Hi i have a pioneer vsx-47tx i was looking at a movie when i heard a pop from the eciver it then shut itself down now when i press the power button it powers up for a few sec then shuts down
    Genius:
  • Audio Player... Master
  • 1,054 Answers
Sounds like a problem in the amp. Probably needs to be looked at by a pro
Posted on Jul 19, 2013
SOURCE: pioneer vsx-d511 amp error
I've had the same problem for over a month and have yet to find the time to get to it. However, I there may be a fuse on the circuit board that needs to be replace. That's just my guess.
Hope it's the solution.
Posted on Sep 17, 2008
tech48
  • 624 Answers
SOURCE: receiver randomly shuts off during play
This is the "Protect" mode. It is either a bad speaker, or not good ventilation, or a channel going out in the receiver. Please provide more details about the problem so I can help you better. How long is it playing before it shuts off, does it shut off even if the volume is low? Disconnect the speakers form the receiver and then turn it on and let it play without speakers, if it still shuts off then the problem is not the speakers. More information is needed to better diagnose this problem.
Posted on Feb 06, 2009
Gurudristi
  • 98 Answers
SOURCE: Pioneer VSX-D209 receiver shuts off when too loud
Dear Tabasco,
Your receiver is basically going into protect mode.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem.
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck! Thanks for using FixYa!
Posted on Apr 21, 2009
  • 4 Answers
SOURCE: Pioneer VSX-816
With the receiver off, press ENTER + ADVANCED SURROUND keys continuously for 2 sec. and it will tell you the fault it encountered. Even if it has a short, it will still protect the speakers; however, it is still a good idea to disconnect all speakers before doing this.
Posted on Aug 12, 2009
SOURCE: Pioneer power LED is Blinking
If that didn't work, with the power off try holding Tune + and Auto surround/stream direct buttons for a few seconds to reset the protection circuits. Make sure to keep 8" of empty space above the unit for air, as overheating can cause this problem. If it fails again, there could be bigger problems, so get it checked
Posted on Jan 24, 2010
While watching TV (all audio ran through my Pioneer VSX-516), the receiver shut off by itself, so I powered it back on. Then it powered off again a couple mins later, and wont power up at all now. I...
Try holding the "advanced surround" and "enter" buttons and see if it turns back on. If it shuts off again, disconnect all speaker wires and try it again. If it stays on, you have a bad speaker or wire. If it still shuts down, the amp is blown and needs to be repaired.
Mar 29, 2013 | Pioneer VSX-516-K
How to 'fix' a Pioneer VSX-D509S that stopped working when we lost power to our house. Suggestions?
Try holding down the advanced surround button and power button. If the unit locked itself into protect, this should clear it.
Jan 03, 2013 | Pioneer VSX-D509S Receiver
My vsx-819h shut down and wont turn back on
hold "Advanced Surround" button, press "Standby" button for 3 seconds, unit will power back.
Jan 17, 2011 | Pioneer VSX-819H-K A/V Receiver
My pioneer VSX-1016 shuts itself off during loud portions of a movie. I have checked the speaker wiring and have clean connections. Any other ideas?
Yes, evaluate the load presented to its amplifiers by the speakers. If you have any speakers running parallel on the amps instead of one per amp channel you could be experiencing temporary unacceptable drops in impedance.
and
From page 57 in the manual...
• Turn down the volume.
• Lower the 40 Hz and 125 Hz equalizer levels in the Manual MCACC setup on page 34.
• Try switching on the digital safety feature (put the receiver into standby, hold down the SYSTEM SETUP button on the front panel and press STANDBY/ON to switch between SAFETY ON and SAFETY OFF
. If the power switches off even with SAFETY ON selected, turn down the volume.
Dec 29, 2010 | Pioneer VSX-1016 Receiver
Pioneer VSX 47TX receiver problem. Hi all, Recently, the pre/pro is acting up. Every time I switch it on, it goes somewhere else other than where it was the last time. For instance, I have it on 'DVD,...
At first I thought you might have some bad soldering. But on second thought it might be a control circuit problem. You would only have a good chance of fixing this yourself only if you had a very comprehensive service manual, I would have thought. So start searching for the Service Manual.
May 03, 2017 | Pioneer Audio Players & Recorders
Pioneer VSX-1019 with a flashing red MCACC
you can "release" the error by pressing the "down arrow" and the "zone 2 on/off" for 2 seconds.
Mar 11, 2010 | Pioneer VSX-1019AHK A/V receiver
Pioneer VSX-35TX , "Power Off Message" , will not stay on.
It's probably going to need output transistors and some resistors, it's a job for a technician. A rough estimate on price is $100 to $130 (that's parts and labor). Before the smoke it may have only needed repair of bad connections.
Mar 08, 2009 | Pioneer VSX-35TX Receiver
Blinking Standby
regarding the Pioneer VSX-912 blinking standby light. This is how you reset it; press the "advanced surround" and the " enter" at the same time for about 3 seconds. Make sure you press the ENTER on the reciever (its the one on top next to the small dial) If you press the "ON" instead of "ENTER" it will not work. If an error message comes on and shuts the unit down, just reset it again. This should save you some $$$$. To bad Pioneer did't put this info in the manual.
May 22, 2007 | Pioneer VSX-D912 Receiver
41 people viewed this question
 Grubhead
Grubhead
