DCM5090/10 CD assembly unit
Cd Unit is not working and needs to be replaced.
SparkGap
  • 363 Answers
SOURCE: cd ejects
There is a varety of causes of ejection of a CD in any player. If the ejection is immediate it may be:- Incorrect length fixing screws fouling mechanism. Faulty eject button Fauly mechanism position sensor/switch Misaligned mechanism Causes of ejection after the disc spins up:- Disc upside-down Incorrect format i.e MP3 data disc in standard CD player Incompatible CD-R type Badly scratched disc Warped disc Player out of calibration Hope this helps
Posted on Sep 21, 2007
  • 38 Answers
SOURCE: Stuck CD cassette
Dear needhelp5246,
What you need is a screw driver not a sledgehammer. Open the bottom plate of the system and eject the cd magazine manually. Hope this solve your problem.
ramesh22
Posted on Jun 15, 2008
  • 31 Answers
SOURCE: CD drawer will not open or close
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Posted on Sep 17, 2008
  • 4 Answers
SOURCE: Question
I am 99% certain that it will only work with 'audio' discs. This is the case with my Philips CDR-796 and as far as I am aware applies to all consumer CD recorders.
Hope this helps
HifiJohn
Posted on Jan 05, 2009
leecom72
  • 4806 Answers
SOURCE: how do i remove acer aspire 5670 keyboard to replace cd/dvd unit
Hi there.
Push the screen back
Lift up the keyboard bezel using a small flat-head screwdriver.
Continue removing the bezel with your fingers.
Lift up and remove the keyboard bezel.
Remove two screws securing the keyboard.
Lift up the keyboard and place it on the laptop cover so you can access the keyboard cable connector.
Unlock the connector and pull the cable.
Remove the keyboard.
Good luck and thanks for choosing FixYa!!
Posted on Sep 04, 2009
I have an old SHARP mini component systen and everything works except the CD player. It says ER CD-10
Laser assembly is probably ng and that part of unit needs replacement if it is not a proprietary design. If so, forget it since it will not be cost effective.
Aug 28, 2017 | Sharp Audio Players & Recorders
Replacing laser assembly/mechanism on Denon DN-C635 CD player.
Don't usually have to do any alignment when replacing the pickup.
Mar 13, 2013 | Denon DN-C635 CD Player
ACOUSTIC 1 CD unit will not play certain CD's
Hi Marva,
Here are the three possible problems according to your description in order of probability. One is that the laser needs cleaning. Two is that the laser is getting weak. Three is that the motor is not spinning the cd up to speed fast enough so that the table of contents can be read. The thing to try first is to take the unit apart with the power disconnected and clean the laser lens. A cotton swab dabbed with Windex usually works great. If that was not the problem, look at the motor spinning your cd. If there are any tiny openings in the motor put a drop of 3 in 1 oil in the opening and let it sit for awhile. The third of course involves replacing the laser assembly. Good luck. - Joe.
May 01, 2010 | Audio Players & Recorders
It plays the same section of the CD over & over...goes back & starts again...allCDs same... unit is 7 years old
In order for an entire CD to play, the optics assembly must travel toward the exterior of the disk. From your description, something is preventing this from happening and the CD player is continuing to play in a restricted area. If the model is CDP-CD355, the optics assembly is on its side. This unit needs service and should not be opened by a homeowner. This is not a unit I would recommend for a DIY repair. This repair is not likely to require parts, but could. It may only need a cleaning and re-lube of the sled rail assembly.
Dan
Mar 03, 2010 | Sony MegaStorage CDP-CX355 300-Disc CD...
BMW CD Changer MP3 player is connected to power and i-bus in e39 (1999 BMW 528i). When I press the button on the display monitor to toggle between Tape and CD, most of the time the CD does not show up (it...
in the unit there are two things that you will have to check
1) one is the lens which reads the cd in the unit.
2) second is the gear that moves up and down to the tape/cd.
if the lens is not getting adjusted after you turn it on/off then this problem happens also if the gear is not moving properly then also same problem occurs.if the gears are getting blocked then also this happens.as you mentioned it works that means the unit is not faulty but there is minor problem in lens or gear assembly just get it resetted by checking it.also local electronic repair shop can realign the unit.the unit need proper servicing to get it work properly.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 31, 2009 | Car Audio & Video
I have an old Sharp CD-C811W mini hi fi system which I took apart to try to clean the lazer head. Since putting it back together the CD's keep skipping - what did I do wrong - help please
You've probably done nothing wrong: presumably there were symptoms which initially prompted you to open the unit up to attend to the head. It's possible that you've left a smear on the laser lens or some grot on the head guide rails, but CD/DVD lasers do not last forever and as your unit is an old (and cheaply built) unit the laser head unit has probably worn out.
If you can find out the exact CD drive assembly fitted to your mini hi-fi then if you're lucky you may find a replacement head assembly (Earth yourself, unclip the guide rails, lift/slide the ribbon cable clamps and remove the assembly, reassemble in reverse with an imperceptible smear of HMP grease on the guide rails).
Unfortunately you're highly unlikely to find an original or even a compatible laser head assembly simply due to the extremely short production cycles of these items due to constant improvements in design. Good, used, CD mini hi-fi's are ten a penny so if you can't get the part for less than £15 then bin it and replace the entire CD system.
If you need it a service manual for your model is at the address below. Please return the favour by rating my answer; I only regret that I could not give you a more positive outcome.
http://www.eserviceinfo.com/downloadsm/25489/Sharp_cd-c811w.html
Sep 21, 2009 | Audio Players & Recorders
Cd stuck, discread on display
If you can access the in-line fuse on the constant 12+ volt lead that powers the units memory. Remove that fuse and wait 5 min. then replace it. This should reset the unit, allowing you to eject the CD.
Note: If the anti-theft code has been enabled, you will need to input that code in order to operate the unit.
If the CD still does not eject, it may be jammed/binded up. thus requiring dis-assembly.
Good luck...
Feb 23, 2009 | Alpine CDA-7892 CD Player
ER!!!
Nope I'm afraid that when this happens, the slider motor is bad, the spindle motor is bad, or the laser pick-up assembly needs to be replaced. You can replace this unit for about 20 bucks. A laser pickup for this unit will cost about 25 to 35 bucks + labor!. See mt point? Good Luck
Jun 19, 2007 | Audiophase CD315 Personal CD Player
131 people viewed this question
 Grubhead
Grubhead
