom
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Tub leak on a Kenmore Washing Machine Model
you could probalby get away with a marine epoxy to repair thecrack (depending on size) , althouth replacing the tub would be the best "feel safe" --- "no longer worry about possible floods". buthte cost and time to switch the puter tub is problably cheaperto buy new machine
Posted on Mar 24, 2009
heatman101
  • 43501 Answers
SOURCE: soap and water leaking at bottom of door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
ghdjkdghas
Posted on Sep 29, 2010
SOURCE: Why is or fridge leaking
I've seen this occur when the refrigerator door is getting closed fully Either a food item is preventing complete closure, (though it may look closed) or a seal is failing. Check the seals by pulling a dollar bill out from in between the seals. If it doesn't catch make sure the seals around the doors are ingood shape and clean.You can also use a heat gun to warm -up the seal and get to expand so you get a good suction
Posted on Oct 15, 2010
Why is my Frigidaire dehumidifier leaking water from the bottom of the unit?
Hi friend, thank you for your post!
I have identified that a few possibilities to why water is leaking from the bottom of your dehumidifier could be a crack inside your bucket or condensation from the bucket. I would remove your bucket and look it over to see if you can locate any visible cracks or chips. How much water is leaking from your dehumidifier? If you can provide any further information I look forward to assisting you. -Matt
Sep 03, 2014 | Dehumidifiers
Why is water leaking from back of kenmore elite refrigerator?
Also, can be a crack on the plastic hose, close to the inlet water valve.
Aug 16, 2014 | Kenmore Refrigerators
Garbage diposal leaking water
These can leak from a number of places. Check and see if the water is running down the side. If it is, check for CRACKS in the housing above the motor. Badger disposals are bad for this. Check the seal at the bottom of the sink, top of the disposal and if the water is coming out the bottom then the leak is a shaft seal inside. If the housing is cracked or the shaft seal is bad, you have to get a new one.
Jul 07, 2014 | Kitchen Appliances - Others
Water leaking from door when cold water dispenser being used
Hello Frank,
The line that runs from under the freezer door and connects to the dispenser is cracked or the connector is cracked. By removing the lower hinge cover ya should be able to see where the line connects to the door and see if it seems to be cracked and leaking their,if that connector is good then the line inside of the door is leaking..in some cases depending on brand the line is easily replacable without having to dis-assamble the entire door
GENE
Nov 11, 2011 | Refrigerators
Leaking water
Yes, Remove two screws rrom bottom of washer using puddy kinfe release the top panel bysliding in at crack between top panel and body the water pump is at the bottom left and may be leaking from hoses the other posiabilty is the selonid that controls the water inlet may be leaking
Aug 14, 2010 | Frigidaire FWSB5700DS Top Load Washer
Side by side with icemaker. leaking from bottom, but I don't know the source of the leak. is there a condensation pan on the bottom?
pull out the bottom shelf in the freezer to see if there is a sheet of ice. if there is, the drain ice iced up and will need to be defrosted with warm water. if not, then the drain pan under the fridge might have a crack in it or one of the plastic water lines could have a crack. hope this helps.
Oct 21, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a coolant leak coming from my 1988 f150. I thought it was because of a bad hose, so I replaced the hoses on the top and bottom of the radiator, but it is still dripping. It sort of looks like the...
The bottom hose goes to the water pump and I would bet your leak is coming from the water pump. The water pump leaking mean it is going bad and needs to be replaced soon. Definitely not as bad as a cracked block.
Oct 10, 2009 | 1988 Ford F 150
Water leaking out of bottom of machine overnight. Stills brews but leaking water from reseviour in back
Suspect the 'pump' tube that runs from the reservoir bottom up to the grounds basket. It may be cracked or the end clamp on the tube is weak, broken, or misplaced on the tube. Check the reservoir for a cracked base or fitting. Remove the bottom plate to get to this. (unplug the cord).
Aug 23, 2009 | KitchenAid KCM400 Coffee Maker
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
My bendix washing machine doesnt fill with water instead it leaks out the bottom. I'm not sure if a connection is loose, a hose cracked or a part missing.
Welcome bcarro10'
You said,
My Bendix washing machine doesn't fill with water instead it leaks out the bottom. I'm not sure if a connection is loose, a hose cracked or a part missing.
My name is Huuum,
I'm not sure if you search more you will, find a connection is loose, a hose cracked or a part leaking and needs replacement! As you surmised.
Or if you do not do it your self, then service will find the same!
Let me know the location of the leak when you locate it!
Cheers, and Bless You!
Please remember to leave a rating when you finish!
Thank You.Huuum
Sep 23, 2008 | Washing Machines
Heating & Cooling Logo
Top Whynter Heating & Cooling Experts
Oloyede Monsuru
Mohamed Ismail
Mohamed Ismail
gbob59
Are you a Whynter Heating and Cooling Expert? Answer questions, earn points and help others
