Question about Sharp Multi-System Mini Component System Shelf System
Cd dk890 says tuner and under it says tuner cl cant get the cl off or change stations
Radio wont find any stations
tuner IC TEF6901 probably failed - needs new tuner unit that cannot be purchsed!
Jul 06, 2012 | Visteon Car Audio & Video
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
How to change tuner to pick up all frequence's eg: goes from 95.5 to 95.7 how do i get it to change to 95.6 thanks jason
It will only tune into odd numbered stations because US radio station only broadcast in odd number stations (ex 95.5,95.7,96.3). You can change the area. Area 1 is North America, Area 2 is other areas. Press "Menu"->"Setup"->"Tuner"->"Tuner Area", then select 1 or 2. After setting, press and hold "Menu" for at least 2 seconds. This may give you the frequency you are looking for.
Apr 14, 2011 | Alpine CDA-9855 CD Player
When changing radio channels the dx mode appears instead of lo (local) cant get a signal
dx is short for distant. this just makes the tuner more sensitive and should pick up more stations. if it is not picking up stations in dx mode, you either have a bad antenna or a bad tuner.
Mar 22, 2011 | Clarion DXZ545MP CD Player
Could some one tell me how to change the stations on my WURLITZER -MODEL WR 18-1015-CD AM/FM- 18" TALL-LIGHT UP i have tried to and i can not get it to work. It only has a remote. Thank you
Here is a link to obtain the owner/user manual for that wurlitzer if you would like it:
http://www.payphone.com/shop/instructions/Wurlitzerwr18.pdf
1. Turn power on using either the remote or power button located behind tuner door.
2. Push CD / RADIO BUTTON (25) to enable FM tuner.
3. Turn FM dial to desired station.
4. Position FM ANTENNA (16) for best reception.
5. Set volume to desired listening level.
Sep 17, 2010 | Wurlitzer Crosley WR18 Mini-Bubbler CD...
Cant get exact station
you mean you cant tune to the correct frequency? if so the tuner may be in European tuning mode. consult your owners manual
May 19, 2010 | Clarion DB455MC CD Player
How do I manually tune a Ford Focus 6006 Radio
Press the Menu button. At some point it'll put an 'M' next to the station frequency. Then hit the seek up and down button.
Dec 12, 2009 | OEM Systems Car Audio & Video
Not recieving fm radio stations
if you can get am stations the problem is in the radio's tuner if you cannot get am stations either your antenna is bad, if this helps you please give me a good rating if not please e-mail me at merle840@aol.com
respectfully, m.merle
Apr 17, 2008 | Jensen CDH-1000 CD Player
AM/FM receiver
the problem is in your tuner for me it is betwen the IC and the IF transformer. if u cant fix it buy new stereo componet.
Apr 16, 2007 | Harman Kardon AVR 225 Receiver
Tune fm stations manual
You use the satellite tuner to change stations, not the head unit.
Jul 18, 2006 | Verge VMP508 CD Player
Sharp Multi-System Mini Component System Shelf System Logo
32 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
