As I'm cutting grass I will turn it off to dump the cut grass out of the bags. The motor is hot at this time I go to start it and it wont. I checked the oil, and made sure battery cables were tight. If you let it sit for a minute, it will then turn over. FYI- The lights come on also, the battery I would think is not the problem.
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
SOURCE: 1993 john deere 445 surging and popping down on
sounds like the flote is stuck down in the carb thats causing it to flood up strip card and give it a goofd clean out
its that or the mower deck is sezed up or the blades are rounded off and your stalling the engine trying to turn it and cut grass,, have a look at them as well,,,
SOURCE: John Deere x520 pto issue
not trying to insult your intelligence, but did you make sure the belts were installed properly.it does happen to the best of us..good luck
hello rich, as far as i know there is no way to bypass the reverse safety button,this was put on there for your protection and by law to keep from backing over people such as children and animals,,hope this helps,
