Question about Proxim Computers & Internet
Setting up proxim Orinoco AP-4000 802.11a, 802.11g/b Wireless Access Point
Want to sett up proxim Orinoco AP-4000 802.11a, 802.11g/b Wireless Access Point gadget but am stuck i need help. A step by step process of how to set it up would help.
Hello have 2 Proxim ap orinoco 4000MR-LR Outdoor and i forgot all password and disable hardware reset how can I reset device to factory default
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
There a great article at General Router Setup.
Jan 31, 2011 | Proxim ORiNOCO AP-4000 (8670MUS)...
Power led blinks for about 8 seconds and switches off
Hi There,
Can you check the adapter or replace with other adapter that has same specification ( Voltage and Ampere) , usually this cause of bad adapter.
dm
Jan 05, 2011 | Proxim Orinoco AP-4000 802.11a, 802.11g/b...
Default Password for Proxim AP 4000 MRLR
The default password is should be "public" if it was factory defaulted.
Dec 04, 2010 | Proxim ORiNOCO AP-4000MR (8670-MR-LR)...
Proxim ap 2000 11b/g cardbus driver free?
i dont now how to get my uther computer to use wifi on the proxim orinoco ap-2000 11 b/g hit can u help me
Oct 13, 2010 | Proxim ORiNOCO AP-2000 11b/g Kit 802.11g/b...
How to reset orinoco ap 700
See the AP700 Hardware Overview below.... while the router is on.. press and hold the reset button (hole) for about 10 sec, using a paperclip.. the simplest way to restore your default setting..39f23e8.jpg
May 12, 2010 | Proxim Orinoco Ap-700 802.11a, 802.11g/b...
I need the acess point software
The software you need is available free at Proxim, the legal copyright holder of the software. You will need to make a free account to download the software. Here is the download link: http://support.proxim.com/cgi-bin/proxim.cfg/php/enduser/std_adp.php?p_faqid=1225
Oct 03, 2009 | Acer Lucent ORiNOCO AP-1000 (91.49C28.003)
I do not have the password for my orinoco rg-1100 router, is there any way to reset this?
Contact the company and find out what the factory password is and then reset the router. That should alow you access to it.
Sep 01, 2009 | Proxim ORiNOCO RG-1100 802.11b
Reset AP-700 failed
Simple solution, firstly do not press the reset button to long as it will erase all software, or you will have to do this the hard way. google the software called ScanTool run that from either ethernet or wireless, this tool shows you the AP-700's ip, mac, and name (some techs run these AP's coadjacent so it shows the name as well). You can change the ip of the AP-700 from here most of the time with the proper pass, then you should be able to connect to it regardless. if this dont help ... Proxim/Support/AP700 you will find more of an in depth approach of these things there.
Oct 30, 2008 | Proxim Orinoco Ap-700 802.11a, 802.11g/b...
Ap 700 reboot suddenly
Device setting themselves on their own to default?  Sometimes power surges, thunderstorms causes all of these. Reconfigure devices and try to buy surge protector.
Oct 18, 2007 | Proxim Orinoco Ap-700 802.11a, 802.11g/b...
Computers & Internet Logo
63 people viewed this question
Top Proxim Computers & Internet Experts
Prashant M
Prashant M
kj henriksen
kj henriksen
Are you a Proxim Computer and Internet Expert? Answer questions, earn points and help others
