Sharp mx5111n not printing
Dialog says job completed but document does not actually print
SOURCE: Deleting - Printed
I've also had this problem with an HP LaserJet 4650dtn printer. I've solved this by: - Stop the "Print Spooler" service. - Delete all the existing print spool files. (Stored in "C:\WINDOWS\system32\spool\PRINTERS" by default). - Start the "Print Spooler" service. - Right-click the printer's icon in the Printers and Faxes folder and choose Properties. - Click the Advanced tab. - Click the Print Processor... button. - Make a note of the existing "Print processor" selection on the left (in case you need to revert it.). Then change it to "WinPrint". Click OK. - Click OK on the printer's properties window. - Try sending a print job to see whether it persists in the print queue.
Posted on May 15, 2007
  • 30 Answers
SOURCE: HP LaserJet 1020 Prints a Black Line when at the right side when using Ms Word 2007
First, you need to try update the latest microsoft office patch file from microsoft or you can open the MS Word, go to "HELP" menu select the update MS Word or related. Try the latest patch file first. You also can try windows update and select custom update, see their list have this problem solution or not. Second, you need to go to HP website download latest driver for LJ1020 and suitable use on Vista. Lastly, if still not solve the problem, you need this problem/issue to microsoft, ask their solutions. Kent
Posted on Aug 23, 2007
SOURCE: HP 2600n can't cancel the last document
SOLUTION!! We have had a 2600n and a 1022n with the same problem as this. Changing the print processor to "RAW" and/or from ZIMFprint to WinPrint did no good in our situation (though I hear it works for Vista clients). We played around with it for several days, researching, testing, trying different methods, and FINALLY - FINALLY! - came across something that worked in both of our situations....
Hopefully, this will work for you as well: On the machine/server where the printer is installed (whether as TCP/IP or otherwise) -- In the printer properties, under the "Ports" tab, you should UNTICK THE BOX for "Enable bidirectional support" -- in other words, you need to disable bidirectional support.
(In case you're wondering, I cannot take credit for this -- I finally found this fix at the following location: http://forums.whirlpool.net.au/forum-replies.cfm?t=916989 ) :)
Posted on Apr 10, 2008
SOURCE: Lexmerk Z600 Series Printer won't delete document after printing
I've got exactly the same problem. So frustrating.
Posted on Oct 12, 2008
SOURCE: My printer won't print ADOBE files, but prints all word documents
I believe you are misunderstanding what you're "telling" the computer to do. You are telling the computer (I assume in Microsoft Word, but perhaps elsewhere) to generate an electronic document in PDF format. (I believe PDF stands for Portable Document Format)
It uses a printing metaphor because like a paper copy, the PDF file is designed for people to read, not edit the document you have created. Also, some PDF-making software methods involve pretending to be a printer, which allows the user to make a PDF file in any program that would normally only output your work to a printer.
Most people, when wanting to print a PDF document onto paper, open it with Adobe's Acrobat Reader (which is free software) and print the document from there. For sharing a document that you want no changes to, this is a superior option to sending people an MS Word .doc (or .docx) file, which does not have its information "locked" onto virtual pages in the file.
I hope this helped!
Posted on Jan 18, 2010
I just installed driver for my mac to mx5111n printer. When I print a page from my computer the printer heats up and acts like it is going to print, but never picks up a page from the tray and never prints...
It sounds to me that you haven't installed the correct driver. Visit sharp.co.uk and download the PS driver from the download centre. Hope this helps.
Jun 18, 2014 | Sharp MX-2300N Color Copier
Documents in printer que, but does not print
If a print job get hung up in the print que it may stop and not be able to be deleted, this will also block other print jobs from printing. Here is a link to an article that shows how to clear the print que and purge the stuck print jobs so printing can resume. I hope it helps.
http://www.ccl-la.com/blog/index.php/how-to-delete-print-jobs-that-are-stuck-in-your-print-queue/
Dec 10, 2012 | Sharp Mx-2310u Color Copy/print/scan
Sharp MX-2610N printer can't set-up the print job (for labels from by pass tray) from my desktop computer.
Some documents like word override the settings... you need to change/save within your document you are printing. page layout and then page set up
Sep 16, 2012 | Sharp MX-2300N Color Copier
Prints job details before each print job
in setting tab>print ? setting you can off this option
May 23, 2012 | HP LaserJet P4015N Printer
How do I print ONLY in black and white? I can't seem to find the properties in the printer dialog box. Help! Thank you, Kim
You need to find the Color Options Features Tab; choose greyscale or Black Only.
Follow these steps to change the print settings for a single print job in Windows 7.
1.Open the document that you want to print. Click File , and then click Print . The Print window opens.
2.Click the button that opens the Properties dialog box. Depending on the software program, the button might be Properties , Options , Printer setup , Printer , or Preferences .
3.In the Properties dialog box, select the print properties for the current print job, and then click OK .
Follow these steps to change the default print settings for all print jobs.
1.On the Windows taskbar, click the Windows icon, and then click Devices and printers .
2.Right-click the printer icon for your product, and then click Printing preferences .
3.Select your new default print settings, and then click OK .
Dec 11, 2010 | HP Photosmart C6180 All-In-One InkJet...
WHEN I AM TRYING TO PRINT THE PDF FILE , I AM GETTING DIFFERENT MARGINS COMPARED TO ORIGINAL PDF FILE.SOME PRINTER IT IS ACTUAL AND SOME PRINTER IT IS DIFFERENT.HOW TO RECTIFY SUCH PROBLEM.KINDLY...
Acrobat reader scales pages on printing, depending on the printer and its driver. By default, Acrobat Reader will use one of the scaling options.
Before printing the PDF document be sure that you select the right kind of paper size such as A4, Letter and B5 which will be printed. Paper size is defined in the Document Setup dialog box for the document.
To print the document without different margin problem:
- Open the Acrobat Reader’s Print dialog box (Choose File > Print).
- Choose “None” from the “Page Scaling” drop-down list. (It will not change until you change it again).
- Then click “OK” to print the document.
This may solve your problem.
Mar 22, 2010 | Adobe Acrobat 6.0 Professional for PC
How to delete password protected pront job in Sharp mx-2700N when password is lost? I can log in as admin (web-access to printer) but cannot delete the documents in Documenthandling. BR, Steven
Open web interface of the printer and supply admin password.
As an administrator you should be able to navigate to the System Settings screen.
Select Document Filing Settings and navigate to the section Administrator Authority Setting.
Select Delete so you can delete forgotten print jobs (remember to Save the setting).
Navigate on Document Operation where you can see a list of existing saved print jobs.
Select the jobs to delete and go on.
You don't have unwanted ghosts anymore on your machine!
Most important: always remeber to smile and to help people. Take care.
Jan 05, 2010 | Sharp MX-2700N Color Copier
We have a spooling problem. The sharp mx-2300n just says "ripping" and 20% complete but won't move from there and print anything. Can cancel print job from Mac but won't stop anything at the printer end....
Go into the Job review mode and highlight the pending print job (note: it may be stuck in processing). You should then get the option to delete the job.
Make sure that the pending print job is also cleared from the network print queue. They can sit in the queue and be persistent on processing, even after you've cleared the copier. Clear the queue prior to deleting the job on the copier.
If this doesn't, disconnect the copier from your network and try the above steps again, then reboot the copier and reconnect it to your network.
If you're trying to print out Adobe-based web pages from the internet, this may be what's causing your copier to jam up. There's known coding anomalies with Adobe-embedded documents on web pages. Trying to directly print from the web page can stall or lock up the print process.
Sep 07, 2009 | Sharp MX-2300N Color Copier
Not printing the whole of the page even all in black ink some parts are randomly missing
Install Temporary Drivers:
Step one: Install a temporary print driver
1. On the Windows task bar, click the Start icon, click Control Panel, and then double-click Printers and Faxes.
2. Click Add a Printer.
3. In the Add Printer dialog box, Select USB001 port, and then click Next.
4. Under Manufacturer, scroll to and click HP.
5. Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
6. Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
7. In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
8. Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
9. Click Finish to complete the installation.
Step two: Designate the temporary print driver for two-sided print jobs
Follow these steps to use the temporary print driver each time you print a two-sided document.
1. In the program you are printing from, click File, and then click Print. The Print dialog box opens.
2. In the Name drop-down list, click hp DeskJet 990c, and then click OK to print.
Aug 18, 2009 | HP PSC 1350 All-In-One Thermal Printer
SHARP MX-2300N
Someone has sent a print job from a computer to the copier with an odd paper size specified. Go to Job status, under "print" highlight the first job in the que and delete it. (if the job was sent more than once you will have to repeat. ) Check the document and print settings of the offending document.
Dec 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
152 people viewed this question
k24674
jasbo
jasbo
