Airbeam ip port forwarding
How do you connect a Verizon mifi so that yoy can view with airbeam app
SOURCE: Port Forwarding on Bigpond 2071a
yes u can forward 2071-a open browser and put this in addy bar 10.0.0.138
Posted on Nov 26, 2008
dvancamp
  • 13 Answers
SOURCE: Port forwarding
You have to create an object for your Web server and then set up new rule to forward traffic via port 80 to the newly created object.
Posted on Feb 10, 2009
trikha_karan
  • 66 Answers
SOURCE: Acer Aspire 5100 won't connect to secure Verizon Mifi 2200
Delete the previous wireless connection than changed the key in router and than try to connect.
Posted on Jul 29, 2009
  • 18 Answers
SOURCE: I want instructions to connect my verizon mifi to my xbox.
you need to buy a wireless reciever, after you connect it you go to system settings, then networ settings, scan for networks, and you should be good. a wireless adapter runs about 100 bucks
Posted on Jan 21, 2010
domotek
  • 591 Answers
SOURCE: I can not access my
OK let me clear port forwarding for you, your router normaly has a firewall (to block of any requests from the internet to exploit any services trough any ports) so if you want access to a resource on the LAN side (side of the router where all the devices and computers are pluged) from the WAN side (side where the ISP's modem is connected for internet) you have to open a port or multiple ports to a specific device IP address (according to device manual).
for exemple:
assuming that the camera has an IP of 192.168.1.110 and it uses port 7777 for resources, in the port forwarding section of the router you ave to open port 7777 and direct it to 192.168.1.110 (save settings and VOILA)
enjoy!
Posted on Jan 04, 2011
How to find dvr ip address
what do you want the DVRs local IP address on your LAN or your internets public IP address?
to see the local IP that the DVR is on, check the menu's in the DVR as if configured properly you should have it set up as a static IP on your LAN...
if you can not find it there, you should be able to log into your router and view connected devices... some routers are better than others, but you will probably only be able to see devices that are connected and assigned an IP address from your routers DHCP table..
if you want your public internet IP address then go to http://cmyip.com but in order to view your DVR from a different location on the internet you will need to set up port forwarding on your router - the DVR manual should show what ports need to be forwarded...
you may also want to consider using a dynamic DNS service if you do not have a static IP from your internet provider... most DVRs that I have encountered provide a dynamic DNS service..
Thanks,
Sep 15, 2014 | Computers & Internet
Panasonic wj hd316a accessing through verizon router
If you're trying to access it from outside your network, you will need to setup port forwarding to whichever the recorder uses. Google "Port forward <your router model"
Mar 08, 2014 | Computers & Internet
Activate roku 1
I am not sure about the page, but typically when your mifi is on and you have successfully connected to it a page may come up such as a Verizon page that will allow you to sign in. In my case with my mifi the page comes up and I wait about a minute and then it connects on it's own since I have already setup the connection to the mifi. The display and / or device will have the factory settings for your SSID and Password to log in with typically. If you could explain the code you are referreing to and what page as well that might help out with your question.
Jan 03, 2014 | ZTE Verizon Jetpack 4g/3g Mobile Hotspot...
I cannot connect my mifi verizon hotspot device to my transformer tablet tf300
Delete any other 'mifi verizon' connections from the 'wifi and networks' then restart (switch off for 10 secs by removing power cable) on both mifi and tablet and try agiain.
Jun 01, 2013 | Tablets & eReaders
I can't seem to remotely connect and view my lorex cameras. What am i doing wrong...it was working fine till I got Verizon FIOS
You may need to reopen the ports necessary for the Lorex to be available for remote viewing. You should be able to look at the function on the Lorex menu to get the port numbers, then call Verizon to have them forward the ports. Without port forwarding, your video stream is being blocked at the Verizon FIOS Modem.
Feb 01, 2013 | Lorex Home Security
I purchased a mifi 2372 from att to connect to a ps3 for my son who lives in an area of limited internet service. I've called tech support at att and sony to see if they can help since everything I've...
Samething with me. I have a mifi and it can connect to the playstation but cant sign in. It says it a DNS error. Which means one of your DNS numbers have blacked out and it can be fixed by getting knew dns numbers.
Dec 19, 2010 | Novatel MiFi 2200 Mobile WiFi Hotspot...
How can I boost the signal of my Verizon MiFi 2200 in my home? Can I attach a Linksys router to the unit?
You cannot connect a router to your Mifi as it does not LAn port. You can use wireless access point to amplify your wireless signal
Sep 13, 2010 | Novatel MiFi 2200 Mobile WiFi Hotspot...
How do I open ports 500, 4500, 53, and 52428 on Dell TrueMobile 2300 wireless router. Need to open them for Verizon Network Extender
1.Open the router interface by checking the default gateway
2.Under FIREWALL, you can find an option that would say "Virtual Servers"
3.Enable these ports, along with their types(TCP/UDP/Both) and assign an IP address that your Verizon Network Extender is going get( you to set that manually on the verizon device)
Save the changes and the ports will get forwarded!
**Note: In this case, DMZ under FIREWALL will NOT work!
Jan 18, 2010 | Dell Wireless 2350 Router
How do i connect MiFi2200 to a wrt54g?
I think this won't work...the MIFI device works as a wireless router that can supply 5 connections and runs on battery which last for 4 hours for one connection then goes down as more connections are in...the MIFI was designed for mobility as the WRT54G is not...I don't exactly know what your plans are but this won't work well.
The Verizon MiFi is a combination 3G modem and Wi-Fi router that is battery-operated for full mobility. Once the MiFi has been activated (more on that later) the device connects to the Verizon Mobile Broadband network (renamed from BroadbandAccess) simply by pushing the power button. In just a few seconds, the MiFi is connected to the 3G high-speed network and the Wi-Fi router takes over. The MiFi appears as a hotspot to any device with Wi-Fi capability, and making the Wi-Fi connection is as simple as entering the network security code which is printed on the back of the MiFi. That’s it: The notebook or other device is now connected to the Verizon network via Wi-Fi. The network code only has to be entered to make the first connection, after which it’s an automatic process. That’s the beauty of the MiFi method: Push the power button and the laptop/UMPC/phone is connected to 3G.
Oct 28, 2009 | Linksys Wireless-G WRT54G Router
How do i install ip cameras so that i can see them over the internet? I have a dvr connected to my 2wire modem and I do have static ips
You need to find out what ports your ip cameras use, and then setup port forwarding on your router. If you have 1 box that controls all the cameras, you just need to forward port 80 traffic to that box. If you have multiple cameras with NO main junction box, you will need to go into the setup on each camera, and specify a port to use.
Then in the router, set up port forwarding to forward each different port, to the camera it goes with. Then when you want to see the camera from home you would type the ip address in the browser, then a colon, then the port number --> IPADDRESS:81
Sep 12, 2009 | 2wire HomePortal 1100 Router...
Computers & Internet Logo
David Payne
David Payne
