Telefunken lcd tlcd32fhdua
No back lights
My telefunken flatscreen tv goes to a black screen just seconds after switching on. The screen shows for about 2 to 3 seconds and then turns black instantly. How can I fix this
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 14, 2016 | Televison & Video
What sound frequency should my Telefunken be set on?
Refer its user manual for details about audio settings. It sounds that the bass level is too low, and treble level is quite high; or the speaker to your set is damaged.
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Jun 27, 2014 | Vizio L32 32 in. LCD HDTV
Telefunken lcd tv
http://www.alibaba.com.
Try the above link for the availability of the mother board.
Gopakumar Gopalan Google
Mar 10, 2014 | Televison & Video
Telefunken Vegas Tv + All For One Universal Remote = :(
Codes to check are 058,038,049,026. If you wish to get more details to different brands of universal remote controls, check this link.
Feb 09, 2013 | Televison & Video
Telefunken LCD TV
As far as I know the only way to set lock mode on/off is using the remote.
The only thing I can think of is unplugging power cord for five minutes to check if this reset settings.
You can get a remote here :
Remote controls for TELEFUNKEN
Aug 14, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
