Question about Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button...
Refrigerator Door Reversal
My fridge (freezer above) is left-opening and I'd like to switch it to open from the right. The frame and door are drilled for this, but I'm not sure whether all the hardware can be switched or whether new, left-side brackets will be needed. Are fridges of this type designed to permit a change without acquiring new hardware?
  • Anonymous Feb 24, 2008
    how do I reverse the fridge freezer doors from left to right? How do I physically do it?
You can switch most makes without extra hardware
Posted on Aug 28, 2007
SOURCE:
Refrigerator section stopped cooling, but the freezer section still works.
Hi. There is a valve in the top corner of the frigde that controls the cold Air to flow from the freezer to cool the fridge. This valve called a damper closes when the door is opened. You have to depress the door switch and listen for the fan in the freezer to switch on then feel for cold air to flow into the fridge compartment. The fan could have failed or the damper valve could be stuck closed.
Jun 05, 2016 | Maytag MFF2258VE
Whirlpool refrigerator door reversal
Check with supplier first but almost all fridge bodies are made for reversal
Apr 22, 2012 | Whirlpool Refrigerators
Switching door sides
some model you can, some you can't....if there are pre drilled holes with plastic plugs on the opposite side you can....you will need to purchase hinges and maybe handles.
Jul 24, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Mod# RFG297AA:Need to remove the freezer section or handle/latch
there are two screws on each side of the bottom freezer unit you need to remove. they can be removed after de-installing the front bin with the two plastic sleeves on the right and left. Then you can remove the bottom drawer door and the bins inside. next, open both top doors and angle the fridge with one door inside the door frame, then "walk" the fridge over the doorstoop, turning towards the inside door as you push. Follow thru with the rest of the unit, then re-attach the bottom drawer.
Apr 08, 2010 | Samsung RF265AA Bottom Freezer French Door...
When I shut the left door the right door pops open, it is always open.... I need it to stay shut
put some heavy stuff on the door like soda or water bottles,also wash around the frame where the door gasket touches the fridge and wash the gasket too, there are magnets inside the gasket and if there's anything on the frame it could stop the gasket from making a good seal,how old is the fridge?what shape is the gasket in?if it's torn or lost it's shape it should be replaced.most likely you might just have to get some weight on the door to stop it from popping open
Mar 07, 2010 | Maytag MFD2561HE Bottom Freezer French...
I have a hotpoint hss22gft that the refrigerator side will not stay cold. freezer side is 10 degrees. any suggestions
if you have an abundance of snow/frost on the back wall of your freezer, you have a defrost problem, heater, thermistor, defrost thermistat, or the main CPU could be the problem. If you have no abundance of frost on back wall of freezer, with freezer door open, "close" the door/light switch. Does your freezer fan run? if not, you have a faulty fan/possibly your main CPU as well. if you fan does run, then the damper door, which opens to let the air from the freezer into the fridge is not opening. close the freezer door, open the fresh food door, "close" the light switch on that side, and place your hand near the vent at the top left side of fresh food side. air flow? if no, bad damper door. if yes, check for any gaps in door seal, tears rips or malformations. if none of the above help, seek technical service
Feb 15, 2010 | GE HSS22GFT Side by Side Refrigerator
Help . Change doors from right to left opening
first remove the door from the fridge, remove the hardware connected to the fridge, on the opposite side should be rubber or plastic caps covering some bolt holes. remove caps and install top of hinge transfer everything you see on the left to the right
Oct 21, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Samsung refrigerator - frost on outside of freezer drawers
try checking the freezer door seal.
if slight gap anywhere around the door seal drawer fronts will frost up.
warm seal up with hair dryer and ease seal out with your hands..
problem often happens with door reversal.
Oct 09, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Refridgerator beeps and upper section not working
First, the Samsung Refrigerator is the only fridge that has one compressor, but two different evaporators to operate the freezer and the refrigerator separately. Thus, you can have the bottom freezer working fine, while the fridge part will not.
The reason your fridge is not working is probably a faulty door switch in the refrigerator. The switch is malfunctioning, telling the computer that the door is open. Therefore you hear the door alarm go off in intervals, even though the door is actually closed. If the computer registers an open door, it will not pump cool air into the refrigerator, as that would be a waste of energy. All you need to do is replace the door switch. Until you get a new one, you can temporarily fix your fridge by simply removing the old switch altogether. You will not have any light in the fridge, however, it will cool again just fine until you are able to install the new switch (a simple plug-in contraption, by the way).
Hope this helps.
May 28, 2009 | Samsung RB2155SH Bottom Freezer...
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button... Logo
229 people viewed this question
Top Westinghouse Refrigerators Experts
John Tripp
John Tripp
Ekse
Vincent G
Vincent G
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
