Question about Apple Macbook Laptop Core 2 Duo 2ghz 1gb 80gb Hd 13.3" White May 2007 Mb061ll/a
4sns/1/40000000: ThOH "Please restart computer" screen appears very often, especially when streaming videos. Hardware Test found following problem: 4sns/1/40000000: ThOH
4 Suggested Answers
  • 22 Answers
SOURCE: DVD write problem and hardware test error code
I hope this works for you it did for me when I updated all my firmware.
http://docs.info.apple.com/article.html?artnum=88275
Posted on Apr 16, 2008
  • 5 Answers
SOURCE: DVD write fails
I got the same problem. The mac internal drive is very choosy about types of disks. Options are - try splashing out a bit more on disks or as LeonAzul suggests go for an external burner. I bought a big batch of cheap discs which only work with an external burner. More expensive jobs are fine with the internal one.
Posted on Feb 28, 2009
  • 3 Answers
SOURCE: 13" late 2008 Aluminum macbook restarts and will not shutdown
The problem should be in the mother board, i recomend take the machine to any apple service store , they have all the software and hardware needed to find the problem, if you paid for the machine the old owner must have the information about the machine ( i mean maybe he must to know the begin of the problem ) if you understand the bassic logic of the repair, you should know that if the machine still show the problem when the drive is not present is one or another answer
1 - the mother board is damaged.
2- the drivers of the dvd reader are corrupted.
Dont broke your mind , take it to the apple service i'm 100% sure that the machine can be fixed with the right hands.
Posted on Aug 30, 2009
4sns/1/40000001:ID0R-0.000
Hi
hope you have fixed the problem by now. However your description does not have enough information to help find solutions. Describe what you do and how you have tried to solve the problem.
Aug 30, 2013 | Apple 15.4" MacBook Pro Notebook Computer...
When i click voice clips in messenger blue screen appears
1. You have a hardware resource conflicts. If you have installed a new hardware try to remove it.
2. Please check if you correctly installed the appropriate drivers to your system
3. Check your video adapter if its working properly.
Check if the driver is intended for that device
Use EVEREST software to check your hardware and software setup
4. Try replacing the RAM maybe it is defective
Thanks. Cheers!
Apr 19, 2010 | Computers & Internet
My hp notebook (laptop) cant start... when I open my notebook the following in sequence appear: ''window is loading files.... next there is ''A rectangular figure with moving small vertical lines from left...
Ok, at bootup, press F8, choose Boot up in safe Mode, when next window comes up, it ask if you want to go to desktop OR System restore, Choose system restore. now when next window, like a calender comes up, simply choose a date BEFORE you had problems, follow instructions, and it will reboot,this should get you back to working.
Mar 26, 2010 | HP Pavilion dv6000z Notebook
Aug 21, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Cant use my usb
Refresh and reinstall USB Ports Of Your Computer Hello there, the other day i tried refreshing and reinstalling the USB ports on my PC, as some of my connecting devices are not recognized. I present the detailed procedure on refreshing the USB ports.
Let’s go!!
Here are the steps to refresh/reinstall/uninstalling the USB ports on the computer.
The USB port needs to be refreshed to make sure that no other device has captured the USB port of the computer. The Mouse, video camera, your external USB hard disk; what ever it may be.
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager Button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external USB hard disk...USB hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main USB devices at the rear end USB port. As they require more power to initiate.
The above steps are for XP operating system. When coming to the matter of Vista, please note the changes below:
1) Right-click Computer icon from the desktop , and then click Properties to open the System Properties window, and then select the Device Manager tab.
2) Click the Plus (+) sign next to Universal Serial Bus Controllers/Root hub.
3) Click the USB Composite Device entry to highlight it, and then click Remove. If a screen appears to confirm the deletion, confirm the deletion.
4) Disconnect the USB cable to the all-in-one, wait a couple seconds, and then reconnect the cable. This should restart Windows device detection (Plug and Play).
5) A New Hardware found screen may appear, click next through all of the screens that appear for the Wizard to install the USB Composite Device. Click Finish once the wizard completes.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | Toshiba Satellite M35X-S311 Notebook
Wont read/write hard drive
use Apple Hardware Test to diagnose the error::
1 Disconnect all external devices from your computer except the power adapter.
If you have an Ethernet cable connected, disconnect it.
2 Insert the Mac OS X Install Disc 1 that came with your computer.
3 Restart your computer and hold down the Option key as it starts up. A list of available
startup volumes appears. Click Apple Hardware Test and click the right arrow.
4 When the Apple Hardware Test main screen appears after about 45 seconds, follow the
onscreen instructions.
5 If Apple Hardware Test detects a problem, it displays an error code. Make a note of the
error code before pursuing support options. If Apple Hardware Test does not detect a
hardware failure, the problem may be software related.
Thanks, Joe
Mar 18, 2009 | Apple PowerBook G4 Mac Notebook
Hello sir,Before 3 days ago I bought HP dv5 1104AX laptop.In this laptop there one problem in graphics like suppose I open video site in browser aned if I put in full screen then screen will be divide in...
Hello sir
I understand that your notebook is unable to play online videos in a web browser in full screen mode.
Videos on YouTube are streamed through an Adobe Flash player. For the best viewing experience, we suggest you install the latest version of Adobe Flash after removing any old versions you've installed.
Please completely uninstall Flash before reinstalling the latest version.
To uninstall Flash, please follow Adobe's instructions, listed here: http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=tn_14157
Once you're done, restart your computer and follow Adobe's instructions for reinstalling Flash: http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash
If the instructions above don't resolve the issue please try the following:
  1. Temporarily disable popup blocking software installed on your computer to test.
  2. Allow YouTube.com as a trusted site in your Firewall software.
  3. Ensure other applications like Quicktime, iTunes, Real Player, or Windows Media Player aren't set as the default streaming application, as this might affect the video player.
Windows Vista users: If the flash uninstall reinstall does not work this maybe due to a Microsoft Windows Vista permissions issue.
Please use the Windows button at the bottom left then the search function:
  1. Go to: C:\Windows\System32\Macromed\Flash\
  2. Right-click on the following file: FlashUtil9b.exe or FlashUtil9e.exe
  3. Select "Run as Administrator" and install the update.
  4. Restart your computer.
Jan 31, 2009 | HP Compaq Presario F750US
Screen goes blank on Log on
You must uninstall your previous video card drivers before installing the new card, especially if they were nVidia drivers.
Jul 23, 2008 | IBM NetVista PC Desktop
Use PC wizard (search and download) this will detect all drivers needed on your computer note name and number for your video card type into search engine IE ati x300 drivers for your operating system xp vista you should be able to download correct drivers
if does not work for you please leave reply what happens
Jul 23, 2008 | HP RADEON X300 SE, (128 MB) PCI Express...
Jan 13, 2008 | Apple Power Mac G5 Desktop
Apple Macbook Laptop Core 2 Duo 2ghz 1gb 80gb Hd 13.3" White May 2007 Mb061ll/a Logo
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
