Question about Dishwashers
Whirlpool dishwasher ADP7979/8 What does the F6 fault message mean and how do you fix it?
2 Suggested Answers
SOURCE: whirlpool dishwasher fault code f6
get a Maytag
Posted on Sep 05, 2008
What is error code F6 E5 in Whirlpool Dishwasher ADP 5510 IX ??? The dishwasher keeps stopping after 2-3 min of working.I haven't touched anything since the day I bought it (2 months ago)
Fault Code F5
Dishwasher Spray arms are clogged or otherwise malfunctioning
F6 Fault code
Dishwasher doesn't detect any incoming water despite the water inlet valve being open.
Nov 10, 2016 | Whirlpool Dishwashers
Whirlpool dishwasher error code F6
F6 error fault code
This is the Water tap closed. What that means is that the flow meter is not recording water entering the dishwasher, this can be a water tap turned off (suprisingly more common than you'd think, after new flooring or decorating has taken place),
water hose kinked or blocked, the dishwasher water soleniod valve defective.
How can I correct a recurrent F6 error?
you may have got a water inlet valve that is faulty, return and exchange.
press the helpful button
Feb 04, 2016 | Whirlpool Dishwashers
F6 code and red star symbol
f6 error is the waterflow to machine if your water is ok then check your flow meter its a bib plastic part on the side of your dishwasher it a common problem with whirlpool
Feb 01, 2014 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool dishwasher error code f6e4
F6 error fault code...
This is the Water tap closed. What that means is that the flow meter is not recording water entering the dishwasher, this can be a water tap turned off (suprisingly more common than you'd think, after new flooring or decorating has taken place),water hose kinked or blocked, the dishwasher water soleniod valve defective.
Dec 18, 2013 | Dishwashers
What does F6 mean?
The dishwasher can't take on water. Check that the water inlet is properly connected, the stop tap valve is open and that water supply is otherwise available to the dishwasher. Also check for kinks or blockages on the water hose.
F6. means "Water valve (WV1) is switched on but flow meter (FM) senses no impulses" (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
Water Valve Closed. Water inlet hose blocked.
Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
Jul 25, 2011 | Whirlpool 24 in. ADP6940 Dishwasher
Fault code F6 on whirlpool adp6940. what is it?
Hello there
F6 error code - The dishwasher can't take on water. Check that the water inlet is properly connected, the stop tap valve is open and that water supply is otherwise available to the dishwasher. Also check for kinks or blockages on the water hose. if all is good than you may have a problem with the solinoid valve for the water or the cycle timer may be faulty and the door switch may be bad or not working properly so
you will want them checked for ohms and resistance if they are found bad they need to be replaced
Jan 05, 2011 | Whirlpool 24 in. ADP6940 Dishwasher
The dishwasher is giving an E6 or is it F6 alert and not allowing any programs to be selected...I think this is an issue with water supply?
If you are getting F6 flashing on the display then it means there is a lid fault. This is usually hard to fix by yourself unless you are already familiar with fixing these type of things.
Not sure why you worked out it is to do with water supply.
I can give you some instructions on checking what could be wrong with the lid but you will have to get the drawer out from the housing. I am assuming you have a single drawer unit. Let me know if you are interested in checking this or calling a technician.
Jun 25, 2010 | Fisher and Paykel DS603SS Stainless Steel...
Dishwashers Logo
Top Dishwashers Experts
