Question about Avaya 4412D Corded Phone
Phone set up
We have several phones and i need all of them to have the same time on the display board. i need step by step instructions on how to do that.
    Novelist:
  • 201 Answers
This phone is a Merlin Magix system phone. The time is stored in the main control unit, not the telephone. You have different times on different phones??? I do not see how this is possible unless the clock is broken and not updating the phones with the correct time. If that was the case every time you unplug a phone and re-connect it the time may be reset to 12:00 on that phone. Avaya has all their manuals available on their web site. I'd suggest going to www.avaya.com and searching for "Magix time"
Posted on Aug 29, 2007
SOURCE:
How to divert an incoming call?
There are several methods. Phone company provided call forwarding instantly sends calls to a phone number you set on your main phone line, that you turn on with *72 + the destination # and turn off with *73. Or "Call Forwarding No Answer" that transfers the call after several rings to a pre-determined number, all setup by the phone company on your main line. Or, on the Panasonic systems (there are many), you do the same using several code choices, a bit more complicated. Your installer must set the system to allow the system to send calls to an outside line, and you must have more than one line because the destination number is dialed on a different line than the line that's receiving the call. Your Panasonic "Operating Manual" lists these codes and methods with instructions, you'll find them listed in the table of contents under "Call Forwarding" with step by step pictured instructions.
Apr 09, 2014 | Panasonic KX-T7730 Corded Phone
How to flash nokia 5300
GO TO STORE........
Oct 01, 2011 | Cell Phones
Flash nokia 2700 classic
You need to flash it for what purpose,? You need to flash it to reset to original settings or security lock hang purpose? You can flash using software for that purpose,If you need to unlock it from Network lock using Flash method? You can use the Unlock code,that is best than software flash,.Get the Unlock code from here Theunlockspot and unlock it from Network Lock.Then you can use any GSM Network Sim card in the Phone....It's best for Unlock.....you can use the Flash software for De-brand the Phone also Removing Logo,Settings etc from previous provider...after unlock it de-brand will be Done.
To Unlock it step by step follow the instructions Below:
Nokia 2700 Classic Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Nokia 2700 Classic mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 2700 Classic mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 2700 Classic without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2700 Classic.
3 - Compose #pw+CODE+1#.
4 - The Nokia 2700 Classic would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 2700 Classic mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 2700 Classic
Aug 15, 2011 | Nokia Classic 2700 Cell Phone
How to do flash my nokia n72
There are many reasons to flash the Phone,Once for to remove the Mobile hanging problem,Unwanted files ,reset the Phone to original settings and remove the Network Lock,But if you need to flash it from Network lock means You can better use the Unlock code,Because Flash done using the software,they leads to data lose and Hardware crash,But Unlock code is best to Unlock the phone from Network Lock,Get the code from here
Onlinegsmunlock and Unlock it..You need to specify it locked Country,network then order code and Unlock it using the Instructions below enter the code in the Phone step by step...
Nokia N72 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Nokia N72 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia N72 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia N72 without any sim card.
2 - Don't bother as to what is displayed on your Nokia N72.
4 - The Nokia N72 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia N72 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
The CODE you need to enter is the unique unlock code for your Nokia N72
Jun 15, 2011 | Nokia N72 Cellular Phone
How do I get ring tone for my cell phone? I need step by step instructions. Is the app on my phone?
You don't need an app for that. Just copy the song that you want to use on your phone and you play it in the music player. While playing press Menu and Set as ringtone. Then go to Settings, then Sound and Display and phone ringtone to chose the sont as a ringtone.
Feb 15, 2011 | HTC Desire Cell Phone
Need to know how to change time on Comdial GCA70-281
  1. Programming the time and date for a Comdial Impact digital phone system must be done from the attendant's station, usually the phone located closest to the Comdial controller. Go to this station before attempting to change the time.
  2. Step 2 set-clock_thumb.jpg Now the phone system's clock is ready to be reset. Without picking up the handset, press the "Intercom" button on the phone. Dial * # 0 1. The digital display2.gif should read "Set Clock"
  3. Step 3 Set the year by dialing two digits (00-99)
  4. Step 4 Set the month by dialing two digits (01-12)
  5. Step 5 Set the day by dialing two digits (01-31)
  6. Step 6 Set the hour by dialing two digits (01-23)
  7. Step 7 Set the minutes by dialing two digits (00-59)
  8. Step 8 set-clock2_thumb.jpg Comdial Impact phone with updated day and time. Pick up the handset and set it back down to set the programming changes. The new date and time should display immediately on all phones connected to the Comdial system
Nov 04, 2009 | Comdial Impact 8124S Corded Phone
Change the time displayed on the Panasonic KXT7433
This phone is used with a Panasonic digital phone system, and the date and time are set in the control unit, not the phone. The phone just displays the system time. You'll need to check the manual for the service unit to see about time setting.
Jan 15, 2009 | Lands Phones
How do you set the time and date?
Step 1.
Press the PROGRAM button, then press * * 1 2 3 4
The display should now read: USR-PGM NO?
Step 2.
Enter: 0 0 0
Display: Day/Time Set
Step 3.
Press NEXT (or the SPKR PHN button)
Display: shows date (if you need to change the date, see steps 5 thru. 10 below)
Step 4.
Press NEXT (or the SPKR PHN button) again
Display: shows time example: 12:00 AM
Step 5.
Enter the hour
to change current entry, press CLEAR (or the TRANSFER button)
Step 6.
Press --> (or FWD/DND button)
Step 7.
Enter the minutes
Step 8.
Step 9.
Press SEL (or AUTO ANSWER/MUTE button) to change AM or PM
Step 10.
Press STORE (or AUTO DIAL/STORE) - Don’t forget this step!
Step 11.
Press END (or HOLD button)
Step 12.
Press SPKR PHN button or pick up and hang up the phone to leave programming mode.
Dec 20, 2008 | Panasonic KX-T7731 Corded Phone
Setting up voicemail on comdial 8212S-F8
Your phone model number is no help with this problem. You could have this phone on one of several different Comdial phone systems using one of several different voice mail systems. You will need to determine which voice mail you have and locate instructions for that specific unit.
Dec 13, 2007 | Comdial Impact SCS 8212S Corded Phone
Changing the display
In your system support room - - you will have two computers set up for your phone system - maybe (at least that's how it's set up here).
One is for the voicemail system and one is for the phone display, essentially.
You will log in to that other station and when you get the command prompt type
change station xxx (where xxx is the extension of the phone display you wish to change).
Sep 13, 2007 | Avaya Definity 6408D Corded Phone
Avaya 4412D Corded Phone Logo
296 people viewed this question
Top Avaya Lands Phones Experts
martin hogg
Ekse
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
