Question about Dehumidifiers
Airforce climate control kfr-35g/nab20-j
Not cooling air
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: AIRFORCE CLIMATE CONTROL HIGH PERFORMANCE
Hi and welcome to FixYa, I am Kelly.
Per the model number you provided in your post (WDDH-820EAH) this is your user's Manual:
http://www.orientalpacific.com/backend/files/products/manuals/127/WDH-820EAH%20User%20Manual.pdf
Note the comment about air filter cleaning on the back of the unit every 2 weeks.
Thanks for choosing FixYa,
Kelly
Posted on Dec 27, 2010
We have two Danby Premiere Dehumidifiers. Both have stopped picking up water. The filters are clean, the fans run and there is alot of moisture in the air? Any ideas on how to fix them?
I assume that you have already:
  • Emptied the water buckets.
  • Are sure the buckets are properly in place.
  • Are sure the bucket switches are not stuck in the full bucket position.
  • Cleaned the cooling coils.
  • Verified that the controls are set for a low humidity
  • Verified that there are no trouble lights or codes,
  • Know that the area to be dehumidified is well above freezing..
It sounds like they are both stuck in defrost mode or the compressors overheated and need to cool off. "Both" is a bothersome word. Both might imply a power surge that wiped out the controls. I would:
  1. Unplug them and let them cool off 36 hours.
  2. Check your manual for a control panel reset.
  3. Take off whatever covers I could, to let me touch the cooling coils to be sure they get cool.
  4. Plug in # one and reset the panel.
  5. Let it run and see if the coils get cold.
  6. Plug in # two and reset the panel.
  7. Let it run and see if the coils get cold.
And then decided what to do next. Hopefully the cool off and reset did it .
Good luckl.
Jun 07, 2015 | Danby DDR60A1GP 60 Pint Dehumidifier
B q dc20 airforce dehumidifier
I do not repair items, I am an engineer. Contact the manufacturer for a list of repair stations, many now do a flat rate.
Price one on the web and as a general rule if it is under $250 it is probably more cost effective to replace it.
Jan 25, 2014 | Dehumidifiers
Looking for a manual for a airforce dehumidifier no, bqwdh/816eah
Call the company look online they might have it or call the manufactor.
Dec 29, 2012 | Dehumidifiers
The motor seems fine, but it no longer collects water or helps the clothes dry. It is an Airforce model BQDD122FW. If it is the heater element, how much should it be to repair, roughly?
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Feb 20, 2011 | Dehumidifiers
AIRFORCE CLIMATE CONTROL HIGH PERFORMANCE 20 LITRE A DAY DEHUMIDIFIER WDDH-820EAH - Hello can you provide me with basic instructions for this as i have lost my manual. Thanks
Kelly
Dec 27, 2010 | Dehumidifiers
My coils are freezing up
Make sure the filter is clean and plenty of air comes through, when coils freeze it is usually caused by low air flow coupled with lots of humidity and low air temperature in the space to be cooled. Clean the filter, fan and gently brush all dust and debris from the intake of the cold coil and retry it. If the basement is already cool and you are trying to dehimidify you should use a dehumidifier that features defrost controls.
May 26, 2010 | Whirlpool AD50USS Dehumidifier
I have an Airforce BQDD122FW Dessicant Dehumidifier. When I bought it last year it worked OK. I have started using it again this year and although the motor appears to run normally it no longer collects...
Hi There, you have faulty heater inside. They are all the same Delonghi, meaco, Logik, ecoair .Airforce
I have done 100s now. If you good you can just twist the wire in the heater and will go again without any problems.
Its just basic steel wire twisted like a spring.
anyon eneeds help sam on 07590 057545
Oct 24, 2009 | Dehumidifiers
Kfr 24w condensor will not run
Check the contactor to see if the contacts are stuck or welded together, if not check to see if you have 24 volts to the contactor, if you do then the thermostat is not opening.
May 17, 2009 | Comfort-Aire BHD-301 Dehumidifier
Dehumidifier efficiency
I'm surprised that you are trying to dehumidify if you are in the northern hemisphere right now.
But, before you go off trying to fix the refrigerant, see if you can get a glass of ice water to sweat near the dehumidifier. While relative humidity might be high in cold climates right now, it's a relative number, as the total grains of moisture is far lower than what it would be in a warmer climate. Cold air saturates easier, because it holds less, moisture.
Most people use a humidifier in the winter because they want to saturate the air with water, which is better for the human body, and minimizes static electricity.
I can help you diagnose the dehumidifier if you want. The coil should only get to 40 degrees or so. But the sweating glass of water will tell you if there is enough moisture in the air for the dehumidifier to wring out.
Jan 30, 2009 | Haier HDN655E Dehumidifier
EHUMIDIFIER RUNS FINE BUT NO WATER IN BUCKET
I had the same problem and went for the s**t or bust option, worked for me.... The pipe that feeds water into the bucket had become 'silted' (clogged up and causing water to flood the floor) so I shoved a pencil up it and wiggled it about. Has been perfect ever since.
Nov 28, 2008 | Maytag M7DH45B2A Dehumidifier
Dehumidifiers Logo
207 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
