Question about Home
A4913BO Shower valve Rohl #A4913BO is 7 years old. Can no longer adjust temperature. It is either real hot or really cold.
frcs68
  • 1605 Answers
SOURCE: Kohler 30 year old single handle shower valve - cold water only
Is this a dual handle or single handle? if it is a single handle
turn the valve 180 degree. if not, then check the cold water supply line.
Posted on Jan 07, 2009
  • 659 Answers
SOURCE: Triton T90si electric shower temperature stuck on hot.
It sounds as though the valve is not closing and opening properly. I would have a proffesional come out to have a look. I could also be the control board not working correctly or a combination of both.
Posted on Mar 22, 2009
  • 744 Answers
SOURCE: My Mo's shower is about 6 years old. I think the
Sure - there is always help at FixYa!
This sounds like a bad cartridge. They can be replaced. To replace the cartridge:
Turn off the water to the tub/shower.
Remove the handle cover (it should pop off)
Remove the center screw (usually phillips head)
Remove the retaining clip holding cartridge in - you can use a pair of long nose piers or a small screwdriver
Grab the cartridge with a pair of pliers and pull straight out. It may require a little force - there are O-rings around the cartridge to keep it from leaking.
Check the cartridge bore (the hole where the cartridge was removed)
Clean any debris or scale - lime away or CLR will work
Apply a little bit of soap around the new cartridge to help it slide in easier. Push it all the way in and make sure it is seated. Re-install the clip (you should have received a new clip with the replacement cartridge)
Turn the water back on a check for leaks
If OK, reinstall the knob screw, and cap.
Let Mom take her warm shower...:)
Posted on Dec 13, 2009
Testimonial: "Thank you very much. I will try my Nursing expertise at fixing this plumbing problem, darn economy I wish I could afford to hire a plumber. Thanks. "
  • 349 Answers
SOURCE: adjusting the scauld guard on a shower mixer valve
Uue a 1/8" allen wrench to remove handle to access the dial that set's the mixture of water.Remember or mark where it is and remove and reinsert counter clockwise about a 1/4 turn to start to you reach desired temperature setting. Be careful not to set it at a hot enough setting to burn you.
Once dial in place slide handle on and turn on to check water temperature.
Posted on Aug 01, 2010
Magaiver
  • 707 Answers
SOURCE: Valve will not mix enough hot water with
Their is a mixer valve if it is a one handle unit which is built in. It may be one half turn out of timing.
Posted on Aug 10, 2010
Is it possible to adjust shower mixer temperature?
Now my best guess is that you kept heater too high for a long time which means that the pipe carrying hot and cold water got touched and water became hot So turn off the heater for while and let the pipes cool off then turn the heater on at a low setting ...
Aug 30, 2014 | Rubinet Home
Shower force
Are you wanting to change/switch the hot and cold range of the shower or the temperature max and min? As for the range, the Monitor pressure balance valve may be having build up or problems. This valve controls the mixture of hot and cold water. To fix this, you will need to turn off the water supply, take the pipes apart and clean out the valve (I would recommend a professional). As for the max and min, you may just need to check the water heater pressure in your house. It may not be the faucet at all.
Elisa Jed ' http://www.ryansallglass.com/
Feb 18, 2014 | Delta Home
To adjust hotter
Your shower has been installed for a while and you are noticing the dial must be turned further and further to the hotter settings to get a normal shower - In this case the filter on the hot inlet is getting clogged with debris. Refer to the cleaning instructions in the manual that came with your shower, or contact Hansgrohe USA by calling 800-334-0455 for the documents.
If your installation is brand new or old, debris on the filter is the number one cause of this problem. You can test it by noticing if there is a drop in pressure when you dial to a hot setting as opposed to the cold setting. The drop in pressure indicates dirt on the filter where water has a tougher time getting through.
Filters on a shower valve may seem strange to US consumers. Your old two handle valve system woul run for years without needing servicing. Now you have filters to deal with. These filters, like any filter need to be cleaned periodically and the frequency depends on the quality of your water supply system.
The real benifit, is that the filters protect your smart valve and the shower head from malfunctioning due to debris.
Aug 31, 2011 | Hansgrohe 06642000 Chrome Solaris Single...
I have a hudson reed Twin Concealed Thermostatic Shower Valve. It was working fine for a couple of years. My brother used the shower and adjusted the water temperature valve but since then the water has...
Sounds to me the diffusor is stuck or broken in the position to allow only hot water through it.Looks to me tou have a mixer valve on it. Might have to replace it.
May 31, 2011 | Hudson Reed Home
We have a home that is 3 years old. We never used the 3rd bathroom shower until today. We have a Moen single knobe shower/bath valve. To get water from the faucet you pull the knob out. To adjust the...
Remove handle to gain acess to the temperature limit stop. Remove handle and pull out handle adapter kit and next there is a dail that can be adjusted to control the water to balance the temp. It could have been installed wrong, pay attention to where it is now and pull it back to it disengages out of the stem and move it counter clockwise a little and reinstall. Put handle on and test water for correct movement.
Go to link below for a part's diagram if needed.
TO ORDER PARTS CALL: 1-800-465-6130
www.moen.com
Aug 15, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Temperature too hot on bristan art deco mixer shower even on lowest temperature setting.
if the water is that hot then lower [adjust] the temp of your hot water heater -if need to adjust the shower you can adjust the mixing by removing the handle and on the valve stem are the adjusting clips the red [hot] and blue [cold]plastic clips can move them around to adjust the mixing of hot and cold water
Jul 23, 2010 | Home
Shower water temperature regulation
The temperature is adjustable. The valve has a disc you pull off the front of valve and then rotate the seat I believe counter-clockwise. If you get the paperwork for this valve from moen it is very explanatory. I can help further if needed, Let me know!
Nov 10, 2009 | Moen & One Handle Tub & Shower Faucet
Bath tub water doesn't stay hot
it is because the tub has a temp control valve in it so if you were to put more cold with the hot it will last longer but still won't be all the way hot,, now a days people are suing the manifacture because they are getting burned form the hot water so they put these saftey temp controls in place of the old style 2 or 3 handle faucets,, there fo no more real hot water nothing you can do outside of change to the othere type of faucet 2 or 3 handle tub shower diverter,, that why the water is hot in the sink but not the tub.....
Jun 23, 2009 | Water Heaters
Not enough hot water, has to do with a shower valve
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
Feb 21, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Shower temperature too hot
Shower valves that have anti-scald features are renowned for this problem. Usually it is caused by not being used regularly. It can be repaired usually without replacing the valve, but you will have to dissemble it, clean, and use some plumbers grease to reassemble it. It should work fine after this. If it still does not work you will need to replace the cartridge.
Dec 10, 2008 | Peerless Industries Peerless& Single...
Home Logo
57 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
