Question about Jeep 2002 Grand Cherokee Laredo 4WD
Po463 code 2002 jeep grand cherokee - Jeep 2002 Grand Cherokee Laredo 4WD
SOURCE: 2002 jeep cherokee laredo
the only problem that vehicle has is with cooling fans is relay/module or electrical harness to module that burns up located behind and under right front headlamp assy must remove headlamp to access relay/module that is what powers up fan motor module assy.
Posted on Aug 10, 2008
  • 55 Answers
SOURCE: 2002 Jeep Grande Cherokee overhead console has no display
try unhooking the battery to see if resetting the body computer helps. low batteries and poor connections at the battery can cause weird problems like this
Posted on Oct 16, 2008
SOURCE: setting timing on a 2002 jeep grand cherokee
how do you set the timing on jeep laredo 2002?
Posted on Oct 18, 2008
  • 41 Answers
SOURCE: engine code 95 jeep grand cherokee lerado
12 is a battery disconnect within the last 50 start cycles and 55 means the end of the diagnostic cycle.  Basically the computer found nothing wrong. The 12 code may seem incorrect if you haven't disconnected the battery recently, but from my experience the 12 code shows up almost all the time regardless.
Posted on Dec 16, 2008
  • 412 Answers
SOURCE: 2002 jeep power windows and door locks stopped
SOUNDS LIKE YOU HAVE BROKEN WIRES BETWEEN DRIVER'S DOOR AND BODY AT A PILLAR..PULL RUBBER BOOT FROM BODY AND DOOR AND INSPECT WIRING HERE
Posted on Jun 21, 2009
Color code for anti theft 2002 grand jeep cherokee
what are you doing
what is the job.
or symptoms.
color codes of what the wires?
the book covers that.
posted over 300 times now,
its free, its real and not fake.
click wJ (jeep name)
then go to chapter 8w (wires) and read
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
Nov 23, 2016 | 2002 Jeep Grand Cherokee
2002 jeep grand cherokee diagnostic trouble code P 0320? how do i repair?
No Crank Reference Signal at PCM No reference signal (crank-shaft position sensor) detected during engine cranking. Use this youtube step-by-step to fix it. How to diagnose P0320 crankshaft position sensor circuit failure
May 01, 2014 | 2002 Jeep Grand Cherokee
My 2002 jeep grand cherokee laredo wull not start shutdown 2 days ago checked all fuses but the ecu fuses don't know how to find them
According with your other quesions, the DTC P1491 code is actually radiator fan control relay circuit.
Soft reset if the battery disconnect would have erased the code; the first thing I would replace for that code (fan relay).
Additionally, its possible thta your THEFT system is activated, check owners manual to disarm. Check details here:
- Grand Cherokee fuses
- Diagnostic Trouble Codes
Hope this helps.
Mar 07, 2012 | 2002 Jeep Grand Cherokee
Why is the engine management light comin on mostly when i accelorate in my 2002 grand jeep cherokee
go to pep boys and purchase a good code reader for 150.00. but youwill find it will code out as a spark plug issue. thats what it was on my 2001
Dec 22, 2009 | 2002 Jeep Grand Cherokee
2002 Jeep Grand cherokee
you really need to get to a dealership and check for trouble codes and go from there
Jun 24, 2009 | 2006 Jeep Grand Cherokee
Diagnostics "P1762 Manufac. Contrl. Transmission"
Had the same code on my 2002 Jeep Grand Cherokee. Started having shifting problems as well. Code is for governor pressure sensor on trans. Cost me about $800 for dealer to fix. No problems after part changed out.
May 22, 2009 | 2002 Jeep Grand Cherokee
Setting timing on a 2002 jeep grand cherokee
You cannot set timing on the car.
The distributor cannot be moved.
Sep 25, 2008 | 2002 Jeep Grand Cherokee
Jeep 2002 Grand Cherokee Laredo 4WD Logo
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Kevin Daniels
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
