Question about Skagen 233XLTTN watch
Battery type battery
Battery size for emporio armani ceramic ladies watch
  • To determine battery type: open back
  • Locate battery holder and identify type. Note battery mounting
  • Place opened watch in plastic bag to keep it dust-free while you obtain a replacement battery
  • Remove watch from plastic bag and install new battery
  • Check operation
  • Install back
Finally, reset watch as necessary
Aug 28, 2016 | Emporio Armani Watches
How to replace battery in Skagen 585XLTMXB watch ?
  • Remove back
  • Find battery and identify type. Note mounting arrangement
  • Obtain replacement of correct type
  • Remove old battery. Install new battery
  • Check operation
  • Install back
Aug 09, 2016 | Skagen Watches
What is the battery specification/type/spec for the Sekonda 3101 Men's writwatch
The practical answer is to take your watch to a jeweler who will not only open it but probably will install a replacement battery for a reasonable charge.
Mar 19, 2015 | Watches
Battery
The Casio Forester FT500WVB watch has an EL (Electroluminescent) backlight and requires one silver oxide button battery. The SR621W battery (also known as type 363) is recommended by the instruction manual for the watch. Note the suffix "W" means this battery is a high drain type which is suitable for powering a watch mechanism and the EL light as well for 2 to 3 years, depending on use of the light. "SW" suffix batteries are low drain and are intended only to power a watch mechanism, and not a light. Note also the "SR" prefix indicates the battery is silver oxide and not lithium. The SR type batteries do not use mercury and are therefore safer to dispose of when they are discharged. I have found the type SR626W (also known as type 377) battery is also suitable for the FT500WVB watch and it has more stored power and should therefore last longer.
Last, the Casio Forrester FT500WC looks exactly like the FT500WVB, but it is a different watch internally. The FT500WC has an LED light and requires two batteries- the SR920SW low drain silver oxide battery which powers the watch mechanism and the CR1616 lithium battery which powers the LED. The LED is brighter than an EL light and stays on longer than the EL light when activated. But the LED has a bright dot light source that some might find annoying.
Apr 17, 2014 | Casio Forester FT500WV-3BV Wrist Watch
I don't know the type of battery for my Colibri watch.
Take your Colibri watch to a jeweler who will remove the back, identify the battery type, and install a replacement, all for a reasonable sum. Make note of the battery type for future replacement.
Feb 23, 2018 | Colibri Watches
Can't find the battery number
The battery type and number should be listed in the owners guide that came with watch. If that's missing the battery type is printed on the battery.
Nov 06, 2010 | Tommy Bahama Rlx1004 Relax Beach Cruiser...
I have a la scala tonneau women watch, the watch type is 0310702, i need to change a battery, but so many type and size of battery, which type and size watch battery is the right one?
The battery has its identification number on it, so if you remove the back of the watch you should be able to read the type without stopping the watch.
Or you could take it to a watch shop, who will have a stock of batteries. Removing and replacing the back of a watch sometimes takes some practice and I advise you to give the job to an expert, especially if it is a water resistant type.
Jan 13, 2010 | Concord Industries Concord, La Scala...
Dont know battery type for ecclissi watches?
Measure your original watch battery (diameter and height).
Compare with the cross reference list and find exactly what you want.
List is here: www.battery-info.co.uk/watch-battery-cross-reference.html - 19k - Cached - Similar pages
Dec 20, 2008 | Watches
Skagen 233XLTTN watch Logo
69 people viewed this question
Top Skagen Watches Experts
Jerry Greenberg
Jerry Greenberg
Gary Nitowski
Are you a Skagen Watch Expert? Answer questions, earn points and help others
