PLDED3992A-C PROSCAN I was attempting to change the SOURCE selection to HDMI3 to watch a DVD and I must have done something wrong to where the screen is black. I've tried unplugging the television, and hold the SOURCE/MENU buttons down but nothing is happening. Television was just purchased two weeks ago.. Need help trouble shooting
techman
  • 3130 Answers
SOURCE: Problems With RCA Television (Gray Screen)
Your problem is the old rca tuner sheild repair thingy. Its a simple but tricky repair where the tuner grounds around the tuner sheild and under the bottom of the tuner sheild has to be resoldered. Most repair shops in the states that i know of charge like 65 to 125 .00 to do this simple repair. Now if you know how to solder you can get this reapir mod from sams photo facts and do it your self but its really an involved thing if you dont know what your doing as some of the serface mounted parts look like a spec of dirt and i've seen a few peeps clean off those specs and ruin the whole set. Best for you to take this set in for a repair. Good luck
Posted on May 05, 2006
  • 1153 Answers
SOURCE: how to use av on a lg television
Did the dvd start, if so can this be a bad dvd player. It could need cleaning. Have you tried another device, like vcr or another dvd
Posted on Sep 14, 2007
retrohack
  • 27 Answers
SOURCE: Akai television
 This model is notorious for power supply problems (mainly bad filter capacitors). They are large electrolytic capacitors located at the top of the switch mode power supply (SMPS) board. Most of the time they are easily spotted (the tops are pushed out in a dome shape rather than the flat top they are supposed to have) but it could be something that is not so easily detected. At any rate, the power supply is probably to blame, and will have to be serviced by a repair tech...
Hope this helps you out....
Posted on Oct 21, 2007
donutty
  • 22 Answers
SOURCE: Timer on television
The user manual is available here:
Pioneer website - PDP5060HD
Setting of the sleep timer is on page 58, quote:
You can also use the menu to set the Sleep Timer.
1 Press HOME MENU.
2 Select “Sleep Timer”. ( / then ENTER)
3 Select the desired time. ( / then ENTER)
4 Press HOME MENU to exit the menu.
Posted on Feb 03, 2008
SOURCE: 2002 zenith console television
If you lost the remote for a zenith television and want play a movie on an input, use the channel up/down buttons to navigate. Ususally if your on ch 2, press the down button. Line 1/2 will appear on a blackscreen if the device is off. Otherwise, I have had great success using a GE universal remote with my Zenith tv/vcr combo unit. (by the way, I work for the technical support department for my city's local cable company)
Posted on Aug 13, 2008
My proscan tv 39 inch PLDED3992A WILL NOT POWER ON AT ALL IS THERE A RESET BUTTON.
Try plugging the TV into another known good outlet. If there is no change unplug the TV for 30 minutes to 1 hour. Plug it in and try to turn the TV on again. If you have the same result, you have a bad main board that needs to be replaced. If its under warranty have it repaired or exchanged. If your warranty has expired take it to your local TV repair shop. Hope this helps.
May 11, 2017 | Proscan Televison & Video
My proscan plded3992a-c is flickering
Flickering can be adjusted. To some rare cases, the SMPS [Power] board might need replacement. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Jan 06, 2017 | Proscan Televison & Video
Pc hdmi no sound
some televisions require a seperate audio feed from the HDMI cable to hook up audio. if you have the cables for this i would try that first. normally ends up having to go thru an AV connection
Jan 16, 2014 | Proscan Televison & Video
Can't get input on tv to activate rca wi fi streaming media player
depends on what input port you plugged into. HDMI1 HDMI2 HDMI3
the tv input select source has to match
I have a similar device plugged into HDMI3 so I select on the input source HDMI3 to see it on the TV.
Dec 29, 2013 | RCA DSB778W Wi-Fi Streaming Media Player
WHAT INPUT DO I PUT TV ON TO WATCH A MOVIE USING A DVD PLAYER
Does not matter just use your connection cable from DVD player and identify the name of where you plug into and change source to there. Sometimes it will take a few seconds before dvd screen will pop up.
Dec 28, 2013 | Proscan 32LA30Q Television
No longer getting video feed through Home Theatre receiver
HDMI ports 5 and 6 on the back of tv no longer are working. (We had a series of thunder storms so don't know if that is how they got damaged or if it was something else) but moved HDMI input cable to HDMI port 4 on tv and everything is working again. Service call placed for warranty service on tv to repair bad ports.
Sep 14, 2009 | Sharp Televison & Video
"NO SIGNAL" message on screen
You need to press the INPUT button on the TV or the remote control until you've selected DVD as the signal source. Then you'll be able to watch the DVD.
A manual is available for download from the website tv.manualsonline.com. It's free, but they ask you to register. I've gotten many manuals through the site and it hasn't generated any spam emails or caused any problems.
Apr 07, 2009 | Proscan 19LB30QD 19 in. LCD HDTV/DVD Combo
Satellite input
Most tv setups require that you change the input source to gain the ability to watch the proper peripheral e.g. if satellite is connected on video one and the dvd is connected to the tv on another input such as video 2.
If the satellite runs into the dvd unit and from there the dvd is connected to tv you may have to power off or on the dvd player to resolve conflict.
Another problem may be the resolution setting if your tv is Hi Def. Set the tv and receiver to the resolution e.g. 1080i.
You can also changed the way the satellite is connected to the tv possibly if you have other inputs.
Check the channel also, if the unit is connected with coax it would more than likely need to be on ch 3 or 4 if you are at the satellite receiver box location. If you are at a stand alone tv off of a dual tuner you may need to search the channels for the right source both air(analog) and cable(digital).
Hope this helps you out. If I can be of more assistance let me know.
Sep 07, 2008 | Proscan PS60690 60" Rear Projection...
Televison & Video Logo
330 people viewed this question
Top Televison & Video Experts
Electro Med Services...
