Air force (B&Q) Air Conditioner wap 35dih Manual
Machine switches on and constantly beens. Ive tried resetting by holding the on/off switch down and turning power on then off but it goes back to bleeping again.
  • 208 Answers
SOURCE: paper jam won't clear
Look for a small piece of paper remaining in the machine.
Also there may be a jam switch actuator that has fallen off.
Posted on Dec 07, 2007
bobotfel
  • 236 Answers
SOURCE: air conditioner
Remote control units have diagnostic program in the
control, after 3 to 5 minutes of operating if the diagnostic
tools detect abnormal operation, then its shutdown the unit
to protect from damage. Thermistor sensor is one of the
parts that detect the operation of the unit. Out of range
or defective thermistor can shut the operation of the unit.
If your indoor and outdoor is clean start the unit in cool mode and monitor the outdoor pipes. If your suction pipe is icing or dry then your unit is under charge, but if your suction is cold and sweating then the system is ok and sure that the thermistor sensor is defective.
- Out of range thermistor sensor in both return air and freeze up sensor can cause the tripping “off “ the unit. The resistance of both thermistor is 8 to 10k ohms, so can test by using ohm meter
Posted on Jan 12, 2008
SOURCE: my hp deskjet 1280 printer is not coming on
Maybe the back door (for removing paper jams) is not closed.
Rotating door knob needs to be pushed to the end - even if it seems to be hard, there is some more space to the end. Printer won't work if the back door is open.
Posted on Jun 11, 2008
SOURCE: Air conditioner won't stay on.
'64 could be right, but these Malibu's also have a tendency to go through HVAC head control units, among other things. I have taken the head unit out of mine and cleaned the contacts, etc...with some success. However, from what I've seen, this is just a temporary fix. These units run upwards of $200 at a dealer, but you can get one online for just over $100. It is a really easy install.
Other common problems include:
-Cruise control modules going bad (cruise kicks off at will)
-Bad resistor on fan blower (only speeds 3-5 will work)
-Front coil springs breaking
-Front brakes wear funny, excessive wear
-Moisture in headlight housings
Posted on Aug 29, 2008
SOURCE: Panasonic casette air conditioner-display error temp 'CHECK'
Check that your water pump is working and not blocked up as the unit will keep swicthing off if it can not get rid of the water.
Posted on Dec 08, 2008
Airforce climate control wap-35dih instructions
Try Googling (airforce)(wap-35dih)(manual) without parens.
Jan 23, 2014 | Heating & Cooling
Tip
How to Reset Your Air Conditioner Filter Light
<span style="font-weight: bold;">Cabin Air Conditioner:</span><br /> <ol> <li>Press and hold down the Off button for 4 seconds.</li></ol><span style="font-weight: bold;">Carrier Air Conditioner:</span><br /> <ol> <li>Press the Reset Filter button to reset the timer that calculates the next air filter change after you have inspected / cleaned the indoor return air filter.</li></ol><span style="font-weight: bold;">Daikan Air Conditioner:</span><br /> <ol> <li>Press the Filter Clean Reset button to reset the CLEAN FILTER INDICATOR after you have inspected / cleaned the indoor return air filter.</li></ol><span style="font-weight: bold;">Frigidaire Air Conditioner:</span><br /> <ol> <li>To reset after cleaning the filter, press the "Filter Reset" button and the light will go off.</li></ol><span style="font-weight: bold;">GE Air Conditioner:</span><br /> <ol> <li>Turn the air conditioner OFF and unplug it.</li> <li>The air conditioner must be unplugged for the automatic filter clean timer to reset. Clean the filter.</li> <li>After cleaning, replace the filter and plug the air conditioner back in.</li></ol><span style="font-weight: bold;">Honeywell Air Conditioner:</span> <ol> <li>Press and hold the i button until the timer is displayed, followed by pressing the Up Arrow button (next to the Wake button)</li> <li>Press the Run Program button.</li></ol><span style="font-weight: bold;">Kenmore Air Conditioner:</span><br /> <ol> <li>To reset the filter indicator, press and hold the filter reset button for 3 seconds.</li></ol><span style="font-weight: bold;">Lexus Air Conditioner:</span><br /> <ol> <li>Without having foot on the brake, press the Start button twice to get to the IG-ON position.</li> <li>Then press and hold the "hard" OFF button next to the "hard" Auto button. Hold the OFF button for approx 5 seconds and you hear several beeps.</li></ol>or<br /> <ol> <li>Turn the engine switch to IG-ON mode.</li> <li>Push and hold the A/C OFF button for more than 4 seconds.</li></ol><span style="font-weight: bold;">Lexus 2008 Air Conditioner:</span> <ol> <li>Push the "INFO" button & touch "Maintenance".</li> <li>Touch the desired button Delete All: To cancel all conditions which have been input or Reset All: To reset the item which has satisfied a condition. If "ON" is selected, the system gives maintenance information with the "Information" screen when the system is turned on. If "OFF" is selected, the "Information" screen is disabled.</li> <li>Input the Notice of Date: The next maintenance date must be input.</li> <li>Now input the Notice of Distance: The driving distance until the next maintenance check.</li> <li>Delete: To cancel the date and distance conditions.</li> <li>Reset: To reset the date and distance conditions.</li> <li>Touch "OK" The screen returns to the "Maintenance screen.</li></ol><span style="font-weight: bold;">Lincoln LS 2001 Air Conditioner:</span><br /> <ol> <li>Press and hold the setup button above the radio until it says system check. NOTE: All the doors must be closed.</li> <li>Watch the system check when it goes to A/C filter hit the reset button.</li> <li>Hold down the reset button to confirm.</li></ol><span style="font-weight: bold;">Lincoln LS 2003 Air Conditioner:</span><br /> <ol> <li>Press the STATUS control to access the System Check function, the message center will display A/C FILTER XX% RESET FOR NEW.</li> <li>Press and hold the RESET control to set to 100%.</li></ol><span style="font-weight: bold;">Lincoln LS 2005 Air Conditioner:</span><br /> <ol> <li>Insert the key and turn the ignition to "Run" or "On." It is not necessary to start the engine.</li> <li>Press the "Status" button above the radio until the system display changes to "AC Filter."</li> <li>Press and hold "Reset" above the radio. The system will beep and the "AC Filter" display resets to "100%."</li></ol><span style="font-weight: bold;">Maytag Air Conditioner:</span><br /> <ol> <li>Press the "Fan" button 2 times, then press the "Mode" button 1 time and it will reset.</li></ol><span style="font-weight: bold;">Whirlpool Air Conditioner:</span><br /> <ol> <li>Push in the filter reset on the remote using a straightened out paper clip or similar.</li></ol>or<br /> <ol> <li>On the control panel, press and hold the Mode and the Up Temp Arrow buttons for 6 seconds.</li></ol>or<br /> <ol> <li>After having cleaned the filter just press the reset button located on the indoor unit behind the front panel to interrupt the flashing of the filter monitor indicator.</li></ol>
on Jun 17, 2011 | Heating & Cooling
E1 error
please mention the brand some e1 code for cleaning the filters and some as follows
Power down the air conditioner using the "power" button on the front panel. Unplug the air conditioner from the wall socket. Hold the front panel "power" button down and plug the air conditioner in.Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button. Unplug the air conditioner.Plug the air conditioner back in.
Aug 22, 2011 | Heating & Cooling
We have a portable air conditioner. It keeps
Follow the steps below....
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
Jun 26, 2010 | Heating & Cooling
How do I reset the e1 on the A/C
I have a sharp and I don't know what model you have but you may check the manufacturers web site for a instruction book
but on my unit you have to do the following
panel.
button.
after following this procedure to clear the nefarious E1 indication, you should obtain
another 720 hours of cooling bliss
Jul 20, 2009 | Sharp AFR120FX Air Conditioner
My MSH 024 Air Conditioner keeps tripping off at the mains switch
FIRST TRY TO CHECK THE CIRCUIT BREAK THAT IS CONNECT TO THAT AIR CONDITION, USUALLY IS A 30 AMPS OR 40 AMPS CAPACITY, MAYBE IS BELOW THE AIR CONDITION CAPACITY AND OVERHEAT THE BREAK, OTHER WISE UR SHOULD CALL A TECHNICIAN TO CHECK THE COMPRESSOR AND THE COIL OF THE CONTACTOR
Mar 09, 2009 | Comfort-Aire MSH-024 Air Conditioner
Control panel lights constantly flashing
You should have a dedicated line that feeds the equipment power look at your main electrical panel or search around your equipment for a pull out disconnect switch or sometimes they will wire it to a light switch. by shutting down the main power and turning it back on it should reset anything.
Jan 04, 2009 | Mastercool 67471 Evaporative Cooler Air...
Air conditioner has to be reset --E1
If your a/c unit is portable,and E1 code most always is "air filter cleaning time" or" water level to high ".
To reset air filter interval turn unit off at power switch then unplug.Hold power switch down while plugging in....unit will go through a short self check then beep.Release power button after beep.Unit should now be reset.
To reset water level....just drain some.....not all.
Most portables use water for increase cooling......so leave some in.
Jul 27, 2008 | Sharp AF-S100FX Air Conditioner
It turns off
The e1 code is a demand to clean the filter. It means the unit has been running for 720 hours. It does not mean anything is broken...unless it hasn't been running for 720 hours. That would mean the "clean the filter" timer is broken! There are 2 reset methods.
1) Unplug the machine. Hold down the power button while plugging it back in and wait until it beeps (for about 5 seconds). Let go of the power button. Unplug the machine again, then plug it in and try to use it as an air conditioner.
2) Unplug the machine. Hold down the Mode button while plugging it back in. Keep the mode button pressed until it beeps (for about 3 seconds). Let go of the mode button. The machine will start. Turn it off by pressing the power button. Resume trying to use it as an air conditioner.
If neither of these work, the "clean the filter" timer is broken and needs replacing.
Jul 23, 2008 | Sharp AF-S100FX Comfort Touch Air...
ARF120
If you have the error code E1 on the LED temperature display. This error code is intended as a reminder for the user to clean the air filter every 720 hours . I have a sharp and I don't know what model you have but you may check the manufacturers web site for a instruction book but on my unit you have to do the following
panel.
button.
Jul 13, 2008 | Sharp AFR120FX Air Conditioner
136 people viewed this question
k24674
