Question about Amcor AL10000E Air Conditioner
Seams to be runing right but not geting cold - Amcor AL10000E Air Conditioner
Fridge not geting cold
check door seals if ok move temp sensor to middle of coil
Jan 09, 2014 | Dometic RM2652 Refrigerator
If my trubo diesel 6.5 chevy if the timeing is off it wont stay runing if i fix the timeing well that make it idelthat was 1 of the code that came up its geting fuel u give it gas it well run u let of
Yes timing is everything with motors if the cylinder isn't firing at the right time all u are doing is filling the cylinder with raw fuel and dumping it into exhaust un burned it can eventually ruin you're catalytic converters also, get it professionally timed you're truck will run like a champ, unles u already caused damage.
Sep 12, 2012 | Fiat Cars & Trucks
2004 Blaster 2 stroke 200cc fires but well not kick start
check your compression. piston rings might be ate up and its time for a rebuild.
Mar 24, 2012 | RTO 200cc Full Size Four Wheeler ATV
My GE refrig. Model dss25srdss runs but does not get cold at all I opened the back panel the compessor runs and so does the fan but the fan seams like its runing slow.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 24, 2011 | Refrigerators
Arms dont spin---d/w buzzes
pump is not runing or it is not geting water
Sep 26, 2010 | Dishwashers
1992 firebird run good then it jist stop runing
Have you changed the fuel filter? Does it start and die right away, or does it take a few minutes?
Aug 19, 2009 | 1992 Pontiac Firebird
Refridgerator freezer not geting cold
Your compressor has shorted out. The compressor shouldnt be scorching hot just warm. And that humming you are hearing is the compressor trying to start but it is shorted. There is nothing you can do except for replace the compressor.(or the refrigerator)
Nov 16, 2008 | Whirlpool Freezers
Amcor AL10000E Air Conditioner Logo
35 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Bill Long
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
