Philips DCM5090/10 The Cd cannot be read and the complete CD assembly unit needs to be replaced
Tech_Avery
SOURCE: Won't read cd/dvd the unit takes the cd tries to read it and then eject's it.
You either have a bad disc or the lens on the reader assembly is dirty. You can goto Wal-Mart and buy a CD lense cleaner
Posted on Dec 13, 2007
  • 476 Answers
SOURCE: philips dvp 3020
This is usually caused by a faulty laser.
Most DVDs have two lasers. One for DVD & one for CD.
Sounds like the CD laser has failed.
Posted on Feb 16, 2008
  • 56 Answers
SOURCE: problem reading blank disk
go to your burning software and look up disc info if it blank you will not be able to read it but it will show disc size space etc let me know how you get on
Brian
Posted on Jun 04, 2008
SOURCE: Philips Magnavox bookshelf 3 cd changer
Clean the laser lens
Posted on Aug 22, 2008
tvservice306
  • 458 Answers
SOURCE: CD player will not play cd's
Manufacturer Sharp Part Number 92LHPC1LXASY Description PICK UP ASSEMBLY
Posted on Dec 31, 2009
Jukebox Error 61 NSM
The complete laser and spindle assembly is a CDM12 Philips unit. Plenty for sale via flea bay.
Mar 19, 2014 | Wurlitzer Jukebox 1015 One More Time...
Recording
The No OPC message means that the unit can't record. The laser power calibration for the burner failed the internal test with that disc. Was the disc a blank disc? Make sure that you use a clean CD-R or unfinalized CD-RW. Try a different lot or brand of CD-Rs or CD-RWs. If the problem persists, then the laser on the recorder is damaged. If the unit is under warranty, contact Philips. However, based on the date given on the manual, this may not be worth finding a shop to fix the unit. DVD/CD burners for computers are fairly cheap but I'm not sure of the specs for a replacement CD burner for inside this unit.
The manual is available from Philips here: www.p4c.philips.com/files/c/cdr765bk/cdr765bk_dfu_eng.pdf . The trouble-shooting information is on page 21 (page 23 of the PDF).
I hope this helps.
Jul 11, 2013 | Philips CDR765 2-Disc CD Recorder
Does not read the disk
The laser pickup is at the end of life, try a cd cleaning kit or take it apart and gently clean the laser lens with a Q-Tip and rubbing alcohol and allow several minutes to dry. No change! the laser pickup assembly will need to be changed, not cost effective to repair far cheaper to replace.
Jul 06, 2012 | Philips CDR880 CD Player
I have a philips hts6510 home theatre system and when i put a dvd in to play it says no disc
hi,
Normally a dvd player shows the message NO DISC when,
1. The disc inserted is bad.
2 The lase pickup unit inside the dvd lost its reading intensity, dirty lens or the spindle motor damaged .
In your case the second one happened. the intensity of the laser pickup unit has lost or the spindle motor faulty or there is some dust on its lens. just insert a cleaning cd in it for two or three times. then check again is the DVD is reading or not
if the problem remains then you have to check the motor and the laser pickup unit. the lase pickup unit have two laser emitter and receiver in its inside . one for reading and playing DVDs and the other for CD and MP3. also the spindle motor runs in different speed when u insert dvd and cd.
Open the cover of your dvd player and power it on insert an audio cd and watch is it reading or not also notice the speed of the spindling of the cd. if the audio cd reads and play. then the possible problem is the spindle motor
To conform it remove the audio cd and insert a dvd. watch the rotation of the dvd. if it feel very hard to rotate it then, the spindle motor is damaged. if so replace the spindle motor if it runs more the the speed of than audio cd then the laser pickup unit is faulty. Then u have to replace the laser pickup unit.
if you need any further assistance from me , feel free to contact me through fixya.
ok
Jan 16, 2011 | Philips HTS-6500/37 System
The handset reads "Initial". Everything
The problem is with the base unit (charger) u can use the handset with another unit
Nov 30, 2010 | Philips CD-150
Nad 502 CD will not recognise and play CD every time
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens, or misaligned loading mechanism. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more
Sep 14, 2009 | Teac CD-P1250 CD Player
Reads no disk
((((NO DISK))))
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Apr 13, 2009 | Philips DVP5960
PHILIPS CDR 606 RECORDER. I was useing the above machine till yesterday without any problem at all. Today i keep getting message "insert CD" after i have put a cd in.. I have tried differnt...
Either the optics have failed or the lens is dirty. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. Basically the unit can not read the disk and is requesting that you insert one. If the cleaning fails to resolve the problem, you will need to have the optics replaced.
Dan
Jun 13, 2008 | Philips Audio Players & Recorders
My tv dvd combi 21pt6820/05
These units use a belt for the loading mechanism. If the belt slips at all, the loading will not complete and lock. This will prevent the unit from reading the disc. Try loading a music CD. If hte CD plays ok, then the optics assembly is in need of at least a cleaning or replacement.
Dan
Apr 16, 2008 | Philips 27DV60S 27 in. TV/DVD Combo
I need a motor assembly for a philips dvd player
i used to repair dvd and cd players, the motor wont spin until the laser focuses on the disc, so you could have a faulty laser. also the mechanism sometimes comes as a complete assembly. which will cost more than anew unit
Mar 27, 2007 | Philips DVP5140 DVD Player
214 people viewed this question
 Grubhead
Grubhead
