I want to clean the haze off the watch crystal
SOURCE: Link pins keep falling out on Ceramic Watch
They probably forgot to put the little locking barrel back in before hammering the links shut again. Some watches have the link, the pin, and a barrel that goes in the link before the pin is hammered in. If your watch needs this barrel then the pin will NOT stay in without it, no matter what.
SOURCE: remove the winding stem/crown.
There is a tiny point (end of small metal piece called setting lever) on the left side of the stem (on watch movement, very close where the stem is entering the movement).
You have to push that point down with a metal pin or tweezers. Crown (winder) must be pushed in to normal position otherwise you will not be able to put the stem back properly.
So, do as follows:
1) Push the crown in,
2) Lay the watch down on flat surface and push on setting lever point,
3) While holding setting lever pushed in- extract the setting lever by gently pulling crown out of watch.
Do not forget to rate, please.
SOURCE: setting time Wenger Swiss military brigade hinged crown protector
The crown protector is hinged on the lower end only. The upper end can be pulled away to expose the crown for time setting.
SOURCE: How do I remove the crown/stem.
To remove the stem you must first loosen the set lever screw, then you can pull the stem out.
You only need to turn the set lever screw a couple turns to release the stem. Some movements use a button instead and in that case you would simply push the button down lightly with a pointed tool and while holding the button down pull the stem out.
For watches with one-piece cases where the movement comes out the dial side and the case has no removable back, you will not be able to get at the set lever screw. For this type of watch you must grasp the crown firmly and pull it out, or use plastic or soft brass tweezers to get behind the crown and pop it off. These watches have two-piece stems that have male and female ends that snap together. Then remove the bezel and let the movement come out into your hands. Then remove the hands and the dial and put the movement face down into a movement holder.
Testimonial: "thanks"
