Question about WWFG 1994-2002 Chevrolet Astro Van Custom Style Over Roof Light Bakers Door
Front end thumping noise when brakes applied - WWFG 1994-2002 Chevrolet Astro Van Custom Style Over Roof Light Bakers Door
    Master:
  • 560 Answers
Could be a distorted rotor, loose wheel nuts, loose wheel bearing nut, break pads that are u7nevenly worn.
Posted on Jul 27, 2014
I have a 99 Sunfire and it is making a thumping noise in the front end seems to be passenger or middle and it does it when I'm driving straight or go around the corner 2 right left cornering is ok
Does it change when the brakes are applied? You might have very rusted and scaly front brake rotors. If this is the case the noise would change when brakes are applied
Apr 10, 2017 | Cars & Trucks
Mercury Montego Problems
I think the clue is in what you are doing. Applying the brakes. The mileage denotes you should have had a least 2 sets of front pads and 1 set of discs by now. When were these last properly checked, and I don't just mean a casual peep under. The thump could be, at this mileage, a bush(es) in the front suspension worn and makes a noise when the front is loaded by applying the brakes. The main thing is, it's not good, and should be checked out immediately.
Nov 05, 2013 | Cars & Trucks
What could cause a thumping noise from the front end when turning at low speed?
sounds like wheel bearings-1st
but hopefully your front disc need turning, or replaced.
check wheel bearings by jacking up the front end "CAREFULLY" WITH
JACK STANDS & wiggle tires,if you get more than a 1/4'' slack on 1 or the other, than it's shot. Best to replace both sides. "GOOD LUCK'' &
BE CAREFULL.
Aug 22, 2012 | 2009 Hyundai Elantra
There is a thumping sound coming from the rear end of my '06 Grand Prix. It isn't a constant thump and sometimes it happens when I apply the brakes
The thumping Would likely be warped rotors causing the pads to rock in the carrier, (Assuming the anti rattle clips were installed at the time brakes were replaced?) Turn or replace rear rotors
Jun 27, 2012 | 2006 Pontiac Grand Prix
Front end making rattling, thumping noise when driving. Slowing of speed increases the noise.
i would 1st check out the front tires to make sure that they are not defective, if tires check out ok, then i would put the jeep on a rack at a garage, and check out all of the front end components, including c. v. joints and the wheel bearings.
Jun 24, 2011 | 1994 Jeep Grand Cherokee
Thumping noise in the front end
Inspect your tires look at the tread, observe the wear across the tread, inspect the inner and outer side walls, look for bubbles, look at the rim look for damage. The more info you get the better.
Apr 28, 2009 | Geo Tracker Cars & Trucks
Knocking noise from rear when hand brake applied.
i recently had 4 tyres fittede and tyre company had crossed threaded one stud so forcing brake disc to be loose, hence when handbrake applied got thump from brake area.
Apr 18, 2009 | 1998 Subaru Impreza
2005 honda accord noise when breaking (transaxle)
You say you hear the noise when you "slow down". Does this mean you hear the thumping noise when you let off the gas and let the car coast to a stop or only when you are applying the brakes to decellerate?
If you only hear the noise while applying the brakes then I would assume it has something to do with your brakes. The first thing that comes to mind would be rotors that aren't true or warped which could make a thumping sound.
Do you feel any vibrations in your foot when it is applying pressure to the brake pedal? If you do feel a sort of pulsating feeling then it could very well be your brakes making the noise.
I hope I was of some assistance,
AadoubleA
Apr 04, 2009 | 2000 Honda Accord
Thumping noise when apply brakes 1990 Accord
yes my cv axles had to be replace cause of the same thing but when you replace one side you need to do the other side at the same time cause when 1 goes bad the other is not that far behind . i know from experience
Nov 18, 2008 | 1990 Honda Accord
WWFG 1994-2002 Chevrolet Astro Van Custom Style Over Roof Light Bakers Door Logo
929 people viewed this question
Top WWFG Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a WWFG Hardware and Accessory Expert? Answer questions, earn points and help others
