Question about Epson WorkForce Pro GT-S50
Epson gt-s50 sticks
I have the Epson Gt-S50 and when I scan anything the paper sometimes sticks.
SOURCE: epson r2400 won't feed paper
I had the same problem, then found these instructions for cleaning the feed roller: http://www.museofineart.com/files/RollerCleaningProcedureRev2.pdf I used the paper towel method and it's working fine now with no issues.
Posted on Mar 06, 2009
rioglen
  • 95 Answers
SOURCE: our epson stylus rx500 printer has been saying
this means that you may need a reset your ink waste counter. try to perform this
For the RX500 - Hold down "clear + setup + on"
continue to hold the buttons until the printer had powered on, then off again, then back on. Once I noticed that the LCD had flashed a blank screen, I let go of the 3 keys. In the LCD window I was given access to 3 options using the select keys.
The first had something to do with calibrating the scan light, the second option said "startup." The 3rd did the trick. An abbreviation resembling "ink pad level" was what I was looking for. Here is where I forget what I did... I think that I pressed "OK" on the keypad,. It did nothing. Then I think that I held down the clear button for around 10 seconds. When I let go of the clear button, the LCD read "Press Power to Reset." All better now!
post me a review should this work sir / ma'am coz it did for me
Posted on Sep 23, 2009
vanherringto
  • 1738 Answers
SOURCE: i cant seem to find a scan option on my epson
Once all of the drivers are downloaded and the printer is connected to your computer, you can initiate a scan of a document two ways.
First, you can select Copy on the printer and it will copy the document placed on the scanner.
Second, you can scan a document to your computer by going to: Start > All Programs > Accessories > Paint.
When the Paint program opens, (in the upper toolbar) click: 'File' and scroll to 'From Scanner or Camera'. Then, select your device (Epson scanner) and click, 'OK'.
Continue with the prompts and your scan will be imported into the Paint Program. To save your scan, Click, File > Save As > (name your document) and select a folder for your scan to be sent to.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks.
Posted on Feb 03, 2010
pineworks
  • 4041 Answers
SOURCE: epson PX700w paper jam
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 05, 2010
tech-agent
  • 83 Answers
SOURCE: loading paper into an epson stylus tx110
hi there... this is what you need.
Loading Paper Follow these steps to load paper: step_1.gif Slide the edge guide to the left. ha5280001h.gif step_2.gif Fan a stack of paper, then tap it on a flat surface to even the edges. step_3.gif Load the paper with the printable side up, against the right side of the sheet feeder. Then slide the left edge guide against the left edge of the paper, but not too tightly. ha5280002h.gif ha5280003h.gif mark_no.gifNote: Leave enough space in front of the printer for the paper to be fully ejected. Always load paper into the sheet feeder short edge first, even when you are printing landscape-oriented pictures. Make sure the paper stack fits under the fon4_99.gif arrow mark inside the left edge guide.pls vote for me
Posted on Mar 16, 2010
Epson Error Code 0x9A
0x9A Circuit error (include blowout of a fuse F1 on mainboard). Main board failure.
Mar 18, 2014 | Epson WorkForce Pro GT-S50 Scanner, 600...
I have Epson stylus TX121 printer but whenever i m using to print out photo, photo comes in orange and red color, pls help me ....
Hi
When switching from printing on standard paper to photo paper, you need the change the paper and picture quality settings in Printing Preferences.
Start > (Control Panel) Printer(s) > right click on the Epson TX121 printer icon > Printing Preferences > Main > tick Photo or Best Photo > under Paper Options/Type select the closest match to the type of Photo Paper you are using (see photo paper packet for guidance) > Apply > OK.
Use the same procedure to switch back to standard paper settings to print on normal paper again.
I hope this helps
Aug 26, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I have downloaded the epson stylus cx5500 file now how to scan a picture
click the start > control panel > printers & faxes and then look for Epson Stylus cx5500. Right click it and click scan properties or scan (in other versions) . Just make sure that you put the paper or picture that you want to scan. Wait for it to load and then click the preview so that you will have the idea on which to scan. Then click Scan to scan the file. It will automatically save to My documents folder.
Jun 08, 2011 | Computers & Internet
How do i scan with a tx100?
In order to scan with the that printer you must use the software provided with it.
You may have an item on your desktop labeled EPSON Scan, but if you do not then you will need to go to Start > All Programs or Programs > EPSON > EPSON Scan > EPSON Scan.
If you still have difficulties you can refer to the manual online here.
I hope this helps.
May 02, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Will not scan. Error C:\ProgramFilesEPSON\escndv\es006c is displayed. Shows also ESCNDV.Exe
Do a complete reinstall.
1. Click Start, go to Control Panel, click System.
2. Click Hardware > Device Manager (XP). Click Device Manager (Vista and 7)
3. Look for Imaging Devices, right click on your Epson scanner and click uninstall.
4. Disconnect the usb cable from the printer.
5. Go to Control Panel > Add/Remove Programs (XP) Control Panel > Programs > Programs and Features (Vista and 7)
6. Look for Epson Scan and click Change/Remove/Uninstall.
7. Restart your computer.
8. Download the SCANNER software from the Epson website. If you have the disc, you can also run it.
9. Connect the usb cable back to the printer and computer.
10. Try scanning.
If that does not resolve your issue, you might need to remove Epson Scan from the Registry and reinstall the software again.
Nov 22, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How do i install epson GT-7000 scanner software cd-rom without using disc drive
Download the driver from onto a usb stick if needed. The appropriate driver as per your OS is available at
http://driverscollection.com/?H=GT-7000&By=Epson
Nov 16, 2010 | Epson GT 7000 Flatbed Scanner
I cant seem to find a scan option on my epson
Feb 03, 2010 | Epson Office Equipment & Supplies
Can you scan photos on the Epson DX6000 and save the image to the computor? If possible how do I go about it?
Starting a Scan With EPSON Scan If you want to scan an image and save it directly to a file, you can start EPSON Scan as a “standalone” program.
step_1.gif Place your document or photo on the scanner. See Placing Documents or Photos for instructions.
step_2.gif Do one of the following to start EPSON Scan:
    Windows:
    Double-click the EPSON Scan icon on your desktop.
    Or select Start > All Programs or Programs > EPSON Scan > EPSON Scan.
    Mac OS X:
    Open the Applications folder and click the EPSON Scan icon.
    The EPSON Scan window appears.
step_3.gif If the Mode setting in the upper right corner of the window is set to Full Auto Mode, click the Scan button. For instructions on selecting optional settings, see Using Full Auto Mode.
01.gif mark_no.gif Note: 01.gif 01.gif To change scan modes, see Changing the Scan Mode.
step_4.gif The File Save Settings window appears. For instructions on selecting options, see Selecting File Save Settings.
cj35003e.gif step_5.gif When you are finished selecting File Save Settings, click OK. EPSON Scan starts scanning in Full Auto Mode.
step_6.gif The scanned image is automatically saved in the specified location.
    If the Open image folder after scanning checkbox is selected in the File Save Settings window, Windows Explorer or the Macintosh Finder automatically opens to the folder where the scanned image was saved.
Please follow this link for same manual with screenshots:
http://support.epson-europe.com/onlineguides/en/dx6000/html_s/scan1_1.htm
Hope it helped.
Nov 22, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Epson WorkForce Pro GT-S50 Logo
18 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
