Question about Dalen Products Pond And Pool Netting Black 14x14 Feet - PN-14
How many gallons of water in 14x14 pool? - Dalen Products Pond And Pool Netting Black 14x14 Feet - PN-14
I need to know how many gallons of water are in my pool
Formula For Average Gallons In Rectangle, Square Or Freeform Pools:
Length x Width x Average Depth x 7.5 = Total gallons
Formula For Average Gallons In Circular Pools:
Diameter x Diameter x Average Depth x 5.9 = Total gallons
Formula For Average Gallons In Oval Pools:
Length x Width x Average Depth x 5.9 = Total gallons
Formula For Average Depth Of Pools With Slopes:
Shallow End Depth + Deep End Depth Divided by 2 = Average Depth
Jun 18, 2017 | Pool & Spa
How many gallons of water in 3172 cubic feet of water?
There are 7 1/2 gallons of water in a cubic foot.
3172 x 7.5 = 23,790
To calculate how much water in a swimming pool, in 'US Feet':
Length x Width = Surface Feet
Surface Feet x Average Depth = Cubic Feet
Cubic Feet x 7.5 = Total Gallons
Mar 07, 2015 | Pool & Spa
How many gallons of water in a 4'by 24' round pool?
the volume of the tank is calculated by the formula
22/7 x 24 x 4
= 301.7143 cubic feet
1 cubic foot = 7.48052 US Gallons
therefore your tank will hold 2257 US gallons approximately
Mar 04, 2015 | Pool & Spa
How many gallons of water in a 24 foot round pool that is 52 inches deep
18,600 gallons (length x width x depthx 7.51 =gallons)
Aug 23, 2014 | Pool & Spa
How many gallons of water is in a pool 10 ' by 36 "?
roughly, between 1700 and 1800 gallons of water will be in that pool
Jun 27, 2014 | Pool & Spa
How many gallons of water the intex 15x36 pool holds?
Depends ... 15 feet round? 36 inches deep? = 3976 gallons
15 feet by 36 feet rectangle, how deep? if 5 feet deep = 20,250 gallons
Hope this addresses your question.
Thanks for your interest in FixYa.com
Jul 10, 2011 | Intex Easy Set Pool 15x36
My salt water system says low salt after i added 40#. I dont know what else to do.
How many gallons of water are we discussing? #40 would be about enough for 1800 gallons? (guessing)
It should say on the bag what the aplication rate is. Had you provided the gallons or had you given the size of yor pool, I would have calculated it for you.
Post the info ... and I will calculate for you ...
Aug 04, 2010 | Intex Automatic Salt Water System for ...
I am setting up my pool and it is 15 x 36.intex easy pool. Do I need to put any shock treatment or chemicals in the water. I heard you can pour in bleach?
yes i put pure bleach in my pool....I only use one bag of shock it about every month or so and i use 1 and half gallons of water each week. U can about tell when u will need to add it..when the water starts getting cloudy. My pool is a 20 round...8,800 gallons, so if u have a smaller pool for instance a 15 round.....5,000 gallons, i would only put maybe 3/4 of a gallon and a smaller pool about half a gallon of bleach per week.
Now how to put the bleach in the pool is what u need to focus on. The way i do it is where the water is returned to your pool i open the bleach and make sure u r wearing old clothing because i didnt once and i had bleach spots on my shirt due to the water splashing back up through the return. Well just pour slowly where the water comes back in the pool.....this is to prevent the liner from bleaching. So i suggest that u do it as slow as u can...its a lil but tidias when u pour it in compared to just dumping a bag of but its well worth the money u save. Pouring it over the water that returns to ur pool is to make sure it doesnt hit the liner and bleach it.....the water from the return will mix in with what u are pouring so that wont happen.....It will save alot of money...i dont use any other thing in my pool but bleach and shock it like i said about every cpl months and all the shock it is for is to settle everything to the bottom so i can vacuum it up. My pool is sparkling clear. i can see every lil spec. Good luck and I hope this helps.....Let me know!
God Bless
Jun 20, 2010 | Intex Easy Set Pool 15x36
The baxters, the gillberts, and the Sings are pumping water into the swimming pool in their city park. The pool will hold 302000 gallons of water. These neighbors are using their garden hoses to fill up...
Do the families have the proper permits to add water to the public pool? If not should the time to acquire the permits be considered ?
Secondly, What is the temperature of the water coming out of the hoses, as cooler water will expand and fill the pool faster.
Considering all of the unknowns we can not solve for Time. Do you know how much water the Baxters are delivering to the pool? It appears they did not pay their Water bill.
Pool=302,000
Gilberts=G=(B/12)*92/H
Baxters=B
Sings=S=85gallons/H
Time=302,000/S+B+G/H
May 26, 2017 | Learning Company, Inc. Clue Finders Math...
My pool water turned green after I put an alkalinity and ph stabilizer in it what can i do to get it clean again?
Pure bleach, gets mine clear when it turns green. If its just clear water with a green tent then i would use bleach. I only use bleach to maintain my pool. I have a 20 round 88,00 gallon pool and i use 1 and half gallons of bleach every week to keep my pool clean and i use a bag of shock it every month or so, all the shock is used for is to drop everything to the bottom so i can vacuum it. If u have a smaller pool then i would use about 3/4 a gallon a week on a 15 round 5,000 gallon pool and about a half a gallon for a smaller pool. But it will for sure get ur water clear and if u dont want to use bleach then shock it will do it and to maintain use the shock it atleast once a week. When u use the bleach make sure u pour in over the where the water returns in your pool slowly to help it not hit the bottom. When u pour it over the clean water that is returning to your pool then it will help spread it throughout your pool and dilute it so it wont spot your liner up with lil bleach spots. So just pour it slowly over the return water comin out of the side of your pool. Also if its an algea problem then bleach will def work to prevent and kill the algea and u can u an algeacide to get rid of it if u dont want to use the bleach. The bleach is the cheapest way and fast way i have found to keep a pool clean. My pool is cyrstal clear, u can see any specs that is floating in it I hope this helps, please let me know what u think and rate solution. thanks and good luck
God bless
Jun 15, 2010 | Intex Easy Set Pool 15x36
Dalen Products Pond And Pool Netting Black 14x14 Feet - PN-14 Logo
62 people viewed this question
Top Dalen Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Dalen Garden Expert? Answer questions, earn points and help others
