Question about Refrigerators
Maytag ref w 21TFA not cooling
We have a 3 yr old fef with 21 TFA Freon and a tech came and said he did not work on that since it is flammable, he said the condenser coil is blacked, is it worth fixing
aborcass
  • 2651 Answers
SOURCE: maytag refmodel number mff2557hew
sounds as if perhaps the fan in the freezer is not circulating air up to refrig sect. pretty common issue, if you pull out freezer door youll be able to hear the fan on the back wall, behind the vent on top sect of freezer. that cover pops right off with a pry of the screw driver.. heres the part number if indded that is the issue 12002744 comes with instuctions on how to install
Posted on Nov 10, 2008
mastatech
  • 478 Answers
SOURCE: amana SXD22S2W Side by Side not cooling - no frost on coils
He's right,sorry.
Posted on Mar 12, 2009
jumptrout51
  • 3361 Answers
SOURCE: maytag side by side defrost problem
The ADC has failed and or the defrost thermostat has failed. It has a cal rod heater. They usually do not fail, but check continuity on it anyway. The ADC is in the control panel on the back right corner.
Posted on Jun 08, 2009
  • 363 Answers
SOURCE: Freezer works ref does not
That is your problem the Freezer Fan supplies air for the freezer as well as the refrigerator. If the rpm are not high enough the frig does not get cool. I just replaces this fan and that was the solution
Posted on Jul 25, 2009
Sea Breeze
  • 4654 Answers
SOURCE: evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
Posted on Aug 05, 2009
I have a 3 yr old maytag ref/w/bottom drawer freezer. We have noticed water/ice under the freezer basket. Sometimes it is thawing and comes outonto the floor.Any ideas what causes this? I have not found...
Have you tried the following steps: 1) check that the gaskets are free of any damage, dirt, or ice. The door gaskets should seal perfectly on closing. 2) Or: turn off the ref, safely guard your frozen food, let the ref thaw totally and more. The purpose is to eliminate any undesired icing. If no succes and your problem gets worse call for help.
Feb 23, 2015 | Maytag Refrigerators
Maytag refrigerator not cold.
do you have a full frost pattern (coating) on freezer coils or see a ice ball, if ice ball Leak in system or bad valve in compressor. not worth fixing. go on (repair clinic .com).
you have a dampener and a fan to let the cold air go to all the areas check to make sure fan is running push in light switch in freezer and llisten for fan could be problem or no power to fan from main control board.
Dampener is flapper door that lets cold air from freezer go into ref. section
are your doors sealed, gaskets, frapper between door on ref section closing.
also your return air ducts need to be clear of ice, is your ice maker working that means that it is below 10 degees and repairable.
May 03, 2014 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag fridge not cooling
If the ref or freezer is too warm and you turn the dial to make it colder the compressor should come on. If the ref or freezer is not cold like you say the compressor should be on all the time. You should hear it, but you can definitely feel it and it should be very warm after a short while.
If the compressor does not get warm unplug the ref with the compressor running and plug it back in immediately. A good compressor should not start up right away.
If it is running and not getting warm and does start right up after unplugging it and plugging it back in it is inefficient and not compressing the freon gas enough and therefore not cooling enough.
The fan in the freezer should be running as should the fan under the refrigerator.
The condenser should be warm and the fan should be blowing[drawing] air across it when the compressor is on.
You don\'t repair compressors and to recharge them correctly is expensive.
May 01, 2013 | Refrigerators
Bought A/C in 2006. Used 1 yr - worked OK. Idle for 3 years. Installed this week - runs but does not cool!
Make sure there is no restrictions in the coils front or back. If the units compressor is running and was just low on freon it will ice up on the inside coil. If the compressor is not running it could be the temp switch or the capacitor. Make sure you have 220v at the plug in if its a 220 unit. Maytags are good units so look for hits on the coils that happened in installation or while stored if you see a obviouse dent ect... and its dirty or oily you may have popped a line and lost your freon. I hope this helps goodluck
Aug 11, 2010 | Maytag Heating & Cooling
Not cooling
It sounds like it needs freon,you will have to buy a saddle valve to have a service port to do this,and a can of freon,if you know someone who can do this,it needs to be done with gauges,so not to lock the compressor up.
May 26, 2010 | Maytag M7Y10F2A Air Conditioner
Last couple of years if our thermostat is set below 74 the ac will freeze up. The last 2 years we had it checked out and were told that 1)coils might be going out and 2) needs more freon. Once freon was...
Hello
If your going to have all the freon taken out,this current tech needs to find the leak.
Clearly from what you have said the unit has a freon leak.Freon is put in by ounces or pounds depending on the size of the unit,then you need to get the correct operating pressures.Coils do not go bad they either get full of dirt or get a hole in them.
An 8 yr old unit is a tough call,surley a new one will probably save some electric and come with a warranty.I would get some quotes on a new one,then see how much i could spend.
May 20, 2010 | Fujitsu Heating & Cooling
Gladiator ref is not cooling properly
Check to see if there is cold air coming from the freezer to the refridgerator side through the vent holes The compressor maybe getting weak or the freon charge maybe low. Does the unit run a long time before it shuts off? 50 degrees is not cold enough for a freezer. You should be around 32 or less.
John
Sep 28, 2009 | Gladiator Freezer GAFZ21XXRK
AC WON'T COOL
Sounds like you have a freon leak or your compressor has stopped working. You will probably need a service tech. If it is out of freon, don't let them just add more freon, make them find and repair the leak first. Good Luck.
Mar 27, 2008 | Intertherm P3RA-048K Air Conditioner
Lights are flashing
this is a common problem and it should be under warranty the mother board is bad its like the ref is possessed or something Ive ran across this I guess 20 times in the last 5 months Maytag has taken care of it but you have to have a tech look at it and wait for parts Maytag will pay up to $450.00 for rental ref. don't let any one tell you it beyond repair This info is direct from Maytag tech line a sepecial number for factory direct techs like myself good luck
Jan 17, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
