Panasonic NV-HD100 remote
My vcr plays it gets audio but no video,when i test in the back of rf signal it comes,but no vissual,or video comes only audio,
SOURCE: panasonic VCR VIDEO PLAYER
Hi, the problem may be typical for this VCR , you must to change 2 mechanical parts, one is the plug on the loading motor , the other is a rod, but you must to have experience in VCR repairs, becouse of that the best solution is to find a Panasonic service center
Posted on Jun 04, 2008
  • 275 Answers
SOURCE: JVC HR-D337MS Multisystem VCR - NO SIGNAL
Connect RF out of VCR to Antenna IN of TV. There should be a Test Signal switch at rear of VCR. Push it to ON. JVC VCRs generally generate a RF signal in the UHF band, around channel 36. Scan all channels on your TV, you should gete a Test signal of 2 parrallel black bars around channel 36. That is the Channel on which you can view tapes. Switch off 'Test signal' at rear of VCR, and press play. you should be able to watch your tape.
Posted on Jul 20, 2008
SOURCE: panasonic NV SJ205 changing RF settings
Hi.. have your solve the problem?
To change channel, hold down MENU button in the remote control for 5 seconds or more, the VCR display will come up. Enter the desired channel numberby channel button. Press MENU button to finish setting. Re tune your TV to the new RF channel..
Posted on Oct 28, 2008
SOURCE: Set the clock on my Panasonic NV-J11 HQ VCR
Hey there - I've got the exact same model VCR; although I've lost the manual as well, I've been using it for so long that I
can usually remember it all from heart:
To set the clock
1. Open the flip-down lid, push [CLOCK] button.
For each of the steps below, use the white-labeled [+] and [-] tracking buttons to increase/decrease each number.
2. Two digits should be blinking - this is the year (last two digits only) - adjust and push [NEXT] when done.
3. Two digits, with a "D" next to them should now be flashing - this is the month (1=January thru 12=December), adjust and push [NEXT] when done.
4. Two digits, with a "M" next to them should now be flashing - this is the day-of-month (1..31), adjust and push [NEXT] when done.
5. The time should now be displayed, with hours flashing - adjust and push [NEXT] when done.
6. The minutes of the time should now be flashing - adjust. When you push [NEXT], this will complete the date-setting and start the seconds-of-the-minute off at zero - handy for synchronising to an external time source (I recommend using the
Teletext broadcast clock if available - you'll usually find your recordings will start right-on time when you do this, depending on your TV station).
7. If you make an error at any step above, push [CLOCK] to exit clock-setting mode and start again.
Depending on your model of VCR - the clock may either persist through power failures (backup battery) or may have to be reset next time power is lost. Mine doesn't seem to have a backup battery.
To program the VCR for timer-recording: There are two modes, Timer Record (start and finish recording at arbitrary times in the future), and OTR ("One Touch Recording", start recording right now and finish at a set time in the future).
*** Timer recording ***
There are eight programme slots (numbered 1-8 on the display), each programme slot has an individual channel and start/finish time associated with it. Programmes can be scheduled up to 1 month in the future.
Push [PROG/CHECK] to cycle through each slot (after the eighth slot, it will return back to normal operating mode).
When you want to set a programme, push [PROG/CHECK] until you find an empty slot (date/time will be all dashes). Then do the following:
1. Channel should be flashing - set this using white-labeled [+]/[-] tracking buttons and push [NEXT] when done.
2. Date should be flashing (defaults to today), use [+]/[-] to adjust starting date and push [NEXT] when done.
3. Set the starting time ("ON" should be lit next to time) (defaults to now), use [+]/[-] to adjust starting time and push [NEXT] when done.
4. Set the finishing time ("OFF" should be lit next to time) (defaults to starting time), use [+]/[-] to adjust and push [NEXT] to complete the setting of this programme. After this, you'll be returned to the start of setting the next programme (the unit will also beep five times to confirm you have a valid programme set).
If you make an error (or you need to clear a programme slot that already has a programme set), hold down the [-] and [+] buttons for three seconds until the starting time/date becomes all dashes.
When you're done with setting your programme(s), keep pressing [PROG/CHECK] until you exit into normal operating mode, then push the [TIMER REC] button to activate the timer; this will put the VCR into timer standby mode, and the orange clock icon should be lit solidly on the display. There should also be a number (1..8) lit for each programme that has been set, but is still yet to run. Make sure you have the tape inserted and positioned in the right place when you do this.
After timer standby mode is activated, you can then push [PROG/CHECK] to review the individual programme slots; each push of [PROG/CHECK] will cycle through each slot (the display will time out in 10-15 secs).
To get out of timer standby mode (either when after the programmes have run or if you've made an error), push [TIMER REC] again - this will return you to normal operating mode (where you can fix errors if need be). Programmes that have run to completion should be automatically be cleared.
*** OTR (One Touch Recording) ***
This will start the tape recording immediately (good for when you have an unexpected distraction or sudden change of plans) and have it stop at a later preset time. The OTR mode only has one programme slot, unlike timer record.
1. Insert tape, have it positioned where you want to record from. Set the channel to the one you want to record from.
2. Open the flip-down lid, look at the bottom-right corner of the array of buttons inside.
3. Push the green-labeled [OTR +] button; this will start the tape recording instantly (the red "OTR" indicator should be lit on the display).
4. The stop time should also be displayed - use the [OTR -] and [OTR +] to adjust the stop time. When you're done, that's all you need to do (you can adjust it any time later).
To abort OTR mode (ie. if you start it by mistake, or want to stop the recording early), push the main [VTR] button to stop the recording. Yes, that's right - turn the whole thing off, it'll leave you in standby mode.
Hope this helps!
-- Bryan R.
Posted on Jan 12, 2009
Grubhead
  • 5362 Answers
SOURCE: Panasonic VCR has F06 code
You appear to have a K Mech model. F06 is the code for the mechanism locking after unload. The cause being something to do with the loading motor or the way the carriage is aligned.
Posted on Jun 16, 2009
I have an older Phillips VCR which I am tryuing to get tape playback through to my older sanyo small tv. Can you tell me how to please,
Either you can use the composite signals which is to connect the video out / audio OUT from your VCR to the video /audio IN of the TV and choose the input select to be LINE IN or VIDEO IN.
If there is no input then you can connect the RF OUT from the VCR and play a tape or use the test signal found on many sets on the RF panel. Now tune the TV, manual is better or the entire presetted TV channels will be erased off. Once the signal is found it will be memorised.
Hope you get this right.
Sep 03, 2011 | Televison & Video
How do you tune a Panasonic VCR model number NV-HD100 in please
You need to connect the RF ( cable or TV) to the input and connect the output to the TV. Now select the menu to auto scan the channels. The you can select timer to set the channels,time and date.
please find the link below for support.
http://www2.panasonic.com/consumer-electronics/support/Video/VCRs.75427
Apr 05, 2011 | Video Game Consoles & Games
Panasonic vcr - audio working, no video
I think this sounds like the old test signal so you can tune in the RF on a TV. Have a look around the back see if you can see a test switch.
You can also look it up in the manual. If you have lost that you can download it free from the Panasonic website.
Feb 10, 2010 | Panasonic NV-HD680 VCR
How do you hook up the dvd player to the tv with a vcr hooked up to the tv
Leave the cable box powered on but disconnected from the TV or VCR. All other components should be disconnected and unplugged, giving clear and easy access to all connections. If components sit in an entertainment unit, make sure all A/V cables can reach the RF modulator and the cable from the modulator can easily reach the television.
  • Step 2 Hookup the first coaxial cable from cable box output, usually labeled "TV," "TV out" or "Out to TV" to the cable "In" on the VCR. Connect the second coaxial cable from the VCR's out to "TV" to the coaxial input on the RF Modulator.
  • Step 3 Connect the third coax cable from the coaxial cable "Out" jack on the RF Modulator to the coax cable "Input" on the television.
  • Step 4 Take one A/V cable, connect the red (right audio channel,) white (left audio channel) and yellow (video) from DVD player's "Output," to the corresponding DVD "inputs" on the RF Modulator. Place components as desired but still disconnected from power. Plug in all power cables including the RF Modulator's into the surge protected outlet strip.
  • Step 5 Make sure the Channel select switch usually found on the back of the VCR and the Channel select switch on the RF Modulator are both set to Channel 3. This channel is used on the television to view your components.
  • Step 6 Turn on the power strip and turn on the TV. Cable reception should come on as usual. Set the TV to Channel 3 and turn on the VCR. With VCR on test it by playing a video tape. The RF Modulator should sense the signal and automatically switch to "VCR."
  • Step 7 Switch off the VCR and with the television still on channel 3, turn on the DVD player. As the RF Modulator senses the DVD player signal and switches to DVD, its welcome screen should be seen on the television. Play a DVD to test and once you're done with the DVD turn it off and the cable should come back on.
  • Jul 15, 2009 | Televison & Video
    Video transfer not working
    1. connect VCR(recorder) to TV, select TV proper channel to get signal from VCR
    2. connect Mini DV to VCR, for example, you are using AV1 input on your VCR
    3. on you VCR, select channel(or input) to AV1, insert a blank tape
    4. turn your Mini DV to play mode and play, press REC on your VCR
    you should get picture now.
    May 08, 2009 | Panasonic NV-DS60 Mini DV Digital...
    Operating manual Panasonic NV-HD610 VCR
    Hi this is tech crazy
    May i help you on this issue .I have given gist of the manual.so that you save enough time by just having glance at it
    The Panasonic VCR/VHS has an RF in and RF out sockets, it also has one red and one white audio out socket. It also has AV1 and AV2 sockets which are rectangular with many pin sockets which i believe are for scart cables. The video also has a switch for RF On, Off and Off(test Signal).
    The sharp LCD has one an antenna in socket, AV1 (Red, Yellow and White sockets), S-Video, AV2 (Red, Yellow and White) and Component Y, Pb, Pr and Audio (Red and White)
    To connect these two together in order to watch old video tapes on the television
    take the out rf socket from the vcr and screw it on the sharp antenna and make sure that you have the tv on channel 3 or 4 which is normally the channels vcrs send the signal 2 and the rf should be on
    Hope this solution helps you
    Please do rate me Sir/madam
    Feb 04, 2009 | Panasonic Televison & Video
    Panasonic TV: TX-28DTX10,VCR nv-HV60 EB, DVD:SC-HT 520
    EC means euro connector, I.E. Scart socket. For some reason there is no video signal coming out of the scart cable/out of the VCR or being displayed on the TV. Try plugging the scart plug into a different scart socket and see if that helps.
    Sep 14, 2008 | Panasonic TX-32PL10 32" TV
    Panasonic NV SJ205 changing RF settings
    Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
    1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
    2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
    Have further query, let me know please.
    bye.
    Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
    Panasonic NV-SJ205 Changing Rf ?
    ok. This is a really easy one.
    All you have to do is hold down the menu button on the remote control for more than 5 seconds, If that doesnt work hold down the power button on the remote control for more than 5 seconds. If that doesnt work hold down the power button on the actual vcr unit for 15 seconds. The first method should work for Panasonic's fine.
    This will then display your current rf output.
    You can then change the output by using the up and down arrows or the channel up and down button on your remote or the vcr unit.
    Press menu button to save or the same button you used to bring up the rf opposition eg power button on remote or the unit.
    all the best. Top tech
    Sep 02, 2008 | Panasonic NV-SJ205 VHS VCR
    Toshiba Model: SD-V295 DVD/VCR Combo Setup for TV recording
    The proper hookup is antenna or cable into the VCR RF/antenna input, then VCR RF/antenna output to the TV RF input. The hookup you describe means no signal is getting to the VCR.
    With some TVs, there can be Video and audio output jacks which can be hooked to the video and audio jacks of the VCR. However this would likely mean you could only record the channel being watched, and, the TV would have to be on.
    Jun 07, 2008 | Toshiba Televison & Video
    Televison & Video Logo
    37 people viewed this question
    Top Televison & Video Experts
