Sony PlayStation 2  Console
Problem for Sony PlayStation 2 (PS2) Console
Power problem
By carlcarson45 on Mar 30, 2009
i have a ps2 that i cleaned out and put back together.after i washed the 2 outer shells and put system together and pluged it up it came on and started to play a movie it quit can alittle water in the power button cause this and if so if it dries out by morning will it work ok
Best Solution
posted on Apr 02, 2009
Helpful)
zabolyx
Rank: Wiz
Rating: 89%, 17 votes
It may or may not.
Getting an item wet is not as bad as one might assume as long as:
1. you dry it out as fast as possible.
2. you quit running electricity through it
3. no transformers or absorbing electronics get wet
You always should kil the power to any wet electronics to keep them from shorting out. Then take it a part and blow dry everything till nice and parched. As for # 3 it is more of a prayer than anything because some electonice components such as transformers and capacitors can hold water even after drying and will make a nice mess once electricity starts coursing through it.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Apr 03, 2009
Not Rated)
scoty boy
Rank: Guide
Rating: 0%, 0 votes
it realy depends wether you tried to turn it on when it was wet. if you leave it to morning without doing anything the water will stll be in the power button. i would advise you not to turn the power on until you have stripped the cover of and dried the wet area with a hair dryer but dont have the heat on full put the heat on the lowest setting as you may melt some circuits hold it for about 15 mins making sure you are not over heating any other components then hopefully that should be you. hope this is helpfulland i hope i fixes your problem.
Was this helpful?
Yes
No
Popular Solutions for Sony PlayStation 2 Console
Questions and Unsolved Problems for Sony PlayStation 2 Console
Do you recommend Sony PlayStation 2 (PS2) Console?
Answer
Answer
my ps2 broke it wont read my games and i need someone to help fix it you can see my image IT JUST... (More)
Answer
what does the back of a playstation 2 look like
Answer
whenever i turn on my ps2, no sound comes out of it at all, even though the volume on the tv is up... (More)
Answer
I have the old black PS2 game console. It will play old playstation 1 games (Risk, my husbands game)... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
