Question about Garden
Husky 1750 The quick connector doesn't fit on or to the machine inlet, I try to tap them together but nothing? So what to do?
    Sergeant:
  • 406 Answers
Try to install the fitting without the o-ring if connection is made then replace the o-ring the intend to swell.
Posted on Aug 05, 2013
You can change the connectors on the wiring loom there are only two wires per valve
this video might help
Jul 22, 2013 | Whirlpool duet Washing Machines
How do i get my filter out of my bush a127ldw washing machine got E03 error am working my way through your list but cant get filter out
Water inlet filters
On the tap part of your machine's water inlet
hose and at the ends of water inlet valves, there
are filters to prevent entrance of the dirt and
foreign materials in the water to the machine. If
the machine is unable to receive sufficient water
although your water tap is fully opened, these
filters should be cleaned.
x Remove the water inlet hose.
x Remove the filters found on the water inlet
valves by using a pincer and wash thoroughly
with a brush. (1)
x Clean the filters of the water inlet hoses
located on the tap side by removing manually
together with the seal. (2)
x After you clean the filters, you can fit them
the same way as you have removed them.
Pump filter
The pump filter system elongates the life of your
pump, which is used to drain the dirty water. It
prevents lint to enter the pump. Cleaning of your
pump filter in every 2-3 months is
recommended. To clean your pump filter:
x Open the kickplate's cover, by pulling the
handle. (2-A & 3-A)
x Before opening the filter cover,place a cup in
front of the filter cover to prevent flow of the
remaining water in the machine.
x Loosen the filter cover by rotating it counter
clockwise and drain the water. (4-A)
x Remove the foreign materials from the filter.
x Check for the rotation of the pump manually.
x After you have cleaned the pump, fit the filter
cover by rotating clockwise.
x Put the kickplate cover into place.
x Do not forget that if you do not fit in the filter
cover properly, it will leak water.
Jan 21, 2013 | Washing Machines
Dell Inspiron 1750 will still not start up after new motherboard has been fitted
I think the new motherboard dosen't matchmaking with your Laptop .So , you should change it
Dec 03, 2012 | Dell Inspiron 1750 Laptop
Our washing machine starts up like it is going to cycle, it even counts down, but the water doesn't run. We have tried unplugging it, and cleaning the filter, but nothing has worked. Any suggestions?
Hi from retired Englishman in SW France
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Sep 14, 2011 | GE Energy Star WCVH6260F Front Load Washer
Hello.. The washer doesn't fill with water. I disconnected the hoses from the two back prongs of the washing machine and the water flowed from my house out the hose. Telling me it's not my...
Hi Rich from retired Englishman in SW France,
No- has nothing to do with the load size. You have already carried out what I normally advise for this sort of problem (below) so it looks like it's down to the last 2 sentences. Sorry ;-0(
John C
Jul 13, 2011 | Kenmore 22422 Top Load Washer
Removed on/off switch from a HUSKY 1750 powerwasher to repair with a new one.....now can't get it back together. Can not find a repair manual.
Hi, To make the switch work connect to the coil. The switch grounds out the spark from coil.
Good luck.
Jun 18, 2011 | Garden
How to connect the cold water supply to K 3.65 Jubilee? In the instruction leaflet, figure J, number 1, 2, and 3 I seem unable to connect it. The above is a pressure washer.
Hi all you need is a 3/4 tap fitting from a diy store.
Maybe a hoselock 3/4 male and female fitting that will fit a standard 1/2" hosepipe. If struggling I can send you a link to the fitting on ebay but if you type in karcher tap connector you will see it by the seller vavcandwash.
Feb 14, 2010 | Karcher 1750 psi Electric Pressure Washer
Haier XQB55-10 : water leakage from inlet hose jointer
You must examine your machine hose to see if it is blocked. Clean out the fine nets in the hose as well as at the machine entry (inlet water entry). Clean well with a tooth brush, refit carefully. Water should be in good pressure for machine operation.
Feb 23, 2009 | Haier HWD1000
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
