Mitsubishi msh 12rv
Lh light flashes continuously a/c a/c works occasionally and then cuts out
4 Suggested Answers
SOURCE: not working probly two flashs then pause
The two flashes are telling you what's wrong with the unit. Take the cover off of the unit inside(evaporator) and there should be a guide on the panel with the wiring diagram. On this diagram there should also be a solution to what each blink means. One blink means this, two blinks mean that, etc... Hope this is helpful.
Posted on Mar 14, 2009
shastalaker7
  • 1515 Answers
SOURCE: My reverse cycle air con (Mitsubishi MSH 12RV) is
I would check the reversing valve. This is what switches the flow of refrigerant for Heating and cooling.There could be several other reasons that could cause it not to heat.
Good Luck, Sincerely, shastalaker7
ps Heat pumps are very temper mental, like I said there could be many things that could cause this problem, and I couldn't walk you through them all. If you have a split system, two piece unit, go to the out side unit and have some run the a/c in cool. Then after a few min. have them switch it to heat and you can hear the reversing valve switch to heat, as it will make a swishing sound.If it doesnt, the valve may be bad, no power to the coil on it, or even the coil could be burned out.
Posted on Oct 30, 2009
  • 37 Answers
SOURCE: I have a heat pump
If its not being turned off by the thermostat, sounds like it might be the low presure switch kicking it off due to low freon. You will have to get a HVAC tech to charge it back up.
Posted on Mar 14, 2011
I have a Mitsubishi Split model MSH-09NV but not turn on, and the leds are off. The Split not work with bottom emergency neither.
Ensure power supply is correct and you have correct live and neutral and Earth at unit, test power across live and neutral to see voltage at outdoor unit terminals
Dec 04, 2015 | Mitsubishi Heating & Cooling
Replacement remote for Mitsubushi aircon MSH-24TV, how do we get them talking?
If you wish to buy a genuine remote control, you have to contact the authorized service centre for Mitsubishi. If you wan to buy a universal remote control, you should first check, which brand remote control have setup codes to Mitsubishi brand TVs. If you wish to get this detail, try the links given here. It has setup code list, and setup procedure to many popular brand remote controls. Check and find out which brand remote control have the codes to Mitsubishi, and buy that one according to availability.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Dec 24, 2013 | Televison & Video
I have a heat pump mitsubish MSH-12RV. It turns itself off after 1-2 minutes operation. Ihave cleaned the filters and re-set the clock. Any other suggestion?
Mar 14, 2011 | Mitsubishi Heating & Cooling
Mitsubishi split-type air conditioner model MSH-26SV. When the unit is switched on, the 2 green lights on the front panel light up normally but but the unit doesn't work at all and, after a few minutes,...
Hi I have Mitsubishi split unit which is 5 years old. when turn heat mode for 30 deg C on the remote condesing unit runs for about 6 minuts and stops. what would be the Technical problem ?Thanks an Apprentice.
May 23, 2010 | Mitsubishi MS09TW Air Conditioner
Left rear tail light went out and its not the bulb can't find the fuse
If Same Light For RH Lamp Is Working Then It Could Be Problem with Bulb of Lh Tail Lamp Or Wire Got Disconnected, Check Main Socket For LH Tail Lamp, Some lose Connection Or Corrosion May Be There, Fuse Is Ok.
Jan 26, 2010 | 2003 Mitsubishi Outlander
My reverse cycle air con (Mitsubishi MSH 12RV) is not producing warm air (for use during cold weather). Which is likely the faulty part ?
Oct 30, 2009 | Heating & Cooling
Have picture and sound then intermittently drops the signal
The DM is in the process of failing.depending on the age of the unit it may not be available.
Here is Mitsubishi's Parts Department Phone Number. 1800-553-7278.
I hope this helps,
Skyassoc
Jul 23, 2009 | Mitsubishi WS-65315 65" Rear Projection...
I have a a/c unit mitsubishi electric ms-12rv r22 when starting it on cooling or heating mode it stops after 30sec and the operating light flashes and the otdoor unit does not run the indoor unit fan stops...
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Apr 04, 2009 | Mitsubishi MS12TN Air Conditioner
Not working probly two flashs then pause
Mar 14, 2009 | Mitsubishi Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
