Question about Canon PowerShot S410 / IXUS 430 Digital Camera
Unusable When I turn the camera on, it makes warning type noises that I've never heard it do before, and then displays the code E18 on a black screen in the lower left hand corner.
  • Anonymous Nov 04, 2007
    code e18
  • Canon Master
  • 4,738 Answers
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Posted on Nov 16, 2007
    Sergeant:
  • 279 Answers
This is a hardware problem common with many Canon cameras. Unfortunately, there is no easy way to fix this. Canon can fix it for you, but they charge more to fix it than it would probably cost to replace the camera. There are entire sites dedicated to those who've had this error, but there is no way to fix it short of sending it in to Canon. One such site is here: http://e18.bitnet.cx/comments.php
Posted on Aug 28, 2007
Camera shuts off even with new batteries
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon.Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jul 12, 2010 | Canon PowerShot A95 Digital Camera
Camera does not power on. I get three beeps,
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 22, 2009 | Canon PowerShot S2 IS Digital Camera
The camera was dropped by my son, which happened before, when turned on the canon logo shows then the screen is black. An error message in the bottome left says E1b or E18. Help!! thanks
Here is some information on the E18 error: http://www.e18error.com
A repair guide (suggestions) http://www.e18error.com/repair.html
Forum for users with the same problem http://www.e18error.com/posts/index.php
May 21, 2009 | Canon Cameras
E18
E18 is the canon fault number for lens error. Is the lens stuck out? does it click when the camera is switched on? Try lightly tapping the lens on a hard surface. This sometimes resets the lens. If all this fails take it to bits! (but watch the flash module as this can give a nasty shock.Big black capacitor) You will see the lens module take the it to bits carefully and re seat the components. I have done a few over the years. It takes about an hour. If you have any more issues contact me.
Sep 04, 2008 | Canon PowerShot A400 Digital Camera
Whirring sound after start then black screen with E18 in bottom corner
this is very easy to fix- switch your camera on, grab then lens around the edges, and carefully give it a firm twist. It should click and turn on.
Dec 18, 2007 | Canon PowerShot A400 Digital Camera
A95 Trouble
Dec 08, 2007 | Canon PowerShot A95 Digital Camera
LENS STUCK IN EXTENDED POSTION
Nov 17, 2007 | Canon PowerShot A70 Digital Camera
Camera was dropped, lens will not retract, when on/off button is pressed the initial screen and sound appear but then the camera makes a kind of warning sound and E18 appears in the lower left hand co
Perhaps the lens got bumped (if the camera was one when it was dropped) and is out of place. Mine did the same and I sent it in (it was within warranty) and Canon fixed it.
Mar 18, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Black Screen
cannon will repair it free of charge,its a problem with ixus 400.
Sep 17, 2006 | Canon PowerShot S400 / IXUS 400 Digital...
Problem with my camera
Your lens is jammed, and needs to be repaired or replaced.
Sep 04, 2006 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot S410 / IXUS 430 Digital Camera Logo
47 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
