G41m p26 WAKE UP ON LAN
4 Suggested Answers
  • 129 Answers
SOURCE: I HAVE MSI G41 Motherboard G41M-P26. MY PC
try sir first to scan your pc with a reliable and full operation anti virus, restarting pc usually is infected by virus.
Posted on Jul 11, 2011
bronk50
  • 27725 Answers
SOURCE: I HAVE GIVEN THE POWER CONNECTIONS IN G41M-P26 FROM CPU WITH THE HELP OF USER MANNUAL,STILL IAM NOT ABLE TO SWITCH ON PC,BUT MOUSE IS GETTING POWER WHY?
Test the leads that attach to your ((hard drive from the motherboard)) make sure they have dust free secure connections or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive)) if its a 40 pin IDE this will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs continue its cycle power and data to travel through every working device and have an end point so any faulty leads will end up with a computer error
hope this helps you
Posted on Feb 21, 2012
  • 3799 Answers
SOURCE: msi g41m-p26 won start (no power)
The most likely solution is to replace any Capacitors that have blown in the onboard power circuit. Look for a Capacitor that has got a very bulging top in the region of the power connector.
Posted on Dec 06, 2012
MSI G41M-P26 jpwr2? if i disconnect it no power. if i connect it there is a power but no display.
You don't give enough information. You need to decide if motherboard is starting up - and you can hear hard disk(s) running and accessing data, or if everything is totally dead.
If the former the lack of a display could be a fault with your graphics card.
You need to see if the power supply is running, look and see if its fan is going and then listen to see if hard disk motor is running. If these are dead try a replacement Power Supply.
If you get some text or graphics on the screen when you first turn on, and before screen goes blank, that suggests it is running and the blank screen can be due to a software problem.
If you need more help, supply more info about the fault.
Cheers.
May 16, 2014 | MSI G41m-p26 Desktop Motherboard - Intel...
Wake on lan enable
enable wake on LAN in bios then download a wake on LAN program. correct the settings to what you want and then test.
just be aware that for WOL to work you need to have a PC on to run the program and then of course send the request
Dec 19, 2013 | IBM x3400 Server
Wake on lan
https://en.wikipedia.org/wiki/Wake-on-LAN
here you can read about WAKE ON LAN.
Apr 17, 2013 | Medion Computers & Internet
Msi g41m-p26 won start (no power)
Dec 05, 2012 | Computers & Internet
How to reset bios on a msi g41m-p26
on the board is a jumper right above the pci slot (blue) with the pc powered off, move the jumper to pins 2 and 3, then wait 5 seconds, then move it back to 1 and 2. your bios is now reset :)
Jan 01, 2012 | Computers & Internet
I have a problem with Wake On LAN (WOL) on my PC. I have a GA-G41M-ES2L (revision 1.0) motherboard. a) Upgraded my BIOS to v8 (Yes, v6 fixed an issue with WOL, which I upgraded to at the time, and now...
My only suggestion would be to go into Windows power options on control panel and see what it's set to do at shutdown.If it goes into hibernation,it will dump everything in RAM,which includes your WOL process.Try setting it to sleep instead and set the put computer to sleep time where you want.
Also,there's a link to "choose what the power button does",set that to sleep as well.
Good or bad,please rate my post?
Thanks
Bob
Aug 11, 2010 | Gigabyte GA-G41M-ES2L Motherboard
How to enable GA-EP43-UD3L motherboard wake on lan?
Most modern ATX motherboards should have a 3-pin Wake-on-LAN connector near the PCI slots and should included BIOS support for Wake-on-LAN power up,check the Power Management Setup for this option.
As i check in your motherboard manual there is not pin but it supports wake on lan so go to bios and enable power on ring in power managment,it should be enable by default.Next right click on your computer,then properties,then device manager(OR YOU CAN SIMPLY GO TO START->RUN AND TYPE devmgmt.msc and hit enter).Then find the network adapters,click on it,and click on your ethernet controller(it should be realtek,gigabyte something like that) and the go to advance and scroll(search) for "wake up on lan" "wake up capabilities" and make sure that is on or enabled AND YOUR DONE:)
Jan 11, 2010 | Gigabyte GA-945GZM-S2 Motherboard
Help me enabling "Wake On Lan" On "On-Board Ethernet Card?
Start
Control Panel
Classic View
System
Properties
Device Manager
Expand the "network devices" branch
Select the NIC
Properties
Advanced
Pull-down and select wake-up properties
Change to 'Wake on LAN".
OK
Nov 09, 2009 | Gigabyte GA-945GZM-S2 Motherboard
Computers & Internet Logo
David Payne
David Payne
