Question about Frigidaire Gallery Series GLRT83TEK 30" 18.2 Cu. Ft. Top Mount Refrigerator w/ 2 Full-Width Glass Sh...
Gas oven long preheat time
Pre heat time is longer than usual
  • Official Brand Answer
  • 4,342 Answers
Hello Peter, there could be
a number of any one of several underlying causes in why the oven is
experiencing this particular issue:
Convection
heating element
Thermal cutout
Thermal oven
sensor
EOC (electronic
oven control)
Ignitor,
Bake or broil
element
All wired
connections
The parts above will need
to be assessed for further evaluation by a technician. Lastly the oven cavity and
insulation should be checked to ensure there are no gaps or damages that will
leak out the heat. At t his time, I would recommend contacting a professional
to assist you further since it is always a good idea to get the appropriate
diagnosis prior to making any unnecessary part replacements.
Posted on Jul 22, 2013
Is preheating this toaster oven necessary? How do you preheat?
Preheat is helpful when you're not cooking for more than a few minutes. If you're going to cook for 20 minutes or more, then most likely you don't need to pre-heat.
To pre-heat, simply turn your toaster-oven on 10 minutes before you put the food in.
Feb 27, 2016 | Toaster Ovens
Oven not heating properly
I think the burner coil is damaged or needs to be replaced. Check it if its damaged then you should replace it then it will work surely at definite time.
Dec 08, 2007 | Ovens
When i turn on the oven it starts up as normal , "on" then "Preheat" then runs. About 30 minutes later both the "oven on" and the "preheat" indicator lights start blinking.
follow this test and fix it. God bless you
Oven Igniter
As the oven igniter weakens over time, it will take longer for the gas valve to open. If the oven doesn't bake evenly, it may be that the oven igniter isn't opening the gas valve when it should. This will cause the oven to cool down more than it should before the burner reignites. The oven temperature should not cool by more than 40 degrees before the oven igniter relights the burner.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't heat the problem is usually with the heating components. However, if the oven control board is bad, it might not send voltage to the heating components. To determine why the oven won't heat, first test the simpler components in the circuit. The oven control board can't be tested easily and will have to be replaced if it is defective.
Nov 04, 2013 | GE Profile Spectra JGBP90 Gas Kitchen...
Maytag gas oven takes a long time heat and smells of gas.
Important---if you smell gas--I'd be very very careful---could be your control valve or lines to it are malfunctioning or leaking. You might have to call in an expert repair person. How old is the oven? Some preliminary checks you might make are: Do you have a pilot lite or preheaters on the unit? If a pilot lite, make sure it is lit. An unlit pilot lite could sometimes give the smell of gas if malfunctioning. If so, there is is a procedure for lighting the pilot lite--check your user or installation manual. If you have pre-heaters make sure they are lighting up. Normally you have one for the top broiler burner, and one for the bottom oven burner. Check your preheater(s) by selecting either broiler or oven and visually checking to see if they are warming up. After 15 seconds or so, they should be turning bright red. You will see some light coming from them. Check one pre-burner at a time. If they do not come on quickly, shut off the associated valve. Again, be very, very careful with any buildup of gas. It could cause an explosion. At the least it could make you sick.
Sep 12, 2012 | Maytag Ovens
I preheat oven and i get an f2 err
F3 is the sensor, F2 is keypad failer. You have two choices. Replace the main controller List price $286. Its kinda easy, Unplug remove backplate and then unplug 2 wireharnesses and remove the controller, it held by two screw. Option 2. Pre heat with door open. Its wastefull in the summer but in the winter, 10 minutes may cost you less than $286 if you dont use your oven very much. Leaving the door open prevents the massive amount of heat that pours out the vent located just below your "over-heated" controller. After pre-heating the F2 usually doesn't appear during normal heating operation. I've done this over 20 times and main controller is the only way to get rid of f2 on whirlpool ranges
Jul 03, 2012 | Whirlpool WFG231LVS Stainless Steel Gas...
The oven sounds like it is sputtering the whole time it is preheating and baking something once it reaches it's temperature. Oven is working, just making this sound. Although, it does seems to take a...
While you didnt say if your oven is heated by gas or electric i am going to assume its gas and the cause of that sputtering sound is due to weak ingiter that is not fully opening the gas valve yet its just opening it a wee bit cauing it to basically starve for gas flow and sputtering all the time the gas is flowing. By replacing the igniter the gas will flow properly and stong and thusly the noise will cease and it will heat quickly.
If its electric heated let me know and i will figure why its sputtering
Oct 15, 2011 | Kitchen Ranges
Preheating takes longer than usual,what can be wrong?
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 19, 2011 | Kenmore 30464 / 30465 / 30469 Gas Single...
I noticed my oven was taking longer and longer to reach the preheat temperatures I was setting. As time went on, the stove was not heating up past 285 and now the temperature never increases but I can...
It is probably as simple as changing the ignitor...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 16, 2010 | Maytag MGR5770 Gas Kitchen Range
Oven sometimes doesn't heat up. Sometimes heats up to desired temp, then quits working. Sometimes doesn't even heat up at all. When preheated light comes on, thermometer in oven usually says about 100...
This sounds like a weak igniter, it would have to be a gas oven and the symtoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 14, 2010 | Amana Ovens
Frigidaire Gallery Series GLRT83TEK 30" 18.2 Cu. Ft. Top Mount Refrigerator w/ 2 Full-Width Glass Sh... Logo
63 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
